Weird artifacts after stacking in Siril
2 replies87 views
Antoni Zegarski avatar
After manual pre-processing and stacking in Sirill this weird artifact pops up when showing image in autostretch.
I've tested and it is present either if i use the only flats or only darks or none or both so it's not its problem. Have you got any ideas how to get rid of it?
Marinos Rrapaj avatar
What stacking algorithm are you using and any pixel rejection? I found that Winsorized Sigma Clipping was giving me weird artifacts as well and once I switched to Generalized Extreme Studentized Deviate Test the artifacts went away!
Good luck!
Well written Insightful Respectful Concise Supportive
Oh… okay. I’ve used WSC so i’ll try the other one.
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
Camera artifact similar to post-processing stacking issue with image defects.
Nov 27, 2025
Odd Horizontal Thick Line Artifacts
Hello. I’ve reached a point of frustration and I’m unsure how to proceed. I have some image stacks that show up with these odd looking horizontal “lines. I cannot figure out what is causing it. I pre-processed in WBPP using lights, darks, bias, flats...
Horizontal line artifacts in stacked images match described artifact problem.
Mar 13, 2026
Dark vertical streaks in stacked image
I've been struggling with trying to understand the source of these streaks I see in some recent stacked images. I'm hoping someone here can offer an idea as to what the source is. I'm hoping it's not the camera itself. My set up is a ...
Vertical streaks in stacked images relate to artifact troubleshooting after stacking.
Aug 21, 2025
