OSC Cameras for Deep Sky imaging with Edge 8 HD...what are you all using?
ScotiaAstroMiguel T. Acosta
25 replies1.8k views
ScotiaAstro avatar
Hey folks,
I'm just in the midst of building out an Edge 8 HD system and am looking for recommendations for an OSC camera for some deep sky astrophotography?  I have the 0.7x Reducer too, so will be likely using that for most of my projects…
I'm shooting from a Bottle 4/5 location and have a mix of Narrowband and Broadband filters already.
I'd be interested in what owners of this scope are using for their imaging sessions? Thanks for any help and advice anyone can give and best wishes from Scotland! smile
Steve smile
Miguel T. Acosta avatar
Hello Steve, I am OSC user with the EdgeHD 8 and a reducer, I use the ASI: 183 Bin 2x2, 533 Bin 2x2, and 2600 Bin 2x2 when seeing is ok, when seeing is good I use Bin 1x1.
Eddie Pons avatar
I'm using the Player One Poseidon-M Pro with the Sony IMX571 APS-C format sensor.  I also use their OAG and filter wheel (7 x 2").  I only use it with the .7 reducer.  I'm very happy with it.
V avatar
I use the ASI2400MC Pro on mine, it's an absolute match made in heaven even if its too big a sensor for the 8's baffletube. Image quality is insane, the F/10 sampling is right on the resolving limit. Don't recommend a reducer.
ov_astro avatar
I use the ZWO ASI 294 MM Pro with good results on my HD8.
Dave Rust avatar
Asi2600mc. Usually bin1. Will shrink to bin 2 in processing if seeing is only average (which is usually the case).
Brian Schumacher avatar
I use both the 294MCPro and the 294MMPro on my C/8 with .7 reducer. I am happy with the results.
Jure Menart avatar
+1 for ASI294mm (bin2 mode), using it on my C8 (no EDGE HD) with 0.7x reducer and works great imho.
Timothy Prospero avatar
Hi, I don't have the 8" telescope, but I do have a C9.25 and an 11HD, both equipped with their respective 0.7x reducers. The ASI294mm PRO works quite well, primarily in Bin2 mode. However, with the C11HD, which is located in a remote observatory, I can also capture images in Bin1 mode with good results, as the seeing is very good..
Timo
Well Written Concise
Eddie Bagwell avatar
I have the 9.25 SCT and use the ZWO 2600mc with two 2" filters with a filter drawer. For filters, I use a UV/IR for galaxies and a dual band IDAS NBZ II for planetary nebulas. I also have a mono set up on another rig with the ZWO 2600mm and LRGBSHO filters in a EFW that I can swap out if I decide to go mono on the SCT.
Rafael Amarins avatar
I'm not sure how well corrected for full frames the Edge HD is but I don't see a better match for the 2400MCP. Incredibly large full well and very low readout noise. Bigger pixels should be a plus at this FL.
V avatar
Rafael Amarins:
The 8's field of view is slightly too small for the full frame sensor, you'll get slight vignetting on the corners. The 9.25 and larger do not have this problem though.
ScotiaAstro avatar
Miguel T. Acosta:
Great to hear, Miguel! I have the 533 and 2600...thanks so much for the info, much appreciated and have a great week!
ScotiaAstro avatar
Eddie Pons:
Thanks Eddie! Yes, the 571 seems to be a popular choice...I have the 2600MC Pro, so that's great news! Appreciate you taking the time to post, cheers!
ScotiaAstro avatar
I use the ASI2400MC Pro on mine, it's an absolute match made in heaven even if its too big a sensor for the 8's image train parts (had to buy custom machined parts) Images are insane, the F/10 sampling is right on the resolving limit, while F/7 is at .8"/px, which is still very good.
Great! Thanks so much for the info mate!
ScotiaAstro avatar
Thanks mate! Glad the 294 is working well for you!
ScotiaAstro avatar
Dave Rust:
Great to hear, Dave...I have the 2600MC too...glad it's working well for you!
ScotiaAstro avatar
Brian Schumacher:
Cheers for that, Brian! Thanks for taking the time to get back to me...
ScotiaAstro avatar
Jure Menart:
Thanks Jure! Yes, a few folks on the thread have been praising the 294...will need to take a look at it! Appreciate your time and have a great week!
ScotiaAstro avatar
Timothy Prospero:
Timo
Always great to image under pristine skies! Thanks for the info Tim! much appreciated!
ScotiaAstro avatar
Eddie Bagwell:
Cheers Eddie! I've got the 2600MC Pro too, so that's great news that it's working well for you!
ScotiaAstro avatar
Rafael Amarins:
Awesome, Rafael! Thanks!
Jay Hovnanian avatar
Miguel,  I am curious to know what FWHM you consider "ok" and "good" at these longer focal lengths?  For example, seeing in the region I image rarely dips below 3.00.  Thanks,  Jay
Jay Hovnanian:
***Hello, Jay. I rely on Telescopius. When I am at the location, Telescopius does a very decent job of providing: seeing, % of cloud, temps, humidity, and dewpoint, I also use an SQM app. I must admit that I am still learning the complexities of it all. The site I do most of my imaging has a Bortle 3 Sky, and the Eagle Eye device does a good job of confirming the sky quality***
Thanks, Miguel.  If you do equate what you find to be "ok" and "good" numerically, message me, please.  It would be good to have a feel for results relating to seeing conditions numerically.  Jay
