Crop settings for simulation on telescopious
2 replies149 views
Javier avatar
I currently have a modded Nikon D5300 but I am considering getting a ZWO ASI585MC Pro. Before that, I'm doing some simulations on Telescopious to compare with my current one, but I'm not sure if I should set the crop factor to 1x or if I should increase it (as the ZWO has a sensor smaller than a "full-frame" camera).
What would be the right setting for this?
Thanks!!
Javier
Well written
What cropping? None of the sort, you just enter the sensor info and you are set.
Javier avatar
Thanks @andrea tasselli
That's what I was suspecting, but I wasn't sure it would be the right setting. For my Nikon, apart from the sensor info, I also have to set up the cropping factor so I can have a very accurate simulation. If I leave the Cropping to 1x with that camera selected, the field of view on telescopious is larger than the actual one, hence my question.
Javier
Choosing a fullframe camera
Hi, I’m currently considering buying a fullframe camera, but I’m not entirely sure which one to choose yet. At the moment, the camera will be used with my Epsilon 160ED. However, I could also imagine adding a telescope with a shorter focal length (un...
Irrelevant - discusses fullframe camera selection, not crop factor or sensor comparison.
28 days ago
ASI294MM Fan No Longer Working
Hi everyone, I realised tonight that my ASi294MM (Pro) fan isn't working anymore (and might have been a while too, doh!). Brought indoor and after taking darks it felt quite warm at the touch and the darks (300s) were unusually noisy compared to ...
Irrelevant - addresses fan malfunction on different camera model, not crop factor settings.
Mar 23, 2026
