What's Going On with these Flat Frames
9 replies237 views
Jerry Gerber avatar
These images below are flat frames taken with the Wanderer Astro Flip-Flat at a remote site, using a ZWO ASI2600MC color camera.  They seem to work fine when I calibrate my lights with them, but they do not look like the flat frames I generate at home in the morning after imaging (sky flats at home).    Anyone know why they look they way they do and if I need to be concerned, what do I do?
Flat frame with UV/IR cut filter:
With L-Ultimate narrowband filter:
With Askar Ha-Oiii filter:
With Askar Sii-Oiii filter:
Thanks for any feedback!
I hope you take them at night, not during daylight. Otherwise is typical with some flat panels. Whether they are still do their job properly is hard to say as you'd be shooting with a far lower background brightness at your dark site I expect and you can get away with less then pristine correction that would otherwise be in the case in significant LP settings.
Jerry Gerber avatar
Yeah, I take them at night as soon as I am finished capturing the last sub for the evening.
Quinn Groessl avatar
If they properly calibrate your lights, don’t worry about it. That’s the rule I’ve always lived by for flats.
….if you are having flat panel issues you can always do sky flats and do away with an extra bit of hardware. It's the easiest way to make flats anyway, no panels, no t-shirts, just a clear blue sky. For that matter, a brightly illuminated wall indoors works well too.
Rostokko avatar
Those seem fairly normal flats for dual-band filters…
Willem Jan Drijfhout avatar
Look pretty normal. So how do your flats look like that you take at home?
Jerry Gerber avatar
....if you are having flat panel issues you can always do sky flats and do away with an extra bit of hardware. It's the easiest way to make flats anyway, no panels, no t-shirts, just a clear blue sky. For that matter, a brightly illuminated wall indoors works well too.
Not really possible when the scope is 900 miles away.
Jerry Gerber avatar
Willem Jan Drijfhout:
The flats I take at home (same camera and scope) don't have the multi color areas that the remote flats have.   Is this because of the difference between sky flats and LED flats?
Here's a flat from my backyard, using same camera and filter:
As you can see, the coloration is much more subdued.  Perhaps the sky flats are dimmer as I use 3 t-shirts over the lens.   There's also the normal vignetting that I don't see  as much in the remote LED flats.
Don’t see anything particularly strange. Any differences can be well attributed to the different light-sources. And the resulting differences in stretching will also make for some differences in how these images look like.
Flats in remote imaging
Hello - I am exploring what it would take to set up an extra scope/mount I have for remote imaging, and specifically looking at flat generation. I'd like my flat frames for all filters to be 4s or longer. I have the following questions: How many ...
Directly addresses flat frame generation for remote imaging setups.
Aug 7, 2025
Green banding issue in WBPP when using flats
Does anyone know what might be causing this green banding? I’ve never encountered this issue before, and it disappears when I exclude flats from WBPP. I have inspected my flats, and they seem normal. I’ve yet to try retaking the flats or do more test...
Discusses flat frame calibration issues and their visual artifacts.
Feb 7, 2026
