New version of Python script to generate target acquisition.csv file from image files in a format suitable for upload using AstroBin's upload csv dialogue
18 replies1.1k views
Steve Greaves avatar
Update 28th October 2024
I have just released the latest version of the script. v1.3.11V1.3.11 changes
1.0 Fixes bug where running the script for the first time from the installation directory would fail
2.0 Deals with the case where the filter names in the light frames have trailing white spaces.
3.0 Modified the script to take a new default parameter for the config file:
The parameter is USEOBSDATE and if set to True, the actual date of the observation session is used when aggregating data for the Astrobin .csv output. If this parameter is set to        False, then the date the observation session was started is used.
4.0 Added progress counter to the HFR processing section of the screen output
The USEOBSDATE was introduced  to allow all images captured during a session to be associated with the start of the session. The current behaviour is to associate the image with the date of capture. To use the script in this new mode set  USEOBSDATE = False in the config.ini file. This can be placed in the [defaults] section, an example is given below:
[defaults]
#FITS keyword Default value
IMAGETYP = LIGHT
EXPOSURE = 0.0
DATE-OBS = 2023-01-01
XBINNING = 1
GAIN = -1
EGAIN = -1
INSTRUME = None
TELESCOP = None
FOCNAME = None
FWHEEL = None
ROTATOR = None
XPIXSZ = 3.76
CCD-TEMP = -10
FOCALLEN = 540
FOCRATIO = 5.4
SITE = Papworth Everard
SITELAT = 52.2484
SITELONG = -0.1231
BORTLE = 4
SQM = 20.5
FILTER = No Filter
OBJECT = No target
FOCTEMP = 20
HFR = 1.6
FWHM = 0
SWCREATE = Unknown package
USEOBSDATE = TRUE
I have added a progress counter that appears as the HFR values are being calculated, it seems some of you process such large image data sets that you were not sure if the script had hung or not!
A comment based upon some user feedback:
1. If the script does not find the filter name that is used in the fits headers in the config file then it will use the filter name found in the header in the astrobin .csv file. You need to ensure the filter naming convention used in the header file exists in the config file, along with the code for that filter.
CS Steve
The scripts can be found here
https://github.com/SteveGreaves/AstroBinUploader
The release bundle can be found here
https://github.com/SteveGreaves/AstroBinUploader/releases/tag/v1.3.11
I have release an expanded and updated version of the script I released in November last year. The main focus of the original script was to ease the upload of acquisition data to Astrobin when you have many nights of imaging to report. This version extends that capability.
As before the user runs the script from the command line, where all relevant image directories are passed to the script . The script then uses the  FITS header file information along with externally retrieved data to generate the required data in the correct format. It then produces a acquisition.csv file from this data. The contents of this file can be cut and pasted into the AstroBin's upload csv dialogue. It also produces a summary.txt file that details the target observation information.
The main focus of the changes in this release is to improve the collection and reporting of observation session information. The session summary information seemed well received so I have expanded that capability.
Key features include:
  • The ability to pass multiple directories via the command line: Multiple directories can be passed to the script via the command line. All images results contained within the directories will be accumulated as part of the target.
  • Structured and unstructured directories: Image files, including calibration files, can be collected into a single directory, the root directory. The root directory structure can be flat or contain sub-directories.
  • Symbolic links to directories: Symbolic links can be used within the root directory or passed directly via the command line, this is useful when reusing calibration directories. The first directory passed should be the root directory.
  • MASTER calibration files: If MASTER calibration files are found, these will be used. If the non-MASTER versions of the MASTER files are also found, the non-MASTER versions will be ignored.Only MASTER files that can be matched with LIGHT file are processed.
  • Processing of PixInsight's Weighted Batch Pre-processing (WBPP) output: When the target is a WBPP directory the script will use the calibrated LIGHT frames as well as any MASTER calibration files found in the directory.
  • Multiple panel mosaic imaging sessions: Mosaic imaging sessions are detected from the OBJECT entry in the FITS headers. LIGHT frames are processed on a per-panel basis, whilst calibration data is processed per target.
  • Multiple site support: Multi-site collaborative target acquisition or remote observatory image capture is supported. Site location data is reverse-geocoded from HEADER location data. Data from multiple sites is reported with summary outputs that correctly identify the site contribution, for instance equipment, LIGHT, and calibration data. All data is, however, aggregated in the AstroBin.csv file for the image target.
