Dew on primary mirror of Mak-Newt (Skywatcher 190MN) or something else?
3 replies104 views
Craig Dixon avatar
Attached is a screenshot of a 3 hour stack of 15 second subs (This is UV/IR data for the stars only to complete a project). Could this be dew on the primary mirror:
I've also noticed that if I zoom in, the noise pattern is shockingly blotchy. This is a 1:1 view:
Of could this be an issue with a process within WBPP?
There is no dew on primary in Maks, it just doesn't happen (well, unless you are at 100% saturation). And even if it were (which is exceedingly unlikely) it would show as a general dimming of the image, that's all. Dew on corrector would be far more easily occuring though. The grainy look is just due to the short subs you're using, which means loads of RON to deal with.
Helpful Insightful
Craig Dixon avatar
The morning after I  shot this data, I looked down the tube and there was condensation in the middle of the primary mirror. I can't say for sure whether this formed during the night whilst data was being collected or in the morning but it was definitely there.
Do you think this data is useable just for the stars?
I guess you reached 100% humidity late in the night and given the very muggy day of yesterday that won't surprise me one bit. Chin up as at least you got clear skies while I get only clouds. Yes, the data is perfectly useable.
Supportive
Secondary mirror coating issue or possible light leak problem?
I was considering sending my secondary for my ago idk 14.5" over to terry at ostahowski optics for a recoat because if I look closely enough, I have what looks like an oil spot or something that slightly dulled a small part of my secondary coating th...
Secondary mirror coating could cause blotchy noise patterns in stacked images.
Nov 3, 2025
One dew solution that may not be for everyone.
I live in coastal Southern California and I have always struggled with dew prevention on my 10” DIY newt… I’ve tried dewshields, dew heaters, burning sage, shamans, you name it. Dewshields are ungainly and huge. Dew heaters would generally overheat t...
Dew on primary mirror is directly relevant to author's suspected dew problem.
Nov 28, 2025
WBPP experiencing "Unknown exception" errors during "Measurements"
I have been having issues with Pixinsight WBPP failing to measure a significant number of sub-exposures during the Measurements step with the reason as “Unknown exception. I have posted this issue to the PI forum and this time been told to use FBPP b...
WBPP processing errors could explain image quality issues mentioned by author.
Sep 28, 2025
