Askar ColourMagic Duo with fast focal ratio scope
11 replies655 views
Arnie avatar
Hello all,
I've been seeing some amazing images taken with the Askar Color Magic Duo Super-Narrowband H-a/O-III & S-II/O-III (D1 + D2) Imaging Filter Set and OSC's. I'm considering purchasing a set. Some filter manufacturers have filters optimized for fast focal ratio scopes (usually f/3.6 and faster) to take account of the centerline shift at fast focal ratios. I'm using a SharpStar 150/2.8 HNT. Does anyone know if these filters will perform well at f/2.8?
Thanks so much,
Arnie
Georg N. Nyman avatar
Arnie:
Hello all,
Thanks so much,
Arnie
I am following you....same OTA and same question....!
Arnie:
Hello all,
Thanks so much,
Arnie
If it is the 6nm (which is wrongly quote as the typical passband) Duos you are referring I'm not too pleased with their efficiency, especially in the OIII band. I'd consider it a pass. No halos that I can see at f/4 and at f/2.8  but the test at f/2.8 wasn't very extensive to rule out halos with different star spectra.
Tom Boyd avatar
For what it's worth, love these filters.  I don't, however, use them at F2.8.
I recall, however, in another forum post another user was using them at this focal length and reported no problems.
To Andrea's comment on quoted band width, this is correct. Testing that I've seen, and the way Agena advertises these, suggests the bandwidth is actually 8 to 9 nm…
Gaillard Jérôme avatar
Unfortunately for you I use them until f/3,8 with my FSQ106ED and it’s focal reducer.
I haven’t noticed any problems with such a focal ratio.
Arnie avatar
Thanks everybody for the input! I will continue my research and report about what I find. Since these are going to be installed in a remote observatory about 1700 miles away, returning them if they don't perform well at f/2.8 is not an attractive option.
Daniel Carter avatar
Arnie:
I'm looking forward to seeing how those work out Arnie. I was thinking of using fhose filters for my 135mm Rokinon and ASI2600MC. I'll be stopping down to roughly f/3.0 to f/3.5.
Arnie avatar
Daniel Carter:
Arnie:
I'll let you know!
Manuel Peitsch avatar
For what it's worth, I have a good experience with these filters (HaOiii and SiiOiii) on a Takahashi E180 with f/2.8 (FL=500mm). A couple of examples:
HaOiii filter on the Heart nebula.
A) HaOiii filter on the Heart nebula. Raw integration 50x120s exposures (60):
OK Halos that can be rather easily dealt with in post-processing:
B) SiiOiii filter on the Heart nebula. Raw integration 50x120s exposures (60):
Again, halos that are bearable
Manuel
Arnie avatar
Manuel Peitsch:
Thanks, Manuel! Nice images! I'm so glad to see how good they look at f/2.8. I'm going to order a set.
Jake Lancaster avatar
I'd like to add that I use these filters on my SharpStar 13028HNT and results have been fantastic. I don't feel like I'm losing much signal due to band shift either. They do an excellent job cutting through light pollution too! So much so that I didn't notice much difference shooting in Bortle 7 or Bortle 1!
Well Written Concise
Arnie avatar
I completely forgot I even started this thread! Since I promised to report back, here ya' go. This is my first image using the Askar ColorMagic D1 (Ha plus Oiii) and D2 (Oiii and Sii) dual-band filters with my f/2.8 SharpStar and a QHY268C color camera. Even though these are not marketed as "high-speed" filters, they seem to work well even on this scope! Of course, it will be even better once I've collected more data. This is SNR G132.7+01.3, just west of the Fish Head Nebula (NGC 896) which is itself just west of the Heart Nebula (IC 1805). I have not uploaded the full resolution image to my gallery yet, so hopefully it's OK posting this thumbnail image here.
Arnie
Well Written Helpful Insightful Respectful Engaging
Advice on duo-band filter selection for astrophotography setup
Hi, I am looking to expand my astrophotography setup with a duo-band filter. Well, possibly two depend on how the pricing goes. I’m looking to have my feel-pinions validated and possibly a correction from someone who knows what they’re talking about....
Directly addresses duo-band filter selection for astrophotography setups.
Aug 31, 2025
A Comparison - Fast vs. Large
Of the many diatribes in AP world one of the most recurrent is the role that "fast" optics plays in achieving a given result or more generally speaking whether being "fast" is better than being "large". And here is the c...
Discusses fast optics performance, relevant to f/2.8 focal ratio concerns.
Jul 27, 2025