  • Support for multiple file formats: Extracts headers for all FITS/FIT/FTS/XISF files in specified directories. Directories can have a mix of files.
  • Accepts files generated by N.I.N.A, SGPro and PixInsight
  • Sky Quality Retrieval: Recovers SQM and Bortle scale classification based on the observation location coordinates.
  • Auxiliary Parameter Calculation: Calculates additional parameters like Image Scale (IMSCALE), and Full-width Half Maximum (FWHM) from measured/estimated HFR values for each image.
  • AstroBin Compatibility: Formats aggregated data for upload to AstroBin's import CSV file dialogue.
  • Target summary: Creates a detailed summary text file for a target acquisition session. Caters for single or multi-site data as well as single or mosaic imaging data.
  • Logging and debugging file output: Creates a detailed .log file as well as data dumps to .csv file if required
  • The changes in this release are quite extensive,  so please consult the readme file before running.
    Many thanks to @Ken Bates for his detailed testing of the script and his many useful comments.
    An example run output is given below.
    I hope you find it a useful tool.
    Steve
    The scripts can be found here:
    https://github.com/SteveGreaves/AstroBinUploader/tree/v1.3.0
    The release bundle can be found here:
    https://github.com/SteveGreaves/AstroBinUploader/releases/tag/v1.3.0
    Example Session Summary Output. Single site, 2-panel mosaic, WBPP directory
    Summary.txt ouput
    acquisition.csv output
New release of this script that contains bug fixes can be found here:
https://github.com/SteveGreaves/AstroBinUploader/releases/tag/v1.3.3
Steve
Update 1st October 2024
The code can be found here:
and a release bundle can found here:
hhttps://github.com/SteveGreaves/AstroBinUploader/releases/tag/v1.3.10
there are quite a few bug fixes along with following changes:
  • Corrected utf-8 encoding error with logging
  • Reset index on group in summarise session such that group['target'].iloc[0] returns the correct value
  • formatted time output seconds are now shown to 2dp
  • allow the script to be called from an image directory and process the images in that directory but allows for calibration directories to be passed as arguments e.g. AstroBinUploadv1_3_7.py "." /home/user/images/calibration
  • output files are written to the current image directory under a directory called "AstroBinUpload". This keeps session files with the imaging data that was used to generated the data
  • modification to accept .fits files from MaximDL and ACP
  • handle the case where a fractional part of a second is present in some date-obs keyword but not in others
  • handle the case where the filter names in the .fits headers have trailing white spaces.
I have also update the readMe.md/pdf to reflect the changes. Please read this first before to run the script. I think all you need to know is contained it the file.
I hope that this is it!
If you have any questions or comments please let me know.
Hope you find this useful and of course:
Steve
David Hickey avatar
Hi Steve,
Great tool!  I just tried it and found a couple things.  When it is first run without any parameters and without a config.ini file in the directory, it bails out with an error that argv[1] is not set.  If I move a config.ini into that directory from a previous version of this script then it runs ok, it just doesn't seem to want to create it.  The second thing I noticed is the .csv file that it generates has the filter names in it (RED, BLUE, etc) rather than the index numbers that AstroBin wants.
Dave
Well written Helpful Respectful Concise
David Hickey:
Hi Steve,
Dave
Hi Dave,
The situation at the moment is:
1. Run from installation directory with no config file and no arguments passed  : -error, as you have found.
2. Run from installation directory with no config file and arguments passed : script  exits and asks user to modify config
3. Run from installation directory, config file exists and arguments passed : script  runs
4. Run from any other directory with no arguments passed : script exits with indication that arguments are needed
5. Run from any other directory with  '.' passed as the first argument but no config file : script exits and ask user to modify config
6. Run from any other directory with  '.'  passed as the first argument, config file exists : script runs
I will rectify this in my next release.
