Rodd Dryfoos avatar
I manually focus with electronic motors using a B-mask.  Normally I get very clean, text book like shapes--angled side spikes and a center spike that is centered to achieve focus.  However, take a look at the attached image of my recent B-mask shape.  You'll note the spikes are bent--or angled close to the star--almost segmented.  Further out, the spikes are long and straight like they are supposed to be.  Using the spikes close to the star makes focusing very difficult, as the base of the central spike is to the right, and the top of the central spike is to the left.  And the side spikes are angled close to the star as well.  Does anybody know what the problem is?  I immediately thought of collimation, but the C11Edge holds collimation extremely well, and last week all was well.  the scope is permanently mounted on concrete fittings and it remains perfectly level and PA does not change (much).  I find it a bit perplexing that collimation would shift with the scope on the mount (mostly not being used as the weather is very poor.
I collected 500 20 sec lum subs to add to my RGB of NGC 5907, and I was amazed how good it came out--it certainly does not look like there is a collimation issue--stars are round and the details in the galaxy very nice for my sky.  I attached a copy of an unprocessed screen stretch of the 494 20 sec sub stack.  If collimation is off, it can't be by much.
The question is--can a very slight miscollimation cause the B-mask image to look as it does?  If that is the case--it appears it is super sensitive and makes a premium method for checking collimation without having to actually get into checking collimation the old fashion way.  Besides, it might be that visually collimation errors would be less noticeable than the b-mask for very small miscollimations.
But is it a collimation issue?
The other strange thing is Sub Frame Selector reports the FWHM value of this stack to be sub 1 arcsec (0.90 I think), which MUST be wrong.  I checked the settings and they are correct.  I expected SFS to report a FWHM of around 2.5
Most likely a thermal plume within the tube. Stars look good. Don't fret over it.
Rodd Dryfoos avatar
Come to think about it, it was very warm and humid.  But it makes it really hard to focus!   It wasn't until I realized I could use the geometry of the outer extent of the spikes that I had any success.
Thanks--good news is hard to come by these days
Bruce Donzanti avatar
"The question is--can a very slight miscollimation cause the B-mask image to look as it does?".......
I do not think so.  At least on my C11" EdgeHD, when it badly needed collimation, I do not recall the mask image changing.  So, I am not sure what is causing this in your case but given your nice image and star shapes, I would not lose any sleep over this.
Rodd Dryfoos avatar
Bruce Donzanti:
Thanks---now, finally, off to bed!
Stargazer66207 avatar
Rodd,
I, too, have a C-11, and use the Bahtinov mask and focus using a Starizona electric MicroTouch focuser.  You did not say in your post what the magnitude of the star was or what your exposure time was. If you were focusing on a bright star (say 2nd mag) and are exposing for longer than 2 to 3 seconds, the star will saturate and "bleed" into the base of the diffraction spikes. Your image of 5907 certainly looks like it is well focused.
Let me know regarding the brightness of the star and the exposure time.  Next time out, I'd recommend trying a shorter exposure and see what this does to the spikes.
Stargazer66207
Rodd Dryfoos avatar
Rodd,
Stargazer66207
Thank, Stargazer.   I typically use stars that do not saturate for focusing.  I have tried all approaches--bright stars with very short exposures, very faint stars with 10 sec exposures, and middle brightness stars that don't show up well in the B-mask with 1 sec exposres, but do yield a decent pattern with 3-4 sec exposures.   I don't know if it's tube currents or seeing, but lately, nothing seems to produce the textbook, sharp B-mask pattern.   I do not know what the magnitude of this star is--the star is located close to NGC 5907--if you look on your planetarium screen, you'll see two stars southeast of NGC 5907.  they are much brighter than any star in my FOV for this image.  I tried using stars in the FOV, but even with 10 sec exposures they just looked like blurry patches.  I used the one closest to the galaxy When everything is working properly, I find that stars that do saturate bleed, as you say, into the surrounding spikes--but they don't cause cocked spikes like these--they just get large and bleed together.
Rodd,
Some more questions:
1) What type of B mask are you using & what brand?
2)Do you re-focus with the mask again later in the evening, or just at the start of an imaging session?
This is an intriguing problem!
Stargazer66207
Rodd Dryfoos avatar
Rodd,
Stargazer66207
I forgot the brand.  I got it at Opt I think.  It’s plastic.  I dont remember having this issue before.  I focus pretty much every time my fwhm creeps above a certain number.  With  the C11Edge On bad nights it’s frustrating because no matter how hard I try I can’t beat 3 and mid 3s makes me want to quit.  On good nights I might achieve 1.6 but it will typically hover around 2.3. When it climbs past 2.8 I refocus.  It can bounce in .5 arcsec humps because subs are short.  So I make sure focus is drifting and it’s not seeing related.  So I refocus many times in a session. Except those rare occasions when my fwhm stays put for hours ( I love those nights)
Rodd,
I can sympathize with your frustration with FWHMs that creep upward. I fight the problem constantly. I also forgot to ask what focal length you are shooting at (native, or with a reducer, and if so, which one).  I fight FWHM problems mainly due to the fact that all of my imaging is done using a Starizona HyperStar III system, which is f/2 (560mm).  The brutally short light cone of f/2 makes the critical focus area extremely small!!  Using HyperStar, I consider myself lucky if I can keep the FWHM under 4!  But, the stars look good in my images, so I can't complain, I guess.
