Translucent Stars: What Causes This?
Daniel EricksonJohn Hayes
24 replies516 views
Daniel Erickson avatar
Probably a simple question with a simple answer, but this hasn't happened to me before.
After stacking my subframes in Siril, I opened the .fit file, did a photometric color calibration, DBE and then saved the file as a 16bit .tif file. When I opened the file in PS, my stars are all translucent, as shown below. What causes this effect? The only thing different in these subs was a longer exposure time. Any thoughts? Thanks for your help.
Well written Engaging
Martin Sebestyen avatar
Seems to be out of focus, what does each sub look like?
D. Jung avatar
The pink core can be due to partially saturated Bayer pattern. If only two of the three colours are saturated you often get this pink colour as the white balance only works properly if all colours are not saturated.
Well written Helpful Insightful Concise
John Hayes avatar
I don’t know what a translucent star is, but two things immediately come to mind here:
1) Did you check the registered subs to make sure that everything was perfectly aligned before you stacked the data?
2) If this were a single sub, I be telling you that you have some serious coma — probably from a misaligned secondary.  Are you sure that your optical system is capable of producing circular pinpoint star images?
Helpful Insightful Respectful
D. Jung:
Thanks, D. Jung. This explanation seems to make sense to me--at least I understand it--although I'm not sure how this might happen (not much on optics and a relative newcomer). How might this occur during imaging or afterwards in post? Thanks again.
Martin Sebestyen:
Thanks, Martin. Focus is pinpoint perfect in the subs.
John Hayes:
Thanks, John. Translucent here is my description of the star being...well...kind of fuzzy and almost see-thru...Everything seems registered just fine. Optical system is a quad apo and has been perfect up until now.
D. Jung avatar
Daniel Erickson:
WB is applied globally, but locally you can of course have areas close to or already saturated, especially in the cores of stars.
So if you have a bright star, where the color channels are close to saturation or are already partially saturated, and you apply your WB gains, you shift the colors.
Assume your pixel has R:0.9, G:0.9, B0.8 (a somewhat orange color, with max value of 1.0) and you apply WB gains of r=1.4, g=1, b=1.25, you get:
R:0.9*1.4=1 (clipped from 1.26)
G:0.9*1   =0.9
B:0.8*1.25=1
which is now a nice pink.
D. Jung:
Daniel Erickson:
G:0.9*1   =0.9
B:0.8*1.25=1
Thanks. It would appear to be over saturation, and I did increase my exposure, so this helps a lot. Thanks!
John Hayes avatar
Daniel Erickson:
Well from what I see in the image that you posted you've got a problem somewhere.  If your quad-apo is perfect, then you've got a stacking problem and if everything is registered fine, then you've got an optical problem.  I suppose that one other possibility is that you've got a small color registration mismatch in the stack combined with defocus (or other optical aberration) between the channels.  Carefully blinking through the color data stacks might tell you exactly what's going on.
John Hayes:
Thanks, John. Your explanation is really clear and the charts help. For the moment, let's assume that the software is fine (I'm using a pre-made script in Siril) and that the issue is optical... Being new to all this, how do I go about checking for and fixing optical issues? I don't expect a long treatise of course--you've been generous enough--but if you can point me towards something to read/research, I'd be grateful. Thanks again.
John Hayes avatar
Daniel Erickson:
There is a lot to identifying and fixing optical problems but broadly speaking, the problems fall into two classes:  1) Aberrations due to fabrication errors or design limitations and 2) Alignment induced errors.  Problems in the first category can be very difficult to resolve without getting the manufacturer involved.  The trick there is to know when you've correctly identified a problem that really is due to a manufacturing error.  Simply because you might have a scope with a sophisticated design that was very expensive does not mean that it will produce perfect images.  Understanding how to test and evaluate optical performance  is a big subject but one good place to start might be with Suiter's book on star testing.
Issues in the second category include mostly misaligned, tilted, or improperly spaced components, although it could include something like a multi-element objective with lens components that are misaligned with respect to each other.  These are things that are ultimately fixable without having to remanufacture parts.  In this case, you have to go through all of the specs and measure everything with respect to the specified spacings.  Suiter's book can also help determine what aberrations you might have though star testing.  This is an area where hooking up with someone who has more experience with this stuff can be really helpful. There is almost no way that I can give a short answer here that would be of much help without addressing a very specific problem.
Finally, I've asked a couple of times about your registration accuracy but forgive me,  I haven't seen a clear, definitive answer.  Blinking through your stack, zooming into the center and four corners while you cycle through the aligned stack can be very revealing.  Have you very carefully examined each of the aligned subs before you did the image integration?  This is where small errors that are easy to miss can turn into very big problems.  Believing that the stacking process is correct is not the same as actually carefully examining the data.  Perhaps I'm misinterpreting your answers (and forgive me if that's the case,) but this is a very important step when you run into problems like this.
