Which field flattener for the WO 71 Gran Turismo?
7 replies156 views
Douwe79 avatar
Hi all,
I'm looking for a small refractor for wide field targets such as the heart nebula, orion nebula, etc.
Right now I'm gravitating towards the William Optics 71 Gran Turismo. I noticed that the dedicated field flattener that WO recommends for this specific scope, is also a 0.8 reducer (the Flat 6AIII). Point is that I rather not have the focus length of the WO 71 GT reduced to a focal length that is actually less than that of the WO Zenithstar 61.
Then I noticed that there's also the WO Flat73A flattener. This is a purely a flattener and not a reducer. However, this flattener is only recommended for the WO Zenithstar 61 and 73 scopes.
So I was thinking "can't I just use the Flat73A on the WO 71 Gran Turismo, or might they be incompatible?" On Astobins Great Wall I normally see the combination WO 71 GT + Flat 6AIII.
Does anyone use the combination WO 71 GT + WO Flat73A flattener?
Thanks in advance and CS!
Douwe
Joe Santacroce avatar
Like others, as you mentioned I have the WO GT71 (and a Z61) and I use the 6Aiii. For some targets, that's more than enough Focal Length but others fall far short. The FL is 336mm with the 6Aiii. I thought of trying it without the Reducer\Flattener for some targets then if needed crop out the starts along the edge but that might not provide the best results. I have the 6r flattener for the Z61 and it is also a .8 reducer.
I would also be interested in seeing if anyone either used no R\F or used the Flattener only.
Nicole & Ryan avatar
We've got the WO 71 with dedicated flattener, tried to get "into" Horsehead and Flame a little by taking off the flattener, results were not good, didn't even keep all of Flame after processing, and sure was not anything to share here.(Alas, still trying to get the F6Alll to be flat smile, our fault not it's)
Nikki
Steven avatar
I've tried my best on google. but I can find surprisingly little.
But, with the 73 being a doublet. And the 71 (and any other listed for the 6AIII) being triplets.. I have my doubts..
every time the 73 Flattener is listed, it is specifically and only listed for the ZS73.
Not like some other flatteners that are listed as: "Apo's between F5-F7 etc etc".. so ... I'm not sure.
I did find a list
And it says at the bottom that the ZS73 flattener is only listed for the ZS73. "some William Optics field flatteners are fixed devices for particular telescopes like the ZenithStar 61 and ZenithStar 73"
And some other flatteners are listed for multiple scopes, as they are adjustable in length, showing the required length next to it.
Making it appear that the 73A flattener is fixed in 1 position..? But....  the ZS73 flattener (P-FLAT73A).. is adjustable.... but it is still only listed for the ZS73.  so.. I'm confused.
I'm not an expert on flatteners and reducers anyway. So maybe there is a reason why it would work together, mainly with one being a doublet, the other a triplet.. So the flatteners are built different to deal with that. but.. no idea.
Douwe79 avatar
Thanks all.
In the meantime I’ve asked WO if the Flat73 is compatible with the GT 71.
I noticed they were very reluctant to answer this question. The only quote I got out of them was:
Flat73a/r are made for ZS73.
Flat73a/r are the flatteners you have to use with ZS73.
No explanation why.
CS!
Larry S avatar
The above is the current info from the WO website for the 6AIII. I have it on the GT71, and I find with smaller sensors (ASI183, ASI533) a setting of 10.1 works better than 9.1. When I tried it with an APS-C sensor (ASI2600MM) and had radiating star trails indicating the sensor was too close to the reducer. I found that 13.1 worked best. In all cases the back focus from reducer to sensor was 55mm. I tried the GT71 once without the FR, and the results were not good.
GW avatar
Have you looked at the  HoTech SCA Field Flattener.
Telescope field flattner lens, SCA field flattener (hotechusa.com)
I have this installed on my GT71
Best wishes
G
Douwe79 avatar
@GW thanks for the tip!
Which Petzval wide field refractor?
I’m thinking about replacing my 72ED refractor with something nicer so I’ve started looking at what I might like instead. I’ve decided on a petzval astrograph of some description but can’t decide what focal length to go for. My 72ED is 420mm and ther...
Nov 6, 2024
Both posts discuss concerns about reducing the focal length of small refractor telescopes for astronomical observation.
Small telescope and Star tracker for beginner astrophotography
Hi, I am currently looking for a small refractor telescope to begin astrophotography in the 300-450mm FL range. As I was searching for an ideal scope I very frecuently stumbled upon the WO Zenithstar Z61 and the Redcat 51. They both seem to be great ...
Aug 30, 2023
Both posts discuss selecting a small refractor telescope for astrophotography by comparing focal length specifications across different models to determine which best suits their observing needs.