Stargazer66207
Rodd Dryfoos avatar
Rodd,
Stargazer66207
Well, as the pixel scale increases (usually focal length goes down) larger fwhm are fine, otherwise you end up with single pixel stars.  With the C11Edge edge at present I am shooting native (2800 mm). I have the celestron 0.7x reducer.  I figured I would try 2800 as I hadn’t imaged at that focal length before.   I don’t want the larger FOV for galaxies. Full frame would be nice though. Or even aps-c
Rick Veregin avatar
From what I can see from your masked image, you are not in focus, when that is the case, you will see even the smallest issue with seeing or thermal equilibration or collimation. If you are in focus you won't see too much issue from collimation in the mask spikes, but out of focus, or off axis it will show up very clearly. Indeed, the star to upper left looks even worse for asymmetrical spikes, could be collimation or your camera and image plane are not parallel.
I also typically turn the gain up to get the spikes as far out as possible, then make sure at the farthest extent there is a nice symmetry, I don't worry about any distortions in close, especially if seeing is not great. if the star is too faint and the diffraction is not visible in long spikes, it can be very difficult to focus. Check the collimation first though, take off the mask and make sure your out of focus image is a perfect bullseye, no point even trying to focus if collimation is off.
I do get asymmetrical patterns when thermal equilibration is poor, or if the mask is not sitting flat on the tube, or if it is off centered on my C925, or if seeing is bad. If you are at prime focus at f/10 you should have relatively good latitude to focus. At f/6.3 I don't need generally to refocus more than once every 2 or 3 hours, but I need to get at least 45' to equilibrate to thermal equilibrium. But if there is a large temperature change at night, you must refocus often, no way around it.
Regarding FWHM, I do see seeing changes over a course of the night, like it will be really bad for 30 minutes, then get better. I generally look to see if some images are still low FWHM, if so, then I don't bother to refocus. It is only if the FWHM keeps drifting worse and worse that I figure it is focus, and if it turns out not to be the case, that seeing is just degraded, decide if I will leave for the night.
Rick
John Hayes avatar
After reading through all the responses, I can add a couple of things here.
1) A misaligned secondary on a SCT produces comatic imaging and as long as the misalignment is small, I agree that you won't see much effect on focusing with a B-mask.  However, you can detect astigmatic errors pretty easily in any telescope with a B-mask. If you rotate the mask in the pupil and you see a change in focus with angle, that's an astigmatic error.  That kind of error can come from a few things but it's typically due to a manufacturing error in the optics somewhere.  It can also come from a mechanically distorted fold mirror.
2) When the diffraction pattern is split or dancing around between exposures, that's an indication of poor seeing coming from within the tube or the atmosphere.  You are simply catching the changes in the wavefront as it dances around.  Obviously that will translating into a larger blur diameter when using a long exposure.  So in that case, it's not only is it harder to find the best focus but finding and achieving the best focus isn't as important.
3) Your image looks very good but I agree that your measured FWHM value probably isn't right.  There are a number of things that can go wrong that aren't always immediately obvious.  If you've double checked your pixel scale and you are absolutely sure it is right, here are some things to try.
a). Look at how many stars are being fitted.  If it's over a couple hundred, something is wrong and you may be picking up noise.  It's a good idea to set the threshold for star detection to be fairly large and to set the max intensity no higher than 90% to avoid picking up over-exposed stars.  Shoot for fitting about 200 stars.  In rare cases, it helps to restrict the measurement area to avoid the edges.  Setting a boarder of 100-500 pixels can sometimes help get a more accurate reading of FWHM in the middle of the field.  This is usually most helpful when the FWHM is reading too large; not too small.
b). Look at the Moffet order for fitted stars.  2.5 is typically a good value but for a very sharp image 1.5 is better.  If the order is set too low, the fit won't be good and your FWHM values will be too large.  If you really want to get accurate use the dynamic PSF tool to measure the actual shape of your stars before measuring the FWHM.
I'm going to try to post a sub of the same object with a measured FWHM in the range of about 1.6" so you can compare it with yours to see how close you got.  I had some trouble attaching it to this post so I'll try in a subsequent post.
Helpful Insightful
John Hayes avatar
John Hayes avatar
Rodd Dryfoos:
This is why you want an auto-focusing system.  Without it, you are wasting valuable imaging conditions!  I use real-time astigmatic focusing on my systems, which measures and sets focus every 1-5 seconds all night long.