Best regards,
Well written Helpful Insightful Engaging Supportive
Björn Arnold avatar
Just to add a few things that cross my mind. I assume that image snippet is shot with your 183M?
- Since it's a OSC, I am wondering of there could be an issue with the debayering, leading to color misalignment?
- Do you really match the required backfocus distance of the RedCat?
Björn
Björn Arnold:
--Yes, shot with the 183.
--I suppose it could be debayering, but I myself wouldn't know...not knowledgeable enough.
--Yes, I used the requisite spacer and adapter to get to the prescribed 55mm, although the Redcat is a petzval so spacing doesn't matter like it does with other scopes, I'm told. I focus using the bahtinov mask and the pattern is quite distinct and the stars of the preview images are crisp and sharp.
John Hayes:
Daniel Erickson:
Best regards,
Thanks, John. I appreciate the time you put into this. I was specifically wanting to know about the optical possibilities because in a PM I began working with someone else who knows Siril quite well about the registration and stacking issues. I wasn't trying to dodge your question.
But, since you mention it, please remember that I am an ignorant beginner and--quite honestly--I'm feeling rather beginner-stupid right now. As such, I tend to blunder my way through to an image. I feel quite confused and  I'm also frustrated, because I want to do good work and I can't learn fast enough to fix problems, it seems... Still, my process, so you understand it, is to shoot my subs (after focusing, etc. etc.). Once I have those files I go through each one looking for bad ones--ones with airplanes and satellites, odd lighting or just plain strange looking frames. At my level of expertise I suspect I don't notice much more than the obvious, I admit. I get rid of every one that doesn't look perfect to me at this time in my own understanding of what constitutes 'good enough'. I then put all my calibration frames (darks, flats, flat darks) in folders with the lights in theirs, and execute a Siril script that *automatically* pre-processes the files, registers and stacks them. Siril is nothing more than a black box to me at that point, so if something is wrong there, I wouldn't know it--hence working with a Siril expert on the matter. The resulting .fit file I then do the photometric color calibration and background extraction on... and here we are.
One reason I thought it might be an optical issue is the star you labelled "registration error". Those occur from the edge of the frame to the center--i.e., everywhere. Perhaps the plate on the back of the scope, which has four tiny set screws, is misaligned...but I'm clueless about how to diagnose that and to know the best way to fix it (turn the screws, that's it). That particular star also has a pink core. You would say then, that it, too, is also overexposed? As for the stars you label as 'coma', I thought my RedCat (quad apo petzval) might actually have avoided that issue entirely. I'm wondering whether it's possible that the 'coma stars' are actually mis-registered (and overexposed) so that one frequency of light is brighter and gives the appearance of coma... just a thought.
Perhaps in the interest of my sanity and your time, I will shelve this data for the time-being. I need to shoot some more data on the same target and same general set of conditions to see if whatever this is recurs. I also want to try decreasing exposure. I've had some ongoing discussions with @Björn Arnold . I may learn something from my exploration of Siril, too.  BTW, you mention "Suiter's book". I don't know what reference you're referring to.
Thanks for all your help John. I don't know that I'm any closer to knowing what's going on at the moment, but I am learning a lot.
Kindly,
Daniel
Helpful Respectful
John Hayes avatar
Daniel,
Ok…and good luck with it.  As for the book I mentioned, go to Google and type in “suiter’s book on star testing” to see what you get.  You can often learn a lot by asking Google to help you out.
John Hayes:
Daniel,
Ok...and good luck with it.  As for the book I mentioned, go to Google and type in “suiter’s book on star testing” to see what you get.  You can often learn a lot by asking Google to help you out.
Well, what'd ya know? A used-steal at Amazon for $242. :-) Of course you can find it cheaper...
John Hayes avatar
Wow!  That's crazy.
FiZzZ avatar
Hi Daniel,
total beginner also here,i however had a couple of problems with 2 different refractors and the images/pictures were extremely similar to yours.
Both of the cases were due to my mistakes handling the equipment, with a Meade ETX 80 i messed with the focuser to make it more smooth but i ended up misaligning it.
With a small refractor guide scope instead i forced too much the "micro focuser" (not helicoidal), as i did not understand how it was working, and ended up on removing it from the factory made lodging.
