Rick Krejci avatar
I struggled processing this one a bit.    Early versions had too much green (Ha).   Too saturated.   Should I just do HOO?
I came across thistutorial, which is more Photoshop oriented with extensive use of layering and really found it enlightening and much more flexible than doing most of my processing in Pixinsight (especially being new to Pixinsight).   The nice thing is that none of the adjustments are descructive, so I can go back and adjust each layer until I'm happy.
I followed my normal Pixinsight process for this small refractor (Zwo FF65):
WBPP with darks only (flats not really needed)
To generate star screen only:
   Color Combine of SHO masters
   Spectrophotometric Color Calibration in Narrowband mode optimize for stars
   Blur Xterminator (0.2 Star, 0.27 Halo)
   Star Xterminator (generate star screen)
   Screen Transfer Function - stretch star image.
   Save star screen as TIF
To generate stretched starless nebula S, H and O images:
   Star Xterminator on the S, H and O masters, no star screen needed
   Blur Xterminator (0.6 nonstellar)
   Screen Transfer Function - stretch S, H and O starless masters so histograms are similar.
   Save S. H and O stretched images as TIF.
From that point I generally followed the linked PS tutorial above:
   Loaded the S, O, H and Stars into layers from bottom to top, putting each into their own adjustment group with levels and curves for each group.
   Set S to Red channel only
   Set O to G and B channels.  Pull G down about 1/3-1/2 of the way down the right side in curves for the O group give it a more balanced blue rather than deep royal blue
   Set H to all channels but pull Red and Blue down to at or near zero on the right side in curves for the H group so it will be primarily Green.
   Adjust levels and curves for each, S, H, O and Stars to bring background in balance and a good balance of the colors.
   Create a curves and color balance layer over all the SHO layers and tweak as desired
   Set Stars as the top layer and set to Screen
   Run NoiseXterminator in PS to keep some noise in the background but make it less noticeable.
Overall, I like that you can pick out each narrowband in some areas including the faint green Ha ring on the east portion as well as an Oiii red background glow west of the west veil portion.  But I've not found a lot of other SHO veil examples that look similar
Any comments or critiques would be appreciated
Lynn K avatar
HOO works great on the Veil.   There is very clear distinction between the Ha and OIII regions in the Veil. That's what makes the Veil so nice to process in HOO.  I think adding the SII signal and assigning Ha to green, just complicates things.
Lynn K.
Rick Krejci avatar
Lynn K:
Lynn K.
Thanks for the reply, Lynn!   While I generally agree, as I processed this image more, I came to appreciate the subtleties the Sii signal added
I did a HOO higher resolution image with my Quattro 250P (West Veil - Witch's Broom - NGC 6960 (Rick Krejci) - AstroBin) and did like the clear interplay between the H and Oiii, but when I did HOO processing of this widefield one, I found it not quite as interesting.    But it still bothers me a little not to have Ha mapped to red though.
This is my first experience with an Oiii filter, so still learning the ropes.
Thanks again!
Rick K
Respectful Supportive
Dale Penkala avatar
Rick Krejci:
Hey buddy, glad to see you on here! Followed you and look forward to seeing you images Rick!
As for your post, I’m far from a pro here but I’ve never been a fan of the SHO versions of the Veil but they are interesting to look at. I’ve always done mine in HOO and that is actually several years ago back when I was kinda playing around with AP.
This is strictly a personal thing, but whenever I do an SHO/HSO I prefer to use RGB stars instead of the NB stars that come from the SPCC. They come out ok but I just prefer the RGB stars for my star layer. Again this is a personal thing however.
Anyway great to see you on here buddy!
Dale
Rick Krejci avatar
Dale Penkala:
Thanks, Dale!   After almost 20 years away from the hobby, I had to dust off some cobwebs, but I'm having fun enjoying all the advances since the early 2000s.
Yea, I probably should have put the exposure time into more Oii and Ha, but wanted to give it a go.
I agree with you on the RGB stars for sure.   The Zwo filters are wider pass than what I was used to years ago so there were more stars than I expected so I just went with it.   That said, the stars turned out better than expected for narrowband imaging.
Dale Penkala avatar
Rick Krejci:
Dale Penkala:
Yes, agreed! So much has changed since then!
