Celestron Smart DewHeater Controller & Streaking Stars
4 replies115 views
Sky Story avatar
I am presently using a simple variable voltage power supply to control my Celestron dew ring on my SCT. Set to minimum, about 3.5V, it works pretty well through the night though just at dawn when the temperature rapidly shifts I often accumulate a little dew on the corrector so a couple hours before dawn I turn up the voltage to about 6V.  I was thinking about getting the Celestron Smart DewHeater Controller to manage the dew ring through the night.  However, I have been concerned about the stars developing streaking from the corrector becoming too warm.  Some persons have reported issues with the Celestron Smart DewHeater Controller causing streaking due to poor power management, slightly overheating the corrector which leads to streaked stars.
If you are using the Celestron Smart DewHeater Controller, I was wondering what your experience with it is.  Do you find streaks in your stars since using it?
Scott Schneider avatar
I have the smart dew heater and yes if you have the heater set too high it will indeed produce little spikes on your stars.  However, if you keep the temp set to around 15-20% I haven't had any issue.
~Scott
Sky Story avatar
Scott Schneider:
~Scott
Does it work well without streaks in automatic mode?
I tried setting it on auto with different values from 5 down to 1.  At 5 it almost always would streak, but when at 1 or 2 it was only occasionally (once or twice out of 10 times), but randomly so.  Then about 6-8 months ago I just set it manually to 18% I think is where I have it right now, and haven't had any streaks since.  Where I live we get a lot of dew all year round, so I use it all the time.
~Scott
John Hayes avatar
Where are you putting the heater strap?  I've never seen "streaking" on any of my C14s.  That makes me think that you are applying WAY too much heat.  Do you have a dew shield or any other dew prevention strategies?
The single most effective way to protect a SCT from dew is to use a dew shield and to heat the shield itself.  For that reason, I really like metal dew shields because metal is better at conducting the heat to the inside of the shield where you need it.  It is easy to show that a dew shield that is just 1.5 times as long as the aperture of the telescope will block 90% of the heat exchange with the sky compared to using no shield.  If the conditions are pretty wet, that still might not enough to prevent dew; however by raising the temperature of the shield by just 2.2C, you'll replace the heat lost to the sky and eliminate the possibility of dew on the front of the plate.  It's best to put the heating strap about 1/3 of the way from the top of the shield.  I've attached some data plots so that you can see how things vary with dew shield aspect ratio.  Obviously longer dew shields are more effective but they are also MUCH more susceptible to wind.
Even with a dew shield, you can still get condensation inside of the tube simply because of radiative heat loss between the tube and the sky.  You can address that problem passively by wrapping the tube in Reflectix, which you can buy at your local hardware store.  Again if your conditions are really wet, you can add another heater strap about 3-5" behind the corrector, under the Refectix to insure that the temperature inside the tube does not drop below ambient.  Again, that does not require much heat.
The Celestron smart controller is a rare product that does the right thing to prevent dew.  It measures the actual temperature-dew point spread and only applies heat when the spread is below a preset threshold.  The dew buster controller doesn't do that, but it includes the ability to actually measure how much you are heating the components so it's easy to set it to only allow a 2C temperature rise on the dew shield (for example).  Years ago I built my own controller to measure the temperature-dew point spread and switch on a Dew Buster when it was needed.  I ran that system in New Mexico under pretty wet dew conditions and never once had dew condense on the corrector or inside the tube.  Whenever you apply heat, you will generate thermals but in my system it looked like nothing worse than a small degradation in seeing.  You just have to be careful to use the smallest amount of heat needed and no more.
Here's a plot showing the amount of heat exchange as a function of dew shield aspect ratio
Here are the results of a calculation to determine how much you have to raise the temperature of a dew shield to perfectly balance heat loss to the sky.
One dew solution that may not be for everyone.
I live in coastal Southern California and I have always struggled with dew prevention on my 10” DIY newt… I’ve tried dewshields, dew heaters, burning sage, shamans, you name it. Dewshields are ungainly and huge. Dew heaters would generally overheat t...
Discusses alternative dew prevention methods beyond heaters for comparison.
Nov 28, 2025
Dew shield modification: painted and insulated, but concerned about reflections
Some time back, a user here (I can’t recall his name, sorry) posted his physics lecture on dew shields and how to best utilize them. The recommendation was that flocking is bad, you should paint the inside of your dew shield and wrap it in insulation...
Addresses dew shield physics and optimization relevant to dew management.
Mar 18, 2026
