Is Seastar S50 Limited To Stars?
7 replies210 views
Szijártó Áron avatar
Hello and welcome. I'd like to ask everyone that houses Seastar  S50. Is the device limited to stars?
Last night, I went to photograph some deep space objects like the California Nebula. When the device is about to process the image, it says it cant stack the image all together because there are fewer stars in the area. So what? Does this mean you can't photograph any type of deep-space objects where there are fewer stars to process the image, so u can only photograph the many stars around a specific object? If so then it sucks. I thought the device could do it without any limitations.
Yes it can photograph deep space objects. Did you try another target? How much light pollution do you have??
Yes, it can photograph deep-space objects. Did you try another target? How much light pollution do you have??
Well, I live in a village, and according to the light pollution map in the app, it says green; I don't know what that means. Does it mean Average light pollution or acceptable? But I did photograph Andromeda galaxy, which was successful, and the ghosts of Cassiopeia.
Depends on the map. Sky brightness is usually measured in magnitude per arc/sec. A more general rating would be the Bortle scale.
Did you photograph those objects with the S50?
Well, currently, that is the only thing I can do deep-space images with, So yes. I'm still learning to find objects that I can capture. One thing that bothers me here is that you can't capture any objects in 5 degrees or what. This is sad because most of the objects are up and above the horizon.
What do you mean by 5 degrees?
like if u want to look above near the zenith.
The device is somehow telling me that you cant observe objects that are above 5° or sonething and need to look for other object.
Ahhhh, that's interesting. All alt/az telescopes have trouble when pointing near the zenith. If you've ever used a Dobsonian telescope you'll know what I'm talking about. I'm not surprised that it has this limitation.
Well written Insightful Respectful Concise Engaging
Need Help Processing Comet Images Taken With seastar
Hello everyone! I’m reaching out because I’m feeling a bit lost when it comes to processing comet images taken with the Seastar. This year, I captured two different comets, but I'm not sure how to process them. I tried following the tutorial from Dee...
Seastar image processing issues; author struggles with stacking limitations.
Sep 3, 2025
Request for 3i Atlas light frames while waiting for delayed Seestar S50
Hi everyone, this is my first post here. I recently bought the Seestar S50, but it's been delayed due to customs, so I'm afraid it will be impossible for me to get the 3i Atlas. I'd like to ask if anyone who has managed to photograph it could share t...
Directly addresses Seestar S50 device and its capabilities/limitations.
Dec 20, 2025
