Question for QHY294M-users
8 replies275 views
CCDMike avatar
Hi there,
what USB-traffic settings do you guys (and girls) use?
I've tried some numbers I've found in the internet but still struggle with crashes in APT caused by not loading the images from the cam.
TIA
Mike
Pablo Petit avatar
Hello,
I've tried different settings but didn't see much of a difference, what really made the difference was the usb connexion.
If i use my 5m usb 3 extension cable with this camera, the mount, filter wheel and auto focuser on a usb hub everything will work, but if I add a guide camera on top of it I can expect crashes or lost images, on both cams. I tried to use a powered usb cable, but the camera wasn't recognized. I used a powered usb hub, it would add some stability but I would still have problems.
The best solution I found, was to plug everything but the QHY294M on a usb3 hub, itself connected to a 5m cable and then to the computer. And to use a separate usb plug, with an extension cable, for the QHY294M.
Its the only way I've found to have everything perfectly stable, and still get about 5 meters between the pc and the mount.
Hope this helps, clear skies.
KIJJA JEARWATTANAKANOK avatar
I agree with Pablo, changing USB traffic does not make any differences. The camera needs USB 3 connection for it self to prevent connection failures. It can also be connected to  a powered USB port together with other devices  that comes to a computer via USB-C port as well.
Kijja
CCDMike avatar
Thanks. I use the cam with the original cable on it's own USB-3-portsmile
But still having trouble.
Mike
Robert Gillette avatar
I don't use this cameras, but I had similar issues with 15 meters of USB extension cables. Solution was an Icron Ranger 4-port hub that connects with my indoor computer by Ethernet cable to a separate Icron reader unit, which in turn connects to the computer by USB-2 cable.
Bob
Concise
CCDMike avatar
Thanks Bob,
in fact I do not need to extend the existing cable. The original 2m works fine for me. So that shouldn't be the bottle neck.
Mike
8472 avatar
My crashes were solved with installing the latest QHY drivers and APT version.
Completed several imaging runs since and no crashes.
Alex avatar
Hi there,
TIA
Mike
Try checking the box for High Quality CCD in the settings.  This fixed it for me with the ASI6200MM.
CCDMike avatar
Thank you guys. I will try it when clouds will vanish.
Camera download fails when connected per USB 3.0
Hey guys, I recently switched from the ASIair to a laptop and got it all working there too. Just sometimes, NINA fails to download images of the camera (183MM Pro) and it only starts working again after I move/replug the USB extension cable. The cabl...
Camera download fails via USB 3.0; directly addresses USB traffic and image loading issues.
Aug 9, 2022
Do I need a powered usb hub after receiving power errors on my laptop...
So I set my HEQ5 up tonight and I started getting errors when I plugged the hand controller into my laptop. I was getting errors saying the usb port was drawing more power then available. I've gotten errors in the past saying there was a power su...
USB power errors on laptop; relevant to USB settings and connection troubleshooting.
Aug 21, 2022
