If you step down even the 50mm AF-S 1.8G will perform admirably with a FF camera. Or if you can afford the thousands required for a top of the line Zeiss I'm sure it won't disappoint either but for the money I don't think the Nikon can be beaten.
*I have the 50 1.8G and it is not remotely close to being acceptable in image quality for astro, severe coma aside my D850 easily out resolves it, and it's electric diaphragm means I can't use it with my QHY367c even if it did have acceptable image quality. I have no issue shelling out thousands for a lens like the Zeiss, but there are at least half a dozen versions of it all with much different optical formulas, and if I'm paying that much I want to make sure I get the right version that's best suited to the task.
