Mono capture process
3 replies84 views
Dunk avatar
Hi all,
about to get my first mono camera and was wondering if anyone can give me any advice/experience on a process when capturing multiple filters?
(I'm using an ASIAir Pro/EFW here, so everything is automated. Not concerned about effort, more about recommendations for best image)
Say I want to take 12 frames each RGB - what's the recommended approach:
12xR, 12xG, 12xB
or
RGB,RGB… 12 times
or
RRR,GGG,BBB,RRR,GGG,BBB…  4 times
or something else?
Or… does it make no real difference and I'm just fussing over nothing?
d.
Kapil K. avatar
Hi D,
it doesn’t really matter in principle as long as your filters are parfocal. Otherwise, you might have to focus between each filter change. So in that case, doing ‘n’ Reds one night (or whatever time span you’d want), then re-focus and do ‘n’ greens next night .. and so on would be a better strategy. In general also, avoiding unnecessary Filter Wheel rotation would just be less error prone, IMO.
I personally do them in sets. For example, on a single night, I would do {25 x L, 15 x R, 15 x G, 15 x B}. That way, even after a single night of captures, I have a full set to process and play around with and course correct as needed. Once I get enough LRGB, I just go all in on Lum and/or H-alpha and get as many of them as I can on next set of clear nights. I try and post-process from time to time and call it done when I think I am getting to point of diminishing returns (usually happens around 15-20hrs of total exposure).
Hope this helps,
-Thanks,
K.
urban.astronomer avatar
Another aspect is how much variation and stability you have in the sky conditions. Where I live, clear nights are not that frequent, so if the seeing conditions are excellent one night, I prefer to rotate the filter wheel, RGB, RGB, .. in case I don't get the opportunity to gather more data in the near future. This way, you also ensure that you have roughly the same data quality from all the filters.
Before I started this procedure, it happened to me more than once that the clouds came in for long periods, and I had to wait for weeks to finish off a data set, missing data from only a single filter. And when the sky went clear again, the deep sky object had moved out of reach.
Think of it as not putting all the eggs in one basket (translated: Don't put all the data on one filter) ;-)
Cheers!
-Martin
Dunk avatar
thx guys. some good advice!
Dunk.
qhy 163m monochrome cmos camera 12 nm. Gain and offset
Hi, everyone, I was wondering if I am using 12 nm. Narrowband filters for my qhy 163 m camera, should I use a lower gain and offset, because these filters have a wider bandpass, or can I use the same gain, offset as say 6 nm. Filters, and does anyone...
Mono camera filter capture process directly relevant to narrowband filter workflow.
Nov 2, 2019
Best gain offset for using 12 nm. Narrowband filters
Hi everyone, I use optolong 12 nm. Narrowband filters for my qhy163m, I was wondering should I use a lower gain and offset for these filters due to their, wider bandpass as supposed to say 5 or 6 nm. Filters ,also what is a good recommend gain and of...
Discusses mono camera filter capture process relevant to narrowband imaging.
Nov 2, 2019
Filter accuracy
I'm not sure about all of you, but after watching some of Cuiv's review of Baader filters and others, I got this super paranoid feeling for filters. Are my narrowband filters doing what I think they are? There's so much effort put into aq...
Filter accuracy affects RGB capture sequence optimization and image quality.
May 22, 2023
Pixinsight - DeBayer Issue
Gang, I'm wondering if anyone might have some suggestions for what is going on in my processing flow. Long story short - captured 3 hours of data using my OSC through an LeNhance filter. Nothing unusual about the settings - no problems in the pas...
Debayering mono camera data directly relates to multi-filter RGB processing workflow.
Aug 30, 2022
