Lunt accessories
2 replies62 views
deleted avatar
Can I use a Lunt Solar Systems ST 50/350 LS50THa/B400PT for photographing the sun with a Mono OSC or do I need something more to this telescope?
TIA
astro_rocketeer avatar
Yes, absolutely. But I recommend you upgrade the blocking filter to a B600 or so. Search Cloudy Nights and you’ll find a lot of helpful discussion and worth reading over before you buy. Here’s an example of one link https://www.cloudynights.com/topic/772006-setting-up-image-train-on-ls50tha/?hl=%2Blunt+%2B50#entry11113377
you can also search astrobin for captures taken with this Lunt 50THa too
Concise
deleted avatar
Cheers @astro_rocketeer for the reply!
Is there a possibility to attach a reducer to the telescope so you get a wider FOV for photography?
Question about Flats
I have a CMOS OSC and use one filter at a time, either the Optolong L-Enhance narrowband filter or the Optolong L-Pro broadband filter. They are the same size (2"). My question is do I need to take flats with both filters or can I take all my fl...
Discusses camera filters and OSC setup relevant to solar imaging configuration.
Dec 9, 2022
New Planetary color camera advice
Hi, I am thinking about buying a new camera for planetary with so many models hitting the markets since few years ago now, i have 6 cameras so far for that [1 is damaged and one is a mini design for guiding only] and they are all great for sure, but ...
Addresses camera selection for specialized imaging, potentially applicable to solar work.
Oct 12, 2022
