Going remote with an EQ6r pro
8 replies627 views
Leonardo Landi avatar
Hello everyone. I'm thinking of setting up a setup at a hosting facility 2.5 hours from home. For the moment, however, I don't want to replace my EQ6r pro, which after tuning allows me to guide at 0.3-0.6 which is more than sufficient for my focal lengths. I currently have a small shelter with a ROR in my backyard, and I control everything from home without any particular problems via an Eagle 4 so the setup can be said to be already remote. Does anyone else have experience with this mount installed remotely? From what I have seen it seems that the main problem is the absence of encoders which causes the loss of the home position in the event of an electrical fault. However, I believe that with a webcam and mount controls you can restore a good home position, and then plate solving will do the rest. Or did I miss some steps? Any advice is welcome!
Mickael Coulon avatar
We made it smile, with an Askar 107PHQ
Indeed, we use a cam to check the mount and with platesolve you can Sync your mount. The absence of encodeurs isn't really a problem ;)
Jaume Zapata avatar
Hi Leonardo,
Here you have my EQ6-R Pro working remotely, 200 km from home with good skies (along with its older sister Losmandy Titan), it is true that if you have a power outage you lose your position, but there are solutions.
I put two pieces of insulating tape for the DEC axis and two more for the RA axis, when the mount is in HOME. Thus, taking the mount to that position, from the aligned insulating tapes that I see with the camera, from the EQMOD we press "Resync encoders" (in Settings, next to "Park Mode") and that's it!
Jaume
Brian Schumacher avatar
When it comes to losing home position due to a power disruption, you are correct. One cost-effective solution is to invest in a battery backup power supply.
Philippe Barraud avatar
There are solutions without encoders, but it can be terribly time wasting… And power losses do happen. I experienced it with a remote CGEM, 1800 km from home !
I have changed for a ZWO AM5, and it makes a huge difference. The mount points always perfectly, due to an efficient plate-solving software, whatever happens with the power. And there is no counterwight balancing, so the entire setup is rapidly in place, which is cost-effective when you do not do it yourself.
Philippe
Richard Shagam avatar
I haven't run mine remote, except from my home office to my driveway where I set up, but I suggest maybe looking into adding a simple homing switch, perhaps using a Hall or optical proximity sensor.  I don't know if you are familiar with it, but the Windows-based Green Swamp Software https://greenswamp.org/ apparently supports an autohome sensor.  But a webcam monitor also seems to be a simple, sastifactory approach.
Paul Wilson avatar
Leonardo Landi:
*** I’m going remote with my EQ6 because it’s what I own.  Mine is high milage and needs a tune up but there’s no available service and I don’t want to tear it down without skills and experience.
The remote place doesn’t allow personal cams so I’m not going to worry about it.  Also I can’t use my flat flip panel/dust cover because of their swing diameter rules.  They pack in as many rigs as possible.***
Optimal data flow from remote observatory?
Attached to one of the latest great images from @John Hayes, he described a recent improvement in his dataflow. After sharing some thoughts back and forth, we thought this might be a good topic to bring to the forum for a bit of a wider discussion an...
Discusses remote observatory data flow, directly relevant to author's setup.
Jul 14, 2025
Vixen AXJ with encoders or 10Micron GM1000 HPS
Hello everyone, I'm currently considering whether to buy a Vixen AXJ with encoders or go for a 10Micron GM1000 HPS. What's most important to me is being able to expose for a certain amount of time without guiding. As far as I can tell, both m...
Compares mount options; author considering remote facility setup may need upgrade.
Jun 11, 2025
Mounting telescopes permanently on motorhome for easier astrophotography setup
Greetings all, I’m an avid “traveler” that drives around 1 hour to access the best sky in my country for all my sessions (bortle 4). The way that I managed to do that is to store all of my astrophotography equipment permanently in my car’s trunk with...
Remote astrophotography setup 2.5 hours away matches author's planned facility scenario.
Jan 5, 2026
Skywatcher EQ6R Pro Update
Hello, I was wondering if anyone has achieved a successful motor controller update on an EQ6R Pro? Skywatcher seem to have recently released the firmware loader for Mac to their website, great I thought as I have no access to a Windows machine, howev...
EQ6R Pro firmware updates relevant to author's current mount.
Jun 24, 2025