Again a misaligned focuser and the same "coma looking" stars all over the field.
so my question, after reading this statement :
Daniel Erickson:
is if you already messed with the focuser or the "screws" (the tilt adjuster).
the best way however is to star test your telescope.
also :
Daniel Erickson:
I went through several of your pictures, finding the same aberration in almost all of them (easier to spot in the pictures made with the ASI), i point it out just to be helpful for the starting time identification of your problem.
in some of them the "coma like" tails or the "direction" of the chromatic aberration seem to be unidirectional (tilt) in some of them they seem to represent the typical field distortion of an unflattened refractor (weird for the Redcat)...
Good luck
Rich Sky avatar
In astap, using ccd inspector, you could understand the level of tilt and off axis abberation. You may learn additional information on your setup.
In startools processing group, a few examples are there. Good luck resolving your issue.
Richard
Alberto Ibañez avatar
Hi Daniel,
I agree with all the recommendations given here, but I think that your main problem is, as pointed, that your star cores are not R=1, G=1, B=1. This is very common after performing PCC, as you did.
Maybe I'm going to open a can of worms, but my opinion is that you should clip your star cores (only the cores) just after color calibration, to keep them pure white, as they should be. Otherwise, when applying color saturation, they will become colored.
Hope it helps.
Alberto.
Hi Daniel,
Daniel Erickson:
also :
Daniel Erickson:
Good luck
Thanks for the nice response, I appreciate it. I haven't messed with the tilt adjuster screws at all, but that may still be an issue. I am going to take off the filter and the camera, clean everything (there are some dust motes on some subs), including the grooves for the filter and camera, and give it a try again. Perhaps one of those two things is ever so slightly off. Thanks again for taking the time to look at my old images and helping to ID the issue.
Daniel
Well written Respectful
Rich Sky:
Richard
Thanks! I don't know ASTAP, but I do see that it's Mac compatible (sometimes a problem finding tools that are Mac-compatible), so I'll grab it and take a look to see if it can help with my issue. Thanks Rich!
Alberto Ibañez:
Hi Daniel,
Hope it helps.
Alberto.
Alberto, thanks so much for this suggestion...I don't mind 'cans of worms', provided I can digest them, so please forgive my next question...how would you suggest I "clip (my) star cores just after color calibration". Happy to give everything a try!
Thanks again, so much!
CS, Daniel
Respectful Supportive
Rich Sky avatar
Hi Daniel,
Here is the astap ccd inspector of your star image. It shows a tilt of your optical train at 63% and an off-axis abberation of 1.23 HFD.
If I compare to my sct, the tilt of my sct varies between 5 and 9%, which I was told was ok, not excellent, but good.
I don't know what type of scope you have, if it is a sct, collimation might help...
what is obvious, one side of all of your stars is color saturated (tilt ?)
It would be best, if you took one of your fits file and do it yourself, I am only demonstrating that you may have an issue.
Hope this helps. and clear skies Daniel.
R
(and stars should have colors... and should be color saturated...)
Rich Sky:
Hi Daniel,
If I compare to my sct, the tild I have is between 5 and 9%, which I was told was ok, not excellent, but good.
what is obvious, one side of all of your stars is color saturated,  and usually that is a tilt issue...
R
I can't pretend that I understand the optics and jargon, but I appreciate the pointer to what appears to be an obvious problem... I'll get the SW and check out some of my .fits... then remains the question how to fix it with my two thumbs. :-)
Daniel Erickson:
Alberto Ibañez:
Hi Daniel,
Hope it helps.
Alberto.
CS, Daniel
Sure,
You have to measure your star cores with Histogram Tranformation, and clip them using the lower value.
I suggest you to check if clipping has been too much by applying an Auto STF before and after the process:
If this leads to excessive clipping on the halos of the stars, you can make a star-cores mask to protect all but not the cores.
WBPP Integration creating star artefacts (non symmetric) - or am I wrong?
I need some help with this. A "standard" WBPP processing of the M42 has created (to me) strange artefacts on the biggest stars in the Master Light file: Facts: Askar FRA400 och ASI2600MC, 80 x 60 sec exp. 30 Flats and 30 Dark Flats. To me i...
Star artifacts from integration processing could relate to translucent star appearance issue.
Feb 5, 2023
Fullwell Capacity – Does it really matter?
Hi! With CMOS cameras you are being told to use a readout mode with a high fullwell capacity (FWC) for deep sky objects, so your stars won’t burn out that quickly. This is one of those things you usually don’t question, because it sounds plausible. H...
Fullwell capacity affects star saturation; longer exposures may cause similar effects.
Apr 15, 2023
SPCC Thoughts and Questions
After reading a related post on some problems using SPCC, it gave rise to some questions I have sort of assembled upon my recent adoption of this feature in PI. Please feel free to dump on me over these questions and challenges below, but I am not an...
SPCC color calibration problems might explain post-processing star appearance issues.
Mar 10, 2023