David Nozadze avatar
Sorry for a completely amateur opinion, but if your scope has a fast focal ratio, a small collimation error may be sufficient to cause this problem. Diffraction spikes in the subframe do appear to be just slightly off-center.  I think slower scopes are more forgiving….
D
Respectful Supportive
John,
what auto focus system do you use that automatically adjusts focus every 3 to 4 seconds as you are imaging?
Stargazer66207
John Hayes avatar
John,
Stargazer66207
I use astigmatic focusing with the IFI ONAG auto guider and Focus Lock on both my 14” SCT and my 20” CDK systems (https://www.innovationsforesight.com/product-category/on-axis-guider/).  You can read more about how I have it set up on my 20” here:  https://www.astrobin.com/xfedon/I/ and here: https://www.astrobin.com/txk760/H/.  Focusing is a big subject and I presented a 4 hour workshop on focusing methods at the last NEAIC meeting.  Unfortunately, they never made any of the presentations public so I can’t give you a link.  With ONAG, image focus can be checked and corrected every guide cycle.  I’ve used FocusLock for over 4 years and it works well, though it only guides and focuses on a single star.  I’m working on converting to IFI SkyGuard autocovariance guiding because that method uses the entire frame for both guiding and focusing.  It also doesn’t require selecting a guide-star so it’s more compatible with fully automated operation.  SkyGuard still needs a minor tweak before I can use it on my system but I understand that it should be available “real soon now.”
John,
Thanks for your feedback re:focusing, and for the fascinating links you included. The text and excellent photos you included were very informative. Unfortunately, I am guiding via a co-ax mounted 80mm refractor, so I would not be able to use an auto focus program that
uses the guiding image to adjust.
What you have done is amazing. Wish I could do something to make my continuing search for perfect focus come to fruition, but I guess I'll just have to keep muddling along!  Again, thanks for the feedback and for the informative links!!
Stargazer66207
John Hayes avatar
John,
Stargazer66207
What scope are you imaging with?
Konstantin Firsov avatar
Rodd Dryfoos:
Most likely you are having an issue with the chromatic aberration. Or your object is too close to the horizon. Try test focusing with a single color filter instead of L. If the problem goes, it's definitely chromatism.
Another check: if your RGB filters are parafocal, you should not notice sufficient focus shift when changing between R - G - B, once you have focused, say in Red. But if the scope has chromatic aberrations you will clearly see the focus shift when changing the filters. Especially with the Bahtinov mask.
John Hayes:
John,
Stargazer66207
John,
I'm imaging with a ca. 1990 Celestron C-11, with an Orion 80ED f/7.5 refractor as a guide scope with ZWO 174mm Mini guide camera.
Stargazer66207
John Hayes avatar
John Hayes:
John,
Stargazer66207
John,
Stargazer66207
Ok, thanks.  I just want you to know that a C11 is not a good scope to use with a guide-scope for long exposure imaging.  Mirror flop and mechanical flexure will not allow very précised guiding. You can get results but you will likely see significant improvement with OAG or ONAG on that scope.
Tilt/Collimation/Back focus issues?
Hi all, I am having some issues with my images - it is obvious that I have issues with corners of my images and I was ignoring it up to know (just crop it out) - I know, not nice but I wanted too fast to get some light Now I am trying to do globular ...
Collimation issues can cause bent spikes and focusing difficulties with masks.
Jun 7, 2023
How well centered is your secondary mirror/corrector plate on your Edge HD?
I yesterday finished printing a tri bhatinov mask for my EHD 9.25 and when I mounted it I was shocked that my central mirror/corrector plate is not very centered. When I look at the position of the 4 grubscrews for centering the plate this seems to b...
Misaligned secondary/corrector plate causes distorted diffraction spikes in B-mask images.
Dec 11, 2022
Mysterious diagonal star spikes
My setup is the Celestron 8SE+Starizona SCT Corrector IV+ASI2600MC Pro. I collimated the OTA and checked for tilt, yet all my stars have this weird oval shape. Looking at the focused star image, it appears that I am too close, even though I am exactl...
Directly addresses mysterious diagonal star spike anomalies similar to your issue.
Sep 10, 2022
WO GT 71 II + Flat6A III + Nikon D5600 Spacing question
Hello there, I have a problem of finding out correct spacing on Flat6A III for my Nikon D5600. firstlightopticsoptics suggests 7.1mm: https://www.firstlightoptics.com/reducersflatteners/william-optics-adjustable-flat6a-iii-08x-reducer-flattener.html ...
Author uses Bhatinov mask for focus verification, relevant to their spacing verification method.
Mar 25, 2020
Frame and focus problems
Went out last night to image with a red cat 51/asi 294 mc pro and l-enhance filter. It was around 10 degrees Fahrenheit with fairly high humidity/frost. I went through polar alignment/star alignment with no issues but began experiencing a problem whe...
Bhatinov Mask issue — focus problems with electronic motors and masks relevant.
Dec 8, 2019
