Mossyback avatar
I don’t know if this is a TSX problem, a N.I.N.A. problem or something with my MtY. I don’t understand the error message so hopefully someone here can help me out. This message came up when I was connecting my equipment in N.I.N.A.
ASCOM Driver Error. Unable to connect to ASCOM telescope Driver for the Sky. Reason: Object reference not set to an instance of an object.
As usual, everything was running smoothly until it wasn’t. What do I have to do to fix this?
BTW, I ran ASCOM diagnostics and everything is fine.
Hank
Reid Smythe avatar
Hopefully you've fixed the issue.  Assuming you had everything working before, this looks to me like some kind of error popped up in your configuration.  For some reason, NINA did not (or could not) instantiate the driver object.  A reboot would be the easiest way to try to fix the situation, or you could just close everything out and ensure all ASCOM and NINA processes are killed using task manager.  If the problem keeps popping up, I would consider uninstalling the ASCOM SkyX driver  (if there's a convenient way to do that), using ASCOM Profile Explorer to delete the entry in the Telescopes section, then reinstall the driver.
You could also try doing putting a bandaid on the issue by connecting the driver in device hub, then connecting NINA to device hub (or you can get a similar effect using ASCOM Remote).  If Device Hub fails to connect to the driver, it is likely that your driver will need to be reinstalled.  Taking a look at the NINA logs may provide additional indication of why things failed.
csummers avatar
I had a similar weird issue with a zwo camera and the Ascom drivers.  I stumbled across deleting the ascom log files and that fixed it.
Help Need for Message
I’m using N.I.N.A. with a SB MtY mount. My target was NGC 6888 and I sent it to the Framing window and it looked fine. However, when I clicked “slew” nothing happened and I got the following message. “ASCOM Driver Error - Object Reference Not Set To ...
ASCOM driver connection issue with N.I.N.A. and telescope mount equipment.
Oct 13, 2025
Paramount MYT + Nina + PHD2 guiding issues
Hey folks, quick question for anyone running a Paramount MYT with NINA and PHD2. My Paramount is doing my head in. Everything is set up correctly as far as I can tell, SkyX, ASCOM, all that. But every now and then PHD2 throws up the error “your mount...
Paramount MYT mount compatibility with N.I.N.A. software and troubleshooting.
Nov 27, 2025
Looking for Camera and Filter Wheel Recommendations
The biggest problems I have running NINA at home or at a remote observatory is 1) camera connectivity to NINA, and 2) the filter wheel getting stuck on one filter. When running at the remote site, I always have to make sure that the camera cools and ...
Camera and filter wheel connectivity problems when using N.I.N.A. software.
Oct 31, 2025
What do you do when PHD2 sees ghosts?
I have been chasing a problem in my guiding for several hours yesterday night and tonight. I use an OAG with a SCT (C8); PHD2 (managed by NINA) is the brain. The experienced problem was that, for a specific target, guiding would work well “in most ca...
N.I.N.A. integration with PHD2 guiding and equipment connection issues.
