Nick Grundy avatar
Does anyone recognize the issue I'm seeing here? I'm using a Redcat51, UV/IR filter, Daystar Quark Chromosphere, ASI432mm
I've used all of it except the asi432mm previously and never seen this concentric ring issue before
Newton's rings. You need to tilt slightly the sensor to see them disappear or get another sensor/camera.
Nick Grundy avatar
so I need to tilt the camera to remove the issue? (I think I heard of this before with the quark)
it sort of goes against every effort I've made in the past year though. smile
thanks, i'll try it
Yes. They sell a tilter unit for this camera.
Claudio Tenreiro avatar
Hi, Also I understand that the ZWO ASI432MM has a T2 tilter, exactly to reduce Newton rings, I wonder if you purchased as a set.
Best regards and CS!
Nick Grundy avatar
Claudio Tenreiro:
It did come with the adapter for this. I had just never needed with any other camera I’ve used with the daystar. Is there anything unique with the 432 that demands it?
Nick Grundy:
Claudio Tenreiro:
*I suppose that this camera is quite commonly used for the sun, and the problem with Newton rings is well known, particularly with the Quark. Daystar Filters do mention several times this issue and the needs for a tilter. The camera ASI432 is quite suited for the kind of images using the 4.2 Barlow (large pixel size) so I do believe they (ZWO) anticipated the problem and give you the tilter straight away.
Walter Leonhard Schramböck avatar
As mentioned: tilt it! Some just use tape or a piece of paper glued to one side of the 1.25" nose-piece to tilt the sensor.
And: making flats is getting more important when tilting the camera to minimize gradients.
Nick Grundy avatar
Is there a consensus on the best way to creat flats with the daystar? I’m guessing, but the only method I can think of is to defocus significantly while on target. How else can it be done? (Since I can’t generate my own flat field)
Nick Grundy:
I bought a diffusion-cap from daystar. You also can use something cheaper than this, something that is translucent but not clear. Or you defocus, but if you have massive dustparticles in your optical train this might not be the best way.
Player One Poseidon-C prominent star halos
Hello all! I've recently upgraded to an IMX571 camera from an old unmodded DSLR setup using a RedCat51 and have been quite happy with the first week of imaging. However, one issue that I haven't been able to mitigate is the presence of prominent star...
RedCat51 user with similar optical setup experiencing image quality issues.
Dec 18, 2025
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Troubleshooting guide for mysterious optical artifacts affecting image quality.
Nov 18, 2025
Serious Stray Light Issue - William Optics UltraCat 56
I’m posting this to see if anyone else has experienced or can verify this problem in their UC 56 telescope. I received the telescope February 2, 2026 from Agena Astro. The quality control certificate that was enclosed was dated December 5, 2025. The ...
Optical issues with similar telescope setup requiring diagnostic investigation.
Mar 1, 2026