Regarding the Blue and Red etc, The code will return the filter name if it cannot read the code as a number, This can happen if  there are extra spaces after = and after the code. I though I had fixed this in v3.1.10, may be i didn't. There is a new release coming  where both these issues will be fixed. In the mean time ensure your config.ini filters section looks like
[filters]
        #Filter     code
        Ha = 4663
        SII = 4844
        OIII = 4752
        Red = 4649
        Green = 4643
        Blue = 4637
        Lum = 2906
ie just one space after the = and no space after the code
[defaults]
IMAGETYP = LIGHT
EXPOSURE = 0.0
XBINNING = 1
GAIN = -1
EGAIN = -1
INSTRUME = None
TELESCOP = None
FOCNAME = None
FWHEEL = None
ROTATOR = None
XPIXSZ = 3.76
CCD-TEMP = -10
FOCALLEN = 540
FOCRATIO = 5.4
SITELAT = 52.2484
SITELONG = -0.1231
BORTLE = 4
SQM = 20.5
FILTER = No Filter
OBJECT = No target
FOCTEMP = 20
HFR = 1.6
FWHM = 0
USEOBSDATE = TRUE
CS Steve
Timothy Martin avatar
Dude, if I haven't already told you this, I owe you a beer–or three–or twenty. This script has literally changed my life. I've always been very anal about entering accurate stats into the AB form by hand. It was really painful and took an hour or two for each image–especially mosaics shot over three to six months with 150+ hours of integration time. Now, it takes two minutes and is completely painless. Thank you!
Well written Respectful Engaging Supportive
Dude,
Thanks so much. You comment makes it all worthwhile. I was in the same boat as you, so I hacked some code to help, then I thought maybe other people would like this. But the effort involved from creating a hacked bit of code I could use to a bit of code everyone could use is unbelievable.
So to find a few of my community are helped by this is great.
Happy Christmas and of course
Clear Skies
Steve
Ps just looked at your account, you have some beautiful images.
Travis Deyoe avatar
I just found this today after wanting to up my game on accuracy in session information. This is fantastic!
A couple things that I would be curious about. I have a AAG Cloudwatcher that connects to voyager so I have ambient temp and SQM info for every image. They are saved as AOCSKYQU, AOCAMBT in the fits header. Would there be a way to use those instead of SQM and I believe FOCTEMP?
Hi Travis,
I will look at this when I do my next release, probably at the end of January.
Alpha Zhang avatar
Hi Steve,
Thanks again for the 28 Oct 2024 update—especially for the USEOBSDATE parameter and bug fixes; they’ve been really helpful.
I have a question about frame-type detection:
Most of my data are captured with Voyager, and the FITS header uses IMAGETYP = 'Light Frame' (see screenshot). At the moment, the uploader doesn’t seem to recognize this properly, as it expects something like “LIGHT” (all caps, no spaces).
For context, the uploader works perfectly with WBPP-processed files, but I still have a lot of older data that were manually calibrated without an automated processing workflow, so the headers lack many key fields. For these, I have to work directly with the raw frames, and almost all of them were shot with Voyager.
Would it be possible to add support for Voyager’s header convention (e.g., treat IMAGETYP = 'Light Frame' as a light frame) or allow a keyword/value mapping in the config file? This would make it possible to upload Voyager raw directories directly, without renaming or pre-sorting files.
Many thanks for considering this!
Alpha Zhang
Well written Helpful Insightful Respectful
Daniel Carter avatar
Do you happen to know why the CSV file isn’t generated?
When I use the —debug arguement, the CSV files are generated but the overall astrobin.csv is not generated.
The session summary shows all the correct information for the number of files and exposure information. The log file is showing that there is no Astrobin data to export. Thanks for any help!
Console Output:
📷 console_output.jpgconsole_output.jpgLogfile:
Alpha Zhang · Jul 24, 2025, 04:39 AM
Hi Steve,
Alpha Zhang
Release Notes: AstroBinUpload v1.4.5 (Beta for Testing)
Hi Alpha,
I’ve just pushed a significant update to the processing engine. This version (v1.4.5) moves us toward a much more robust, hardware-agnostic system. Please find the .zip file attached for your review and testing.
🚀 Key Improvements & New Features1. The "Alpha" Normalization (Fuzzy IMAGETYP Matching)
We have overhauled how the script identifies Light frames. Previously, it looked for exact matches, which caused issues with various capture softwares.
  • The Change: The engine now performs a substring search for the word "LIGHT" (case-insensitive).
  • The Benefit: Whether your FITS header says Light Frame, light, or Target_LIGHT, the script will now correctly identify and include it in the integration totals.
  • Safety: It automatically skips any frames marked as MASTER to prevent double-counting.
