FSQ-85 vs FSQ-106 are these a big different for AP ?
10 replies696 views
Ice_cream avatar
Hi, i just wanna ask this, for astro imaging is this a big different between FSQ-85 and a FSQ-106 ? the price to take the FSQ-106, i could take a FSQ-85 and a TSA 120, i just want to ask is it relly worth to buy an FSQ-106 ? and if i buy a FSQ-85, should i buy any more adapter to connect my female M42 ZWO 533 ?
Nadir Astro avatar
The biggest advantage of FSQ-106 over Baby-Q is the huge declared 88mm corrected field. While it was designed for larger pixel cameras, it still shows pinpoint stars even on a modern small pixel full-frame sensors like IMX455. (though 1.01x flattner on 85 is also nice) Also variety of focal reducers, including 645QE and F/3, are available only for FSQ-106, not 85.
Other than that it's basically just another 21mm of aperture.
Björn Arnold avatar
Hello,
Hi, i just wanna ask this...
The shortest questions often lead to the most complex answers  and mine is not even an answer but more a question: what do you want to achieve? From what you're writing, it seems you already have some equipment and don't start from scratch. What are you planning to change? Is it FOV? Do you "simply" want to upgrade to a higher quality optics? Which optics would match your current imaging hardware better.
CS!
Björn
It depends. 55% more aperture and longer focal length is nothing to sneeze at. In the end is just a matter of throwing more money at it…
Ice_cream avatar
i think an APS-C sensor size is enough for me :|
It depends. 55% more aperture and longer focal length is nothing to sneeze at. In the end is just a matter of throwing more money at it...
yeah, you r right
Robert Gillette avatar
The FSQ-85 in my experience is a wonderful wide-field scope with superb optics.  It's also readily airline transportable, if that matters.  I once took mine to Chile for a week of imaging.
CS,  Bob
Well Written Concise
Tom Dinneen avatar
If you are going to use a 3.76um sensor with the FSQ-85 then you will have to use the flattener with it. That’s irrespective of sensor size. In my mind that negates the whole Petzval design that you are back having to get your backfocus exact. The flattener does work quite well though up to ASP-C at least. Not tried it with a full frame but I expect full frame and small pixel won’t work well together. Optically the FSQ-106 is in a deferent league in my opinion. The FSQ-85 is not a scaled down version. I'm hopeful that Takahashi will update the reducer at some stage for it to work better with small pixel sensors.
Helpful Insightful Respectful
Bob Lockwood avatar
I think if you are planning to get one or the other, just get the FSQ-106. If you buy the FSQ-85 you'll end up selling it down the line.
The FSQ-106 will handle any chip you put behind it.
Tareq Abdulla avatar
Looking at your AB gallery i see that you already have FSQ106 and also 130NFB, so why you are thinking about FSQ85 or 106 again? You should get a reducer for that 106 and you will be kicking …
Ice_cream avatar
Tareq Abdulla:
Looking at your AB gallery i see that you already have FSQ106 and also 130NFB, so why you are thinking about FSQ85 or 106 again? You should get a reducer for that 106 and you will be kicking ...
I asked before i bought them, actualy i bought all of them, fsq-85 fsq-106 and toa-130nfb, just sold fsq-85 for my friend
Tareq Abdulla:
Ah ok, it was an old question then, i didn't check out the starting date, thank you and luck you
Which long(ish) FL scope would you recommend for me?
Hi guys, I've been imaging for 6 years now and am happily continuing to do so. I would consider myself very experienced (with the gear I have). You can find that in the description. Very happy with my Esprit 100 / ASI294 combo For many years I...
Comparing telescope options for astrophotography imaging needs and budgets.
Sep 22, 2022
Advice me for next equipment plan
I want to plan wisely for a serious next purchase so i don't regret and i can calm down and stop buying more for a while, so i am not sure how it should be if it was you. Let's assume you have about $5000 maximum, which one of the following p...
Planning equipment purchases wisely to avoid regret and unnecessary spending.
Mar 20, 2023
Looking for advice (refractor-wise)
Hi guys! Since my budget is limited and I don't want to waste more money than necessary on this hobby at the current state I'm asking for your response and recommendations. I wish I could spend more money on a refractor, but because I need to...
Seeking refractor advice within budget constraints for astrophotography hobby.
Feb 3, 2023
