13028HNT Collimation
4 replies489 views
Armin Lukas avatar
I recently purchased the OCAL for collimation for my Sharpstar 13028. During collimation I noticed I can not get the secondary mirror a perfect sircle while maintaining a concentric circle of the reflection of the primary mirror. The secondary mirror keeps being an oval shape.
Is there a way to fix this?
Can the collimation be improved? Or is there anything i missed?
Reg Pratt avatar
As long as the reflection of the primary mirror is fully visible and centered under the focuser you're fine. Your collimation looks good you just need to tip the secondary slightly. As an added check you can make another circle and size it to be a little smaller than the body of the OCAL inside the focuser. If that is also concentric you're good to go. If it isn't, your primary mirror spot may not be placed well and won't be a good reference to use for collimation.
Helpful Concise Supportive
Esteban Pineda avatar
Thats because your secondary is oblicuous. It's well centered with your focuser and primary mirror, but you'll get distorted images on 2 corners.
Leonardo Landi avatar
As far as I know, the illuminated circle in newt scopes matches the primary mirror reflection. So if it's well centered and fully visible in the focuser tube, you will be ok. Please do not use the center mark to center it, but use the OCAL body. Create a new circle a little bit larger or smaller and collimate the primary mirror with it. If you read the OCAL manual, they discourage the use of the "eye" of thecamera too, because it's not precisely centered with the body (that's why you need calibration codes). I found several scopes with uncentered mark. In SW scopes they missed the right spot by 7-10mm.
Andy avatar
Struggling with this now with my 130hnt. What does a star test look like ?
My littte bad weather project: Sharpstar 13028HNT modification
Due to bad weather in Germany, I wanted to do some modifications to my Sharpstar 13028HNT. I’d like to share my first experiences with these modifications, though there is still more to do. A few things I wanted to try:Create a new mirror mask (notch...
Author owns same telescope model; modifications may address collimation issues.
Dec 12, 2025
ONTC Tube Foam Sandwich Compression and Solution
I’ve been using a 10” TS Optics ONTC Newtonian as my primary imaging scope for a few years now. Overall it’s a great scope and I’ve been very pleased with its performance. It is, however, not without some issues. One issue which has plagued me from d...
Discusses Newtonian collimation and tube issues relevant to similar scopes.
Oct 22, 2025
Optimized Newtonian - Is it worth it?
There are a lot of ways I can think of that the current crop of Newtonian Astrographs can be improved. Lets restrict the conversation to apertures between 6 and 10 inches. 1.) Lowering the focal plane relative to the side of the tube (eliminate the f...
Explores Newtonian improvements; collimation optimization likely discussed.
Jul 28, 2025
OOUK ODK10 mirror spacing & corrector placement
Hello, I acquired an ODK10 from an German Observatory for a very good price and received it today. It’s used and has seen better days, but I want to see if I can make it work. Mechanically it looks OK and the Observatory fixed the weird unstable cork...
Addresses mirror spacing and alignment in Newtonian telescopes.
Dec 23, 2025
