First mosaic, all at once or per night?
7 replies187 views
Daniel Renner avatar
I plan to make my first mosaic M31, and it will be a 2 panel mosaic mono.
Should I capture all panels at on the same day multiple days or is it best to take 1 panel each night?
Eric Gagne avatar
I am also created my first mosaic over multiple days.  I do all panels each night so the seeing and the gradient is distributed equally.
I have done it both ways and I get better results with all panels in one night. That said, I've done it the other way too and it came out fine. It just depends on how consistent conditions are on the nights you image.
Well written
SemiPro avatar
Gonna pile on to the all-in-one-night crowd because you want consistent seeing and gradients in all your frames. This becomes more and more important the closer your target is to the horizon. You also need to strike a balance between efficient use of time and how little variation you want between panels. You could, for example spend one hour per panel before switching, but that might be too long given a particular scenario. The flip side is that you bounce back and forth every 10 minutes, but that is a lot of time lost to slewing, plate solving, and focusing again.
Generally speaking, the closer your target is to the horizon the less time you want to spend on each panel before switching.
Helpful Insightful Concise
….and if going more than one night you might want to reverse the order of the panels, this is to even out the effects of altitude.
Sam Badcock avatar
....and if going more than one night you might want to reverse the order of the panels, this is to even out the effects of altitude.
What do ya mean by this?? I haven’t done a mosaic just yet, m31 or the veil nebula will be
my first
hmm do you mean if i do a 2 panel mosaic the first night i do Panel 1 and then Panel 2.
Do you mean on day 2 i start with Panel 2 and then Panel 1 etc?
Yes, if it's a 4 panel mosaic do 1,2,3,4 the first night, 4,3,2,1 the next and so on….
Seeking advice on next steps in my astrophotography journey
I’d really appreciate your views on the next steps on my Astrophotography journey. Having been doing this amazing and absorbing hobby now for just under two years, I know that my journey has progressed from bafflement with how to use the equipment an...
Discusses astrophotography journey progression, relevant to mosaic planning strategy.
Feb 5, 2026
