Help Requested on Crescent Nebula
13 replies379 views
Andrew Topper avatar
Looking for input on this image. It was taken in Bortle 8 with a new scope: FF130. The scope is about at the limit of the mount. Crescent Nebula:  https://astrob.in/x5svip/0/
Thanks in advance.
Quinn Groessl avatar
I like the detail and it looks pretty sharp even at full resolution. I even like the blue color for the filaments or "brain" looking part of it. I do think it could use some different colors though. If you look at other pictures, they generally have red with like a blue bubble seemingly around it. Yours is all blue, which if I didn't know that the structure was there, it almost looks like you just did a poor job color masking. I think it would benefit from having more distinct color differences between what I'm calling the filaments and the bubble.
Jon Rista avatar
The color, given its a three band NB image, is definitely what stands out… Given you have both OIII and Ha, I am curious what your color mappings were? Did you map both Ha and OIII to the blue channel? If so, I think doing something to bring out the distinction between those two channels would help,  regardless of what palette you choose. Right now, there is no telling the difference between Ha and OIII, which I do think probably detracts from the image.
Another thing that stands out, is the stars all have mostly a white or very nearly white color. That may indeed be the result of the same issue, if Ha and OIII were mapped to the same channels. I do think that getting at least some diversity in the star colors, even if its not a lot, would help the image as well. The stars definitely have a mostly monochromatic presentation which I think is probably also a detractor.
Helpful Respectful Engaging
Thanks for the input. I'll review my image processing steps and post an update when I get some time to work on it.
Well written Respectful
NeilM avatar
Slightly random question but curious why you are at the limit of your mount?  The AM5 handles twice the weight of the FF130 and even with guide scope and cameras etc aren’t you well within the capacity limit?
Timothy Martin avatar
I would recommend more integration time—lots more. 7 hours per filter would really improve your result. More would be even better. Further, imaging in SHO will produce a fine result, but without using some more advanced techniques, it will tend to create a blue brain. If you want the typical pink brain with teal halo, HOO will get you there.
Well written Helpful Insightful Concise
Dale Penkala avatar
Andrew Topper:
Thanks in advance.
Hello Andrew,
1st very nice image here good round stars and nice fov. I would have some suggestions for you on this but very much agree with the others here.
1st more integration time would defiantly help you out but for the time you have its not bad. Even if you doubled the amount of integration time you’ll see a difference in the image as far as SN and I think you’ll find it will make your processing go a tad bit better/easier. It will also allow you to do a bit more sharpening on the internal structure of the nebula.
2nd you don’t see much in the way of a channel separation between your HA & OIII. I’m guessing you were shooting for something like an SHO, HSO or something along that line??? FWIW I shot this in a much wider field of view here a couple weeks ago. If your interested here is my HSO version with RGB stars for color: https://www.astrobin.com/uqfj83/D/.
Like others have mentioned an HOO version will give you a much more distinct channel separation so that you can see the Oiii bubble/shell around the actual nebula or “brain” part of the object. Here is my HOO version as well if your interested to look at it: https://www.astrobin.com/uqfj83/D/
3rd as @Jon Rista pointed out your stars really don’t have much in the way of color but you can very easily remedy that one. My suggestion would be to just take some short exposures in RGB and combine them. Obviously you would need to register them so everything is aligned but when you go starless just use these RGB color stars for the recombination of your starless and stars layer. There are many ways to add more color to your stars but my favorite way is to pull a luminance on the combined RGB star layer and add it back in LRGB combination and bump up the saturation to say around .38 an add it back a few times. You’ll need to play with it to find that happy medium for your star color.
All this said as I mentioned in the beginning, this is a very nice start, I think you could do better if you map your colors/channel a bit better.
This is just my 2 cents.
Good luck but have fun!
Dale
For astro photography I like to stay below half the wight capacity of the mount. Also ZWO recommends a max focal length of 1,000mm and I'm right at that point. Overall guiding is not bad with counterweight. I also found it useful to balance the scope as much as possible to improve guideing.
Concise
Thank you all. I agree that more integration time would add to the image. I usually try to get at least two nights worth and ideally three if weather and time permits. With the channel separation, I have to come clean. I've been using some Pixel math in Pixinsight from James Lamb: https://www.youtube.com/watch?v=YGMRn-fMVV8. I see now that I'll either have to try to mess with the pixel math or use a different method to pull out more contrast. I will also try HOO and see what results I can get.
I did put a lot of work into RGB stars on my last target https://astrob.in/ov0fhi/0/. I think I'll have to add more RGB time to my SHO images. For those of you that do RGB stars how much time do you dedicate to just the stars?
@Dale Penkala  I saw your image just before choosing this target for the new moon and it inspired me to go for the crescent over some other targets I was considering.
Thanks again
Andrew
NeilM avatar
Andrew Topper:
ah, got it!  I run my HEQ5 (currently for sale) at about 75-80% of the weight capacity for astrophotography but I understand that lower is better, especially with a long telescope.
Did some research and found the Foraxx Palette script. I've applied that palette to my data and updated the image:
Cresent Nebula
I think this addresses my channel problem and even gave some color to the stars. Not sure I'm not 100% done yet but headed in a better direction.
Dale Penkala avatar
Andrew Topper:
Thanks again
Andrew
I’m glad you liked my image enough to give it a go.
As for stars Andrew, if your just going to use strictly stars in the past I’ve gotten away with just 30-45 minutes worth of integration time but when I do stars I like to get between 1-2 hrs worth of data. Usually you can get pretty clean stars with that amount of data. Keep in mind I’m shooting OSC so its a quick and easy processing step for me to get them.
I look forward to your next revision on this image!
Dale
Helpful Respectful Supportive
Richard Carande avatar
Nice – but I think the framing could be improved so that you got the entire Soap Bubble PN in there.  In this image you get just about half of it on the left edge.  I always look for the Soap Bubble in Crescent N. images.  It's quite subtle.
Well written Concise
Brian Diaz avatar
Andrew Topper:
Thanks in advance.
hi
my recommendation is about the  bias frames ( avoid it )
   try , flats , dark flats and darks for zwo 2600. 6200, 2400
CS, Brian
First image with new Edge 9.25 scope reveals possible discovery.... Can i get peoples opinions please
Hi guys, i’ve just processed my first image using my new edge 9.25 hd scope. Given that it is not a very eye catching image i don’t think many people are going to view it, but i would really like some input/opinions on my possible discovery. It is no...
Similar scope feedback; author seeking input on new equipment performance.
Jan 14, 2026
Round stars using a guidescope at 1000mm - possible?
Hi All, I recently bought a ZWO FF130 to supplement my great little FF65. Normally with the smaller scope I’ve been getting good guiding with the ZWO 30F4/ASI120mm combo of between 0.5”—0.8” RMS. This is all sitting on an AM5N/TC40 (with weights in t...
Directly relevant; discusses FF130 scope guiding and image quality issues.
Feb 5, 2026
Crescent Nebula raw data available for processing - 21 hours collected
Hello all, The time has come again to offer up some of my raw image data for anyone to process if you’re up for it, specifically my 2025 acquisition of the Crescent Nebula in Cygnus. I captured this in a relatively narrow FOV with my Celestron C6 sco...
Same target (Crescent Nebula); raw data processing experience applicable.
Jan 7, 2026
