I have a ZWO guide scope to guide my 80 mm refractor. How much better guiding can I expect if I change to an on axis guider?
Ruediger:-lack of flexure (OAG wins)
Please consider, you put significant more weight to the small focuser. Since it is a 80mm I would guess it is not the most stable one. So you may introduce new issues there too. But this is guessing since we have no details about the scope.
Rüdiger
Tim Ray:
Most likely the improvement has been the use of the Multi-Star guiding function. That can be toggled on and off via the "Brain" button. That way you can isolate your recent addition of OAGing and get a more accurate result of OAG vs GS. I think your improvement is mostly the result of the updated PHD2 software. I have seen marked improvements on all my mounts with this updated software.
For the hassles of OAG, I recommend solving your GS mounting issues. if needed put a 3pt ring on the finder draw tube. Use the Guiding Assistant in PHD2 to dial in the software settings. With the flexibility of not guiding thru the main tube that a GS offers. Plus I hate to play the herd mentality game but you would be hard pressed to find a fellow APr that uses OAG on anything other than a movable mirror-long F.L. OTA for that reason.
Another point is speed of setup. Its getting to the point I can setup within a half hour and another 5min polar alignment with the Polemaster and once the camera cools and the sky is dark. The longest thing I have to wait for to start imaging is for the mount to slew, platesolving the position, autofocus, the PHD2 does a mount calibration on a guides star and I start my sequence. I did not have to spend a moment planning a guide star position or even wondering if I would even have a guide star to use. Enough issues pop up in a normal imaging session, a GS will help to minimize any issues that prevents time on target with the main camera.
Cheers
Used the same ASI120MM-mini with both.
I suspect that with short primary focal lengths (200-1200mm) there will be little guiding improvement with OAG.
But I think that with longer focal length (>2000mm) in combination with long exposure times (>300 sek) a OAG is a better choice.
