Diego Pacchiani avatar
Hi I would like to know if anyone has this configuration and if it works well. Specially with the weight limit of the HEQ5.
I am looking to buy both as my first setup for astrophotography, but that can evolve in a more complex setup by adding autoguiding etc.
Thanks for the responses 🙏
Stefano Annarumi avatar
Hi Diego, I started in February 2023 with 200 Pds and a HEQ5. In October I changed the HEQ5 with an AZEQ6, more stable.
As long as you do visual, the combo 200pds+HEQ5 is good. If you want to go for astrophotography, you start adding weight to a very borderline setup.
My suggestion: go for another mount or another OTA (but the 200/1000 is great).
Ask me more for more details
Cieli sereni
Ciao
Helpful Concise Supportive
Michael Zinke avatar
Hi Diego!
I used this setup in the past…and still sometimes using it. The answer depends on your targets I would say. For long-exposure deep-sky imaging: It's working yes (see my profile) but your guiding will most likely be not good. Also depending on the additional gear you will have attached and the wind strength (high surface area of the 200 PDS). Due to the (most probably) bad guiding or keeping the target in center of the field of view in general you will also lose sub frames…and thereby precious imaging time. So I would really not recommend it for that purpose. I would rather buy (at least) a EQ6-R Pro for the 200 PDS instead. For planetary imaging I personally would do that as a beginner and on a budget because you are anyways using high frame-rate planetary cameras (or e.g. fast DSLR shutter speeds). I don't know about your personal situation. As a beginner you may don't know if you want to stick to the hobby in the future…so maybe I wouldn't spend a fortune on the gear (and you could still perfectly use your HEQ5 with a smaller refractor for example). On the other side: If you already know that you want to stick to AP and also want to extend your gear in the future I would always consider (if in your budget) to buy gear (especially mount!) wich is "extendable" so I would choose a mount with a higher weight limit although you don't need it at the moment. I hope that helps a little. All the best and clear skies!
Christian Bennich avatar
I was also looking at that combo to start. For the reasons already mentioned, I went with the EQ6-R Pro.
That was a better choice, as I quickly found myself wanting to add more equipment etc. and the load would not have gone well with the smaller HEQ5.
I would argue that you will have more long term value spending a bit more on the mount, than e.g. on your first camera.
A lesser mount, will lead to more pain 😁👍
MCE_23 avatar
Hello Diego,
I started in Oktober with this Setup you mentioned. It is good for beginning, but you can expect that 30-50% of Images you take are trash, because of the inadequate Mount. It is working and you can take nice looking pictures.
My recommendation is, that you chose another mount. If you are slightly mobile with the setup (so if you don’t have an observatory where the Teleskope can stand 24/7) my advise is to NOT chose an EQ6 or similar. The HEQ5 is heavy (15 kg Mount + 15kg Counterweights). I guess the EQ6 even more.
i chose a harmonic mount, wich was nearly as expensive as the HEQ5 but can carry 20kg. At only 5 kg for the mount and 5kg counterweight.
There is a website or Discordserver from Proxisky where you can buy (if you feel confident go for the discordserver). Don’t buy the UMi17 lite for your 200PDS. I have an UMi17
greetings
Gabriel Wiklund avatar
I use the 200 PDS on a HEQ5 Pro unmodified and it works really well, i think it depends on the copy you get. I almost always get 0.5-0.8 RMS guiding in arc seconds and feel limited by the seeing not the mount.
While it may depend on the copy you get my local dealer actually recommends this combination for Astrophotography (many dealers sell them as a pair for imaging) and i know others who don't have any issues with this setup.
My Setup / Relevant Payload:
ZWO ASI 533 MC Pro
ZWO EAF Electronic Focuser
ZWO Off Axis Guider
ZWO ASI 120 MM Mini Guide Camera
Explore Scientific 2" HR Coma Corrector
 Total: 10.5 kg
So i would say, if you can comfortably afford the EQ6 or another mount with more payload capacity why not, but if the HEQ5 is what you can afford i would not worry about using it with the 200 PDS.
This guy takes fantastic images and even uses a 10" f/4 on the HEQ5: https://www.astrobin.com/users/sky-watcher/
Another thing to consider is that with todays sensor technology and the relatively fast optics of the 200 PDS the read noise is negligible when doing 60 second subs even in dark skies if you are doing broadband imaging.
Hi everyone,
Thanks for all of your answers, I now have a better idea of this setup. Given the fact that I’m only 16 I have a quite tight budget.
After seeing what images some of you have in their profile, I think that a least for the start, I will try this combination. Also giving me the time to learn everything I need to know in this passion. I would probably take the NEQ6 or EQ6 mount later, when it would be really necessary.
Thank you all again for your answers and clear skies to everyone !
Respectful
Hey Diego, you missed to mention you are only 16.
In this case, 200PDS + HEQ5 is a perfect combo to start growing and learning this exciting hobby.
I think that it is really important to leave some space for growing, also in term of upgrades.
Enjoy it! Looking forward to see some astrophoto from you
Ciao!
Supportive
Arny avatar
Hi Diego,
I started with the same combination of 200PDS and HEQ5 aiming for astrofotography from the beginning.
It did work, BUT
- my first HEQ5 went straight back and I got an exchange as the mount drive would stop working with no clear pattern (so apparently there are good and bad new ones)
- supplying a 7 Amp power supply really was essential - at full slew speed it needs all the amps
- the power plug tends to drop too easliy out of the socket, especially when there is the slightest tension on the wire - really sucks as you start over entirely
- over time with growing image trains weight did become more of an issue and I kept adding weights which then overload the mount, especially with long newtonians
- the moving RA + Dec parts tend to get loose and need to be retightened once in a while. If you overtighten it makes horrible noises killing its gears
- overall the mount and hand control appears a bit aged and looks like from the 90s/00s - but is sturdy & solid
Bottom line: I did get a solid work horse for good money - but I have wished more than once I would have gone straight to the EQ6 - if you have the money, it is well spend on a mount which is ahead of your ambition. But if you want to find out how deep ou want to go, the combi is a great and proven starting point.
Arny
Helpful Respectful Engaging
FilippoTib avatar
Hi, I hope I am not bothering by inserting myself in this thread by relaunching Diego Pacchiani's question.
Still talking about Heq5s and Newtonians, up to what diameter are Quattro instruments usable for astrophotography?
200/800 or is that already too much?  Because if I remember correctly, the weight of the instrument is similar to that of the 200PDS in the original question, but we are still talking about 200mm less focal length.
Thank you very much and sorry again!
Respectful
Wim van Berlo avatar
The longer and wider the tube, the more it will catch the wind. So why the 200pds? A 150pds is shorter and not as wide. It will be less if a sail in the wind, while the focal length idn’t that much less. Besides, a shorter focal length gives a wider view ( good for nebulae) and a somewhat coarser pixel scale, which is more forgiving for tracking. Plus a lower weight for this mount.
Discusses mount selection and configuration for astrophotography setups.
27 days ago
Fornax LighTrack II setup advice
Hello all, I bought a Fornax LighTrack II used for about 370€. It's just the tracking arm so that gave me room to improvise how I would like to have my rig set up and I've come to this final configuration. However, I am very open to any suggestions. ...
Addresses tracker setup and weight considerations for astrophotography equipment.
Jan 10, 2026
action cam on a star tracker
Hi all. I’m planning to buy an action cam not for astro use, but I know that I will eventually try to experiment with it on the night sky. I am thinking of something modern such as the DJI Osmo Action 5, or the Insta350 Ace Pro 2. They both have a re...
Explores beginner-friendly star tracker options for astrophotography experimentation.
8 days ago
