Best solution for fighting dew in a Takahashi E-160ed
13 replies366 views
Rafael Sampaio avatar
Hi everyone,
To avoid dew in a Takahashi E-160ed, would you prefer to use a rigid fiber carbon dew shied along with a dew heater, or a heated flexible dew shield like the ones from AstroZap ?
Jeff Ridder avatar
Rafael Sampaio:
Hi everyone,
I use the heated AstroZap and it works great. I have to crank the agressiveness to 10 on my PPBU2 during the more humid months here in Virginia, but the heated AstroZap does the job.
Heated one, but order it from them made at 10". Then it won't protrude too far into the light path.
Jeff Ridder avatar
AstroZap has changed the default length to 10” for the Epsi dew shields, so should be good to order straight up.
Jeff Ridder:
Hey that's awesome. Good to know!
Thanks everyone!
So, does the Astrozap heated shield works with any 12v dew heater output, like the Eagle and  Pegasus Astro ones?
Jeff Ridder avatar
Rafael Sampaio:
Thanks everyone!
Yes. I use it with my Pegasus Powerbox Ultimate v2. Just have to crank the aggressiveness up a bit in my environment, but it’s fine.
Jeff Ridder avatar
If you get a PPBUv2, I recommend this doodad: https://www.overcastobservatory.com/product/upbv2-piggyback-cable-management-system/
Those dew heater cables are annoyingly long, and this gives you a way to manage them, along with any other long cables.
Well Written Concise
Yuexiao Shen avatar
Rafael Sampaio:
Hi everyone,
If you want to run remote, better to use a rigid carbon dew shield so that you can add a motorized cap
Yuexiao Shen:
Rafael Sampaio:
Hi everyone,
Good point! Thanks!
Jeff Ridder avatar
I’m deploying mine remote with the AstroZap and not concerned with a cap. Yeah, it might accumulate a bit more dust, but that’s kind of inevitable. Not concerned with a flat panel either since sky flats are super easy with Voyager and work great.
Jeff Ridder:
Sky flats will correct things with this imaging system that panel flats will not. Similarly, the tube is semi-closed (not being a truss system), so capping it is probably a bad idea while it sits in the observatory with the roof closed. A rear fan should be used no matter what, but capping the front of the scope, IMHO is not a good idea.
Yuexiao Shen avatar
The cap is essential in an area where the weather is dusty and insects are active. Nobody wants insects to lay eggs and have families inside scopes. Unless there is someone who can take are of scope from time to time on site
Yuexiao
Rouz Astro avatar
We do have rigid carbon composite dew shield for the Epsilons.
These also have integrated Losmandy style dovetails to which you can clamp some brands of flat panels like the Primaluces.
Also, there is front lip designed in collaboration with Deep Sky Dad for those who want to clamp the DSD flat panels to.
We also add a small fan to constantly move the air inside the tube, further delaying the onset of dew.
The new fan design is fully baffled to avoid light leaks.
One dew solution that may not be for everyone.
I live in coastal Southern California and I have always struggled with dew prevention on my 10” DIY newt… I’ve tried dewshields, dew heaters, burning sage, shamans, you name it. Dewshields are ungainly and huge. Dew heaters would generally overheat t...
Discusses dew prevention solutions for telescopes in humid coastal conditions.
Nov 28, 2025
