Mount stops tracking around 23 degrees altitude
2 replies119 views
Jerry Gerber avatar
Hello,
The 10MicronGM1000 mount was tracking (unguided) flawlessly until the target, M20, reached around 23 degrees in altitude in the southern sky.  The first 75 subs looked fine, the last two looked like this:
My model altitude limits were set  to 80 degrees through to 30 degrees.  Could that be why the tracking failure occurred?
Or is there a tracking limit in the mount's settings somewhere I can set?  23 degrees wasn't that low on the horizon, yet NINA's error message said the object is too close to the horizon to track.
Anyone have similar experience?
Jerry
First, 23 deg is considered very low, more so at your image scale and yes, programs and mounts can be set to stop tracking once they reached a given altitude, generally 30deg but it could be lower. Mine have none so they can track at any altitude (and correct for refraction).
Jerry Gerber avatar
The mount is set to stop tracking below 25 degrees altitude.  Problem solved.
Mini PC crashing caused scope to hit mount
Looking for some help/advice please, on how to understand what caused my mini pc to crash & also how to stop the mount continuing to drive in the event of a pc hanging-up.. Following a recent imaging session I awoke to find my mount (an EQ6-R) ha...
Mount tracking failure investigation relevant to similar GM1000 issue.
28 days ago
Fairly Cold Weather (15 degree Fahrenheit) and Tracking
When the temperature drops to 15F or lower, can tracking be affected? I have a 10Micron GM1000 mount and the stars are looking slightly oval on some subs while others look fine. If temperature is a factor, is there anything to be done with the mount ...
Environmental factors affecting tracking performance on same mount model.
Jan 13, 2026
EQ6R-Pro disaster
Hey all, Last night I had a big issue with the system while it was imaging overnight. (EQ6R-Pro, ASIAIR plus, 150PDS, ASI120 mini guidescope) From looking at the log, guiding was great throughout the night (0.6RMS average) until suddenly the RA went ...
Mount system failure during imaging; troubleshooting approach applicable here.
Sep 23, 2025