2. Dynamic Hardware Overrides
To support custom hardware setups (like those using AOCAMBT for temperature or AOCSKYQ for SQM), we’ve implemented a dynamic mapping bridge.
  • How it works: You can now define your hardware-specific headers in the config.ini under the [override] section.
  • The Logic: The script maps the custom header to the internal standard (e.g., AOCAMBT -> FOCTEMP) and then purges the original column.
  • Benefit: This prevents the aggregator from seeing duplicate or conflicting data, ensuring the final summary is 100% accurate.
  • Multi-Key Support: You can provide a comma-separated list (e.g., SQM = AOCSKYQ, AOCSKYQU) and the script will prioritize the first match it finds.
3. Integrated Diagnostic Test Mode (--test)
We have formalized the diagnostic pipeline to allow for rapid troubleshooting without needing thousands of FITS files.
  • Usage: python3 AstroBinUpload.py "/path/to/data" --test your_metadata.csv
  • Function: This allows us to simulate entire imaging runs using a CSV. It passes the CSV data through the exact same conditioning engine as real FITS files, ensuring that a fix for the test is a fix for the live production environment.
4. Speed & Performance Optimization
The "Conditioning Gauntlet" has been streamlined. By optimizing how DataFrames are handled during the transition from raw headers to finalized tables:
  • We've reduced redundant memory operations.
  • The handoff between process_directories and the aggregator is now faster, especially for sessions with high frame counts.
🛠 Testing Request
Before I release this to the wider group, I’d appreciate it if you could:
  1. Run the script against one of your typical datasets.
  2. Verify the Total Exposure Time in the .txt summary matches your expectations.
  3. Confirm that any Temperature or SQM data is populating correctly if you are using custom overrides.
Please let me know if you encounter any "Column not found" errors or integration discrepancies.
Best regards,
Steve
AstroBinUploadV1.4.5.zip
Well written Helpful Engaging Supportive
Daniel Carter · Feb 6, 2026, 09:44 PM
Console Output:
Hi Daniel,
I’ve just pushed a significant update to the processing engine. This version (v1.4.5) moves us toward a much more robust, hardware-agnostic system with improved data validation. Please find the .zip file attached for your review and testing. I think the Date-OBS fix mentioned below should resolve your issue.
We have overhauled how the script identifies Light frames to handle variations across different capture suites (N.I.N.A., SGP, Voyager, etc.).
  • Safety: It automatically ignores any frames containing MASTER to prevent double-counting calibrated files.
  • The Logic: The script maps custom hardware headers defined in config.ini to internal standards (e.g., AOCAMBT -> FOCTEMP) and then prunes the original source column.
  • The Benefit: This eliminates data ambiguity. By removing the "old" name after remapping, we ensure the aggregator only sees one clean, standardized data point.
  • Multi-Key Support: You can now use comma-separated lists in your .ini (e.g., SQM = AOCSKYQ, AOCSKYQU).
3. Date-OBS Robustness Fix
We identified an issue where inconsistent or malformed date strings in the DATE-OBS header could cause session grouping to fail or skip files.
  • The Fix: Improved the date-parsing logic to be more resilient. The script now standardizes these timestamps earlier in the "Conditioning Gauntlet," ensuring that integration times are calculated correctly across multi-night sessions.
4. Integrated Diagnostic Test Mode (--test)
We have formalized the diagnostic pipeline to allow for troubleshooting without needing to scan thousands of FITS files.
  • Function: This passes CSV data through the exact same logic path as real FITS files. This ensures that if a fix works in Test Mode, it is guaranteed to work on real data.
5. Speed & Performance Optimization
The internal handoff of data between the directory scanner and the aggregator has been streamlined.
  • Reduced redundant memory operations when handling large DataFrames.
  • Significant speed-up when processing directories with hundreds of sub-exposures.
🛠 Testing Request
Before the full release, I’d appreciate it if you could verify:
  1. Total Exposure Time: Does the .txt summary match your manual totals? (Verifies the Alpha & Date-OBS fixes).
  2. Data Population: Are Temperature, SQM, and Gain showing up correctly in the final report? (Verifies the Override logic).
Please let me know if you encounter any "Column not found" errors or discrepancies.
