Lucky Imaging
7 replies398 views
Michel avatar
Context :
I came to Lucky Imaging given the poor quality of my site: Bortle 7, lots of turbulence, mediocre Seing
The Lucky Imagine has many advantages for me:
• We free ourselves from the breast with poses < 500ms
• We improve the resolution to -1” with exposures < 5s because it is less sensitive to turbulence. By posing very short we freeze the turbulence and eliminate small tracking defects.
• Simplicity of the photo process with the Shapcap stacking tool. No need for autoguiding up to 30”.
• Image stacking and alignment is automatic with SharpCap. The histogram stack function helps improve the brightness of dark areas of the image and improve the contrast in brighter areas of the image.
•  The most important: the pleasure because you can see the image forming live over the seconds.
• We can access 80% of interesting planetary nebulae and galaxies without problems. It’s trickier for the Nebulae.
• The surface brightness of the target is limited but I observe in my photos magnitudes greater than 17 in 15’
• You must set the Gain between 50% and 90% of the maximum gain in order to benefit from the lowest reading noise.
• With high gain it is preferable to add offset so as not to "eat" the very weak signals.
My uncertainties:
The recommendations explain that we must do Darks but that Offsets (Bias) and Flats (PLU) are not essential.
I'm not convinced:
1. Darks do not seem essential to me given that my camera (ASI533) produces only 0.0005 electrons/second/Pixel or 0.0015e/s/Pixel with an exposure of 3” and cooling of -10°C. (0.15e/s/Pixel with an exposure of 300’’, i.e. 100 times more electrons.
2. On the other hand, the reading noise of the camera (1e) with a Gain of 500 is not negligible / thermal noise (0.0015e) so it seems essential to me to do Offsets (Bias)
3. Regarding the Flats (PLU) I think that when in doubt you should do them.
Question: Can anyone advise me on DOF and share their experience in Lucky Imaging?
Salvatore Iovene avatar
I moved this topic to the Electronically-Assisted Astronomy (EAA), as I think it would be more relevant here. I hope that's alright!
Michel avatar
No problem
Exaxe avatar
It all depends on how you make your acquisitions: if you use 8b (gain >500ms) you have to do simple stacking in sum mode, so darks are mandatory (no offset, they are contained in the darks) . For flats, it depends on the size of your sensor, with my 290mm no flats, with the 533 flats. On the other hand, if your gain is lower than 500, 16b is (maybe to think about it) possible, so you can take the stacking mode with rejection. At this time no darks (let's say it's not obligatory), and offset possible.
Adam Drake avatar
Darks handle hot/stuck pixels as well as read noise.  I don't do EAA without darks for that reason alone.
Well Written Concise
Marc-Antonio Fischer avatar
Exaxe:
the god himself speaking. love you exaxe, your are the reason i start doing it XD no joke
Ive tried it several times, with and without success . My endboss was always this damn walking noisepattern, beacuse of the no dithered images. Ive tried the Sharpcap tool which works good, but not as good as Ive hoped so (because it often looses track or can align after the dither)
Michel avatar
Given my results I will take my next shots in lucky imaging with ScharpCap which works very well I have never had any tracking problem (Maybe look at the station setup).
I will integrate the DOFs into the Pre-Processing done with Pixinsight.
How important is experiencing the night sky to you astrophotographers?
Automated setups allow for imaging while taking care about other things. They allow us to "harvest" data without much of a connection to the night sky. I would be interested to hear how important it is to you to experience the night sky. &l...
Lucky imaging addresses poor observing conditions and image quality challenges.
Jun 5, 2022
What exposures should I be taking with my ASI1600MM Pro?
I live in a sububan area and take backyard photos. I'm shooting at unity gain on an old 1600MM Pro mono camera at -10 degrees. I'm curently taking exposures as follows with an F4.5 scope: Narrowband (7nm) 300 secs RGB 90 secs Lum 30 secs Give...
Lucky Imaging alternative for improving image quality in mediocre seeing conditions.
May 7, 2022
Large aperture planetary setup heavily underperforming for an unknown reason
So this Jupiter image i took recently, its somewhat decent i would say, but as im exploring this site i notice people getting far better results with significantly smaller telescopes and less data, makes me wonder what am i missing / doing wrong. For...
Author uses Lucky Imaging for poor seeing; underperformance diagnosis directly relevant.
Jan 20, 2026
Which imaging acquisition and processing techniques could I learn more about to increase image quality and accuracy?
Hello, I use a full-frame mirrorless camera, I mostly do daylight photography, some night photography and astrophotography too. I did hightlight in bold keywords to make it easier to scroll thru, for those that don't want to read most of my post. Bef...
Author seeks techniques to improve image quality; Lucky Imaging is one approach.
Dec 29, 2025
