Jon Rista:
Daytime sky isn't really flat (thanks the nearest star to us, the Sun) and we don't know what the OP is using for imaging. Wide FOV will reveal that sure enough. Small FOV, you'll get away with it, IF pointing well away from the Sun. I have always taken flats at dusk (specifically at sunset or shortly before) and NEVER had any issue. YMMV.
A daytime flat is significantly flatter than a dusk flat. You can easily point away from the sun enough that the blue sky is very flat. At dusk, you have constantly changing variables that are integrated into your individual frames. Some software allows you to normalize the average ADU count, but you can still have some pretty rouge gradients. You can also pick up stars (a near-impossibility during the day). A blue sky flat, even if it has a gradient, will be orders of magnitude smaller than most dusk/dawn sky flats, and you won't have the intensity shift of dusk/dawn flats.
Jon,
The software in use nowadays, does all of this for people. Picking up stars is not a problem. The automation slews and dithers as well. I would bet you $10 I can take better flats with Voyagers automation, than you can with a T-shirt futzing around in the daytime.
This image was taken using the same software, same method of flats, and is up on the "Sky" Facebook page of NASA and will probably show up soon as an APOD. That is "The Eyes" taken with a 1 meter CDK in Chile by Mike Selby.
What you are saying here, is old man get off my lawn levels of old school thought and point in time perspective based on what software BACK THEN did. We are way past this, my friend.
With a blue daytime flat, you don't use a diffuser. Its just the blue sky with an open aperture. If you try an overcast sky, then a diffuser would be necessary, but not with a blue sky. Its exceptionally flat.
If software can take care of stars for you and all of that, great. I have always had gradients in my flats at dusk (or dawn). Does the software also correct the gradient? Is a corrected gradient better than a truly flat flat? If you are correcting a gradient, then that would be multiplying and dividing the signal, so I wonder about PRNU correction and how good it would be. I am aware that modern software can automate flat acquisition, and do things like automatically adjust to maintain an average ADU level. The image you shared exhibits a dark ring artifact, around the center field, and looks slightly brighter at the top than the bottom. Is that due to the flats?
I still disagree that a dusk sky has less gradient than a blue sky. ;)
With that said, I won't continue to debate the point. If someone wants to get their flats at dusk, I am certainly not going to tell them they are wrong, or are an old geezer for saying so.
I'm sure voyager could make short work of open aperture daytime blue sky flats too, and I think they can be just as viable an option for those who have troubles with dusk flats. Beyond that, I don't think this all warrants any deeper debate. I've offered my 2 pence, and people can decide on their own what kind of flat to get.