I actually forgot that your shooting mono so things are a bit different in my case I shoot all OSC so my processing is different from you.
Looking forward to seeing your work Rick!
Dale
Dan Kearl avatar
I am not a big fan of SHO for this nebula and  the green is a bit off putting for me but colors are subjective.
I also own the 2600mm and I am curious about your statement that Flats are not needed.
The general consensus of that camera is that Darks are not needed although I use them but Flats calibrated with dark flats  I feel are totally necessary with all cameras.
Rick Krejci avatar
Dan Kearl:
Thanks for the feedback...completely understand your comment on the colors especially the Ha green areas, since green is not normally a color one sees in a DSO image.    My goal was to try to differentiate the various wavelengths, particularly Ha and Sii.
I took flats and processed this image with found my imperfect flats introduced a gradient.    So I processed without flats the images looked nearly identical except no gradient.   The FF65 with the .25 flattener/reducer produces a very flat field.     I absolutely do need flats with my Quattro 250p
When I do flats, I just use a master bias rather than dark flats.   The main reason for a dark flat is to remove the bias/pedestal so it will mathematically work correctly. It's not to remove the dark noise since the exposures are short and light completely swamps any dark noise which is negligible to begin with as you said.  A bias frame does that without having to worry about matching exposure time/temp of flat frames or ensuring there are no light leaks, especially since I use auto exposure for my flats.
I used to not use darks for DSO imaging, but they are so easy to take and reuse for months that there's little reason for me not to use them, even if the improvement is minimal.
Thanks again for the feedback!
Rick Krejci avatar
I tried something a little different with the image to avoid the green areas.     I basically processed it as HOO, but then added the Sii image into the green channel.   So still have the familiar red Ha, the Cyan Oiii but brought in the oranges of the Sii, so H(SO)O.    Not traditional, but I do like the look overall, a little richer than the HOO and still differentiates the Ha dominant red areas.    Comments/suggestions welcome!
Veil Complex in H(SO)O Palette
Dan Kearl avatar
I would back off the magenta a tad but otherwise a big improvement for me..
Nice work!
Jonathan H avatar
I landed at a similar pallet when doing this region in SHO. I was just processing in PI thought. What attracted me to it originally, was the Hubble image.  I think your capture looks awesome.
The Veil Nebula Complex in SHO
Rick Krejci avatar
Dan Kearl:
Nice work!
Backed the Magenta on the stars and did a final color tweak.   I'm pretty satisfied with it ( until I'm not again )
Best way to stretch an Image in Pixinsight
Hey guys, i am new to pixinsight and only processed a few pictures with it until now. one thing i don’t fully get is. what is the best way to stretch an image in pixinsight? until now i only ever used the stretch of the screen transfer function for m...
Discusses image stretching techniques and saturation issues in PixInsight processing.
Dec 21, 2022
Processing Tip for Balancing Narrowband Channels for Custom Blends in Pixinsight
I'd like to offer up a processing tip for achieving better balance with narrowband channels for SHO or custom blend imaging. I use pixinsight, so the steps I describe are PI based, but the concept may be applicable to other processing suites. &md...
Author discusses SHO processing challenges; candidate shows similar narrowband balance struggles.
Aug 15, 2022
Did Mars ruin my image
I was imaging the spaghetti Nebula for the night and Mars was close by which made locating the Nebula super easy. However during post processing I had to stretch the image by alot. The nebula was able to pop out but since mars was also close by I thi...
Addresses nebula processing challenges including brightness and stretching techniques.
Nov 22, 2022
Looking for help on SHO processing
Below is my first serious attempt at SHO processing. This is The Bubble nebula, 4.5 hrs total integration using 7nm Ha, Sii and Oiii filters in a Bortle 5 zone. I'm looking for feedback on: * Colour pallette .. I used 40% straight SHO mixed with ...
Addresses SHO processing challenges including color palette and green saturation issues.
Aug 9, 2022
[RCC] Galaxy post processing M101
Request you to provide your critique - It is my first attempt to post-process galaxy data. I obtained the data from TAIC workshop. The LRGB subs were already stacked and registered, even cropped to good extent. I proceeded with these steps, providing...
Direct example of galaxy post-processing workflow similar to your M101 processing experience.
Aug 19, 2025
