Just Checking, is that dew?
2 replies231 views
AstRobert avatar
Unexpectedly yesterday night cleared up and I tossed out all my stuff and started a session. I stayd with it for the 5 pics before the Meridian flip as I wanted to observe and test it for the first time with NINA. Then I left everything to image throughout the short summer nights. i i found that every image after the flip and even one before looks like this:
Is that dew? And if, WHERE???
Because I had the dew heater running on full power, at least I thought.
The build up in the images is rather quick and it stays, so it is not going completely in. Also I am usually used to dew forming in the center and creping outwards and I looked on the lense during the meridian flip wait time and it was totally clear, but even one picture before that showed this.
Any suggestions or other explanations.
One alternative i have is, that it is dew on the camera shield as I though it would be a good idea to cool down to -20 and not jsut -10. and had the camera dew heater only set to 1 of 4? :-(
Cheers, Robert
It's condensation on the sensor. Run it at 0  and then after a while you might move it -10. If your integrations are less than 5 min isn't really worth doing though, at least with modern CMOS. Window's dew heater is essentially pointless in summer.
jmdl101 avatar
Funny enough the exact same thing happened to me last night. A little after midnight that dark oak started growing and I lost 4 hours of exposures. It's definitely dew or fog on your sensor window. I had my camera dew heater at half power because I have never had an issue before. After putting it on full power the oval faded and disappeared after about 10 minutes.
Well written Helpful Insightful Respectful Concise Engaging Supportive Perfect post
Star Elongation following Meridian Flip
I recently replaced my Stellarvue 80mm with a Tak FSQ85 EDX on top of my C11" EdgeHD. All is working fine as before except for one thing. I am getting elongated stars on the first 5-minute frame following meridian flip. It then settles down for ...
Mentions meridian flip timing; may contain relevant settling or focus insights.
Sep 23, 2022
Hom many people use auto meridian flip?
I've used auto meridian flip in NINA for my last couple of sessions. It has worked quite well with the slew and centre after flip option selected. How many of you out there trust NINA to flip the scope whilst you are asleep?
Meridian flip procedures and timing relevant to automation trust.
Sep 1, 2022
My ASI6200mm is acting up again
I had an issue last night in that a perfectly round black dot appeared on individual frames hours after the ASI6200mm had been running at its usual settings: 100 gain at -5 degrees with the dew heater on. It did not look like the oval-shape black dot...
Sensor defects can cause image artifacts; check if issue is hardware-related.
Mar 24, 2026
Secondary mirror coating issue or possible light leak problem?
I was considering sending my secondary for my ago idk 14.5" over to terry at ostahowski optics for a recoat because if I look closely enough, I have what looks like an oil spot or something that slightly dulled a small part of my secondary coating th...
Light leaks or optical issues can cause image degradation after meridian flip.
Nov 3, 2025
