Asi585//PDS150
6 replies224 views
Orfanidisharis avatar
Good morning,I have an issue with focusing and I am really struggling with it.i have checked the backfocus,I have tested the camera with the extra spacers but always my focus is a bit off.
also I have collimate my telescope and the laser seems to be ok.
what is happening?any guess?
(also I use comma corrector.)
The question is a bit too generic. Give examples (images) and also state whether you can't reach focus or it's a question of quality of focus at best focus. Also, please, state what backspacing are you using and what coma corrector. Then we might be able to help.
I use the SW 1.0X2" comma corrector
the backspacing that i measure is 55mm (from the flange of comma corrector until the sensor of the camera )
the focus it’s barely ok,if you see the stars I think that are big enough
There might an issue with collimation, more evident in the Crescent Nebula shot but otherwise I can't see anything obviously wrong with the focus, other than you might been having poor seeing. Try to shot the NP (Polaris) without tracking taking 5s integration and trying to achieve as tight stars as you can, assuming you are focusing manually. Then we'll see what, if any, are the issues with focus.
Helpful Concise Supportive
Thank you my friend.I will try again
donsinger avatar
The triangular star shapes in the Crescent shot looks like pinched optics-I would loosen the primary mirror clips a tad….just enough to get a piece of paper undet
Don
I searched about it and indeed I have the same "egg shape" stars.
i will sit down today to give a try
i have to say,that I am scared of untightened  the primary mirror…but I will do what I must
thank you in advance!
Focus Issue with OIII filter on edgeHD 8
Hello, I recently acquired a 533 mono camera and have been collecting some test shots weather permitting. I use Zwo Eaf for focusing. With the Luminance filter the focus point was very close to my previous configuration (osc camera + cls filter). Las...
Focus issue with filter; author uses coma corrector and tests focus like your setup.
Aug 12, 2025