Best regards,
Steve
Steve Greaves · Jan 13, 2025, 10:29 AM
Hi Travis,
Hi Travis,
I’ve just pushed a significant update to the processing engine. This version (v1.4.5) moves us toward a much more robust, hardware-agnostic system with improved data validation. Please see the Dynamic hardware override section I think this will solve your issue.
🛠 Testing Request
Best regards,
Steve
Update 8th February 2026
I have just released the latest version of the script: v1.4.5.
v1.4.5 changes
1.0 Significant Performance Boost
I have overhauled the I/O and processing engine. The script is now significantly faster, especially when scanning large datasets or running on high-speed storage like RAID 0.
2.0 Robust Header Aggregation
Fixed a bug where the script would crash if certain keywords (like Rotator angles) were missing from your FITS headers. The script now intelligently "injects" missing data using your project defaults from the config.ini, ensuring the processing completes every time.
3.0 Cleaner Session Summaries
Resolved an issue where missing hardware data would output as "nan" in the equipment inventory. The summary now cleanly omits any fields where data is unavailable, providing a much more professional text output.
4.0 Enhanced Real-time Progress Feedback
I have added a new real-time scanner counter. You will now see progress during the initial file scanning phase as well as the HFR calculation phase. This ensures you know exactly what the script is doing during intensive disk operations.
5.0 Hardware Overrides and Keyword Sync
Improved support for varied hardware naming conventions. You can now use an [override] section in your config.ini to map custom hardware keywords to the script's internal variables. I have also synchronized the rotator naming convention to ROTANTANG for better consistency across all platforms.
Example of the new [override] capability in config.ini:
```ini
[override]
# Map your specific hardware keywords to internal variables
FOCTEMP = AOCAMBT
EXPOSURE = EXPTIME
A note on the new Performance:
The speed increase is quite substantial. For those of you processing hundreds of images, the scanning and aggregation phases should now feel nearly instantaneous compared to previous versions!
CS Steve
https://github.com/SteveGreaves/AstroBinUploader/releases/tag/v1.4.5
coronalite avatar
Hi Steve,
I am very interested in your program, but I am running into issues getting started on my Windows 11 PC.
Installed Python from the Microsoft Store (V3.14.4.).
Downloaded your v1.4.5, and extracted files to a new folder in my local Documents folder, and then ran your instruction in Step 4 (pip install -r requirements.txt) of the Readme.MD. The first time - I received an error that was to the effect it could not find vswhere.exe. From some Googling I found this is related to MS Visual Studio. So - went to Microsoft Store and installed Visual Studio (without any “work packages”). Now - I have a vswhere.exe in the Windows Program Files(x86) directory (C:\Program Files (x86)\Microsoft Visual Studio\Installer).
I then ran Step 4 again (after a restart) and now the error is: “..\meson.build:1:0: ERROR: Could not parse vswhere.exe output”.
The only config file in the AstroBinUpload folder is the example file (config.ini.example) that came with the download.
Appreciate if you could point me in the right direction.
Thank you!
coronalite · Apr 14, 2026, 01:29 AM
Hi Steve,
Thank you!
Hi coronalite
Thank you for the detailed description — this helps a lot! The root cause is Python 3.14, which is a very new pre-release version. Packages like numpy and astropy in the requirements don't yet have pre-built Windows installers ("wheels") for Python 3.14, so pip falls back to compiling them from source code. That's what triggers the meson.build and vswhere.exe errors — you'd need a full Visual Studio C++ build environment to make that work, and it's more trouble than it's worth.
The simple fix: install Python 3.11 or 3.12 instead.
Here are the steps:
  1. Uninstall Python 3.14 from the Microsoft Store (Settings → Apps → search "Python").
  2. Download Python 3.12 directly from the official site: python.org/downloads — choose the "Windows installer (64-bit)" for version 3.12.x.
  3. During installation, tick the box "Add Python to PATH" — this is important.
  4. Open a new Command Prompt, navigate to your AstroBinUploader folder, and run:
    python -m pip install -r requirements.txt
    This time it should download pre-built wheels and complete without errors.
Python 3.11 and 3.12 are the versions all the dependencies are tested and packaged against. Python 3.14 will be supported in time, but not yet.
Let me know if you hit any further issues!
Best regards,
Steve
Well written Helpful Respectful Engaging
coronalite avatar
Thanks Steve - appreciate the additional guidance which solved the issue.
Fantastic program and a real time saver!
