Integration fails in Pixnsigt
12 replies214 views
Patrick Graham avatar
I haven't had this happen before but when trying to integrate the 146 subs I shot of  M106, I keep getting the same "not enough stars available to match" error message.  Visually the subs look great and even removed bad ones with the subframe selector tool.  Each sub was shot through a ZWO 2400MC-Pro attached with the L-Enhance filter.  My OTA is the Stellarvue SVX130T. I've tried different settings as instructed by Warren Keller's book, "Inside PixInsight".  Still no success.
Field of view is 3.24 degrees X 2.16 degrees.  Resolution is  1.92" x 1.92"  Above is a sample subframe.
haven't had this issue with any other targets.  Anyone know what I'm doing wrong or suggestions for settings to get this to work?
Pat Graham....Oops....shoulda put this under processing techniques.   My bad
Almos Balasi avatar
Are you using the weighted batch preprocessing script? With this script the same problem happened to me. The error is sometime due to the meridian flip, if I rotate the recordings after the flip with 180 degrees, than the integration works (usually for mono images). Sometime is the same problem with CFA images, and it is probably your case,when the detection of bayer matrix selector is set to auto. I change it to RGGB for all light frames (you can set  it in Control Panel -> CFA images) and it works again. By the way, are you using Asiair? I ask it because the problem probably came from the fits file header, and it happen if the meridian flip is activated after you start the Auto mode.
CS - Álmos
If you flipped crossing the meridian then this might be a reason. Split the integration in batches to find which of the set is giving you grief. Say integrate the first 40, then 80 then 120 and so on. Change the number as you see fit.
I'm using the integration tool in my PI workflow, not the WBPP.  I haven't used any calibration frames except for the autodark feature in the SkyX pro.  I think you both are correct that the flip may be the culprit.  I hadn't thought of that as PI boasts that their integration tool can factor that into the sequence.  I'll try your suggestion, Andrea.   Also, I usually use the RGGB when debayering but may have inadvertently omitted that selection and it defaulted to Auto.  Thanks for the advice and I'll let you know if the issue is resolved.
Patrick G
My apologies,  the problem occurs in the star alignment process, not integration.  I've tried several different combination of values without any success.
dkamen avatar
Hi Patrick,
It must be telling you how many stars it is finding in every image. Look at the process log. Based on your image, you probably want to crank up "Peak Response", perhaps increase detection scale by 1 and maybe decrease Log(Sensitivity) a little bit.
Dimitris
Helpful Respectful Concise
Almos Balasi avatar
In some situation the star align can fail also due the camera bad or hot pixels. You can eliminate this problem in PI with Cosmetic Correction.
Patrick Graham:
Patrick G
I had the issue when trying to align LRGBHa frames to each other and when one (or more) was flipped then PI failed to align. Another extreme case is when less than half of the target frame is contained in the reference frame and the field is poor in stars.
Roger Nichol avatar
This is a StarAlignment issue, not ImageIntegration.  You can change your Star Detection settings but more likely your Star Matching where you could increase your RANSAC settings.  I attach my settings which have never let me down with my 550mm scope and ASI2600 camera.
Concise
dkamen avatar
To me the stars in that image look slightly out of focus or perhaps just blurry due to problematic transparency. So increasing peak response to say 0.95 should find more stars.
Thanks, everyone for all the help and suggestions.  I'll try each and every one unitl I can get something to work.  Could be just not enough stars in the field so maybe longer exposures are called for.  Focus should have been ok, but always good to check each time after a slew.  Roger,  I'll try your settings and see what happens.  Thanks for sharing.
clear skies to all,
Pat
Well,  after applying all your suggestion and techniques, I finally got the star alignment to run successfully.     Everyone, please accept my thanks for all your help.  I'm still in a steep learning curve here and I appreciate you all sharing your experience and knowledge.
Clear Skies to all,
Patrick G
What On Earth Did I End Up Capturing Here?
Hi Folks, I was imaging remotely at a dark site about 30 minutes from my house. When I started processing the results, I noticed a single frame that had the strangest pattern that I can't quite figure out. The target is the Iris Nebula, and just ...
Troubleshooting image processing issues with similar equipment and filters.
Sep 27, 2022
Same Telescope, Same Camera, Same Mount, Same Filter--But very different results
A week or so ago I shot this image using an Esprit 100ED, AM5 mount 2600MC camera and an L-Pro filter. I'm happy with the results (M3). But last night I went out to shoot M101 and planned on shooting 5 hours but only got to 3 as the clouds moved ...
Comparing results with same telescope, camera, mount, and L-filter setup.
Apr 17, 2023
Imaging Time -- OSC filters vs. Sky Quality
I currently use an L-Enhance filter from a sky on the darker end of a Bortle 6 (~19.4 SQM); Bortle 5 is just a mile or so away. My most used local sites are in the 20.7 - 21.3 range. If I recall correctly, requisite imaging time is proportional to 2....
L-Enhance filter performance and imaging conditions optimization.
Apr 21, 2023
