Help ASI 1600mm PRO- Darks' mean ADU unstable
11 replies337 views
Anthony Saab avatar
Hello, I've recently had some issues with my ASI 1600mmPRO that I noticed while taking 10 minute darks at gain 200. The camera is not 1 year old yet. Before I explain what I did, all the test were done in exactly the same conditions, same laptop etc... I tried using different USB cables, different capture software and a different PC with the same results. My main issue is that the mean ADU of my darks are not stable. They start at ADU 920 for example, go up slowly till about 970 and then drop back to 915 or so. This does not happen at gain 75, only gain 200 (did not test other gains yet). So unless I need to test more on gain 75 and give it more time, so far the issue appears only in high gain but that could be inaccurate. I have plotted a graph showing the mean value of each frame for 5 minute and 10 minute darks at gain 200. The x_axis is the frame number. The y_axis is the mean ADU value. I compared these darks with my older darks, and the old darks' mean was extremely stable (+- 1 ADU difference between frames). The cooler power seems to be stable with no big fluctuations (just 1 or 2% max and it rarely changes). I am currently in the process of taking 3 minute darks at gain 200 to see if the same trend happens. So far the mean appears to be stable. I will update this info once capture has finished. Still waiting for ZWO support to reply so I'd appreciate if anyone has any insights or if someone else had this issue just so I save myself some time and trouble. Cheers,Anthony
matthew.maclean avatar
I certainly have no idea, but I think I would open a couple of the brightest and darkest frames, stretch them, and see if there was any pattern to the brightness differences (e.g. one particular side, one corner, some repeatable pattern, etc.)? Any chance lighting nearby was changing and could have leaked into the camera during that particular run? I just happened to have taken a bunch of darks on my camera last winter and realized after I thought I was done that my filter tray doesn't seal perfectly tight and all my darks had a bright band along the edge where the tray comes apart…lesson learned there….
Anthony Saab avatar
I certainly have no idea, but I think I would open a couple of the brightest and darkest frames, stretch them, and see if there was any pattern to the brightness differences (e.g. one particular side, one corner, some repeatable pattern, etc.)? Any chance lighting nearby was changing and could have leaked into the camera during that particular run? I just happened to have taken a bunch of darks on my camera last winter and realized after I thought I was done that my filter tray doesn't seal perfectly tight and all my darks had a bright band along the edge where the tray comes apart...lesson learned there....
Hey Mathew, I'm currently repeating the tests in a completely dark room with the AC on just to make sure it's not light leaks not drastic ambient temp changes. I will get back with the results.
Padraic Moran avatar
Hi Anthony, I had a similar issue just last week, with asi1600mm darks at gain 200 coming out with varying ADUs. Needless to say, they didn't calibrate well!
I re-did the run, in a fully-darkened room, and all worked well. I can't say that it wasn't 'user error'.
I don't remember ever having this issue with darks at gain 139. Interesting to hear how you get on with your next batch.
Well Written Respectful Concise Engaging Supportive
Anthony Saab avatar
Padraic Moran:
Hello! Yes I'm currently taking the darks in a completely dark room with the AC on. The mean seems stable (between 912 and 916) but I think I'm going to have to give it some more time to make sure the mean changes are not happening randomly. Hopefully it was user error related to light leaks or ambient temp changes.
Anthony Saab avatar
So I repeated the test today, and so far it's not going so well. Yesterday the mean was stable at around 912 (around 35 frames). Today, with the exact same conditions (same room, completely dark, AC on same temperature, same cooler power %), I'm getting a mean of 933 and slowly rising. I'm not sure what to do now…
Then that starts to sound like a camera problem to me unfortunately…..
the only other thing I could think to ask would be is this near the maximum limit of the cooling (~100% TEC power)?  Is it seeming to maintain the temperature you set easily?
Anthony Saab avatar
Then that starts to sound like a camera problem to me unfortunately.....
The cooler is running at around 58%. The mean appears to have stabilized at 939. So yesterday it was stable at 913, today at 939. I know that CMOS chips' electronic signature changes pretty rapidly, but I'm not sure if that's what's happening in my case.
Still no answer from ZWO...
You definitely need to hear from them as 26ADU does sound non-trivial. Only last obvious thing to check is the “offset” didn’t get changed between the two days somehow? (Hopefully by 26 counts...)
Also, they are good about providing a dark-current plot for a lot of their cameras:
https://astronomy-imaging-camera.com/product/asi1600mm-cool
I think that is your camera so about half-way down the page gives the dark e/s/px (log scale) and you could deduce approximately what temperature change would be needed to account for the increased 26ADU. It doesn’t solve your root issue obviously, but it might tell you something.
Anthony Saab avatar
No I'm using the same offset of 50 smile I do need to find the root of the issue as you said since it might be hiding some defect that might cause some other worse issues down the line, especially since the camera is still under warranty.
Markus A. R. Langlotz avatar
Hi Anthony,
what do your plots show? Is it the mean value of ADUs in a darkframe over the number of darkframes? So this would show a certain time-dependency.
Maybe, you just see an overshoot/undershoot in the TEC regulation, think about 6 degrees doubling your thermal signal, so 5% more could translate to
small thermal instabilities below a tenth of a degree.
Starting the exposure batch even after stabilzing the sensor thermally, will bring in fluctuations, as you now start the sensor work and read it out on a regular basis, so the chip will become warmer and there the TEC regulation has to counteract.
To get real stable darks, let the TEC stabilize, start a batch of lets say 100 darks and withdraw the first 50 darks.
Markus
Helpful Insightful Respectful
Anthony Saab avatar
Markus A. R. Langlotz:
Hi Anthony,
Markus
Hi Markus,
I thought about removing the "bad" darks and just calibrating with the stable darks, however, this unstable behavior will also translate to my lights especially if it's an electronic issue changing the offset. The result would probably be bad; one issue might be that the flats would over or undercorrect if I'm not mistaken.
Fullwell Capacity – Does it really matter?
Hi! With CMOS cameras you are being told to use a readout mode with a high fullwell capacity (FWC) for deep sky objects, so your stars won’t burn out that quickly. This is one of those things you usually don’t question, because it sounds plausible. H...
High fullwell capacity affects dark frame stability and thermal behavior.
Apr 15, 2023
ASI1600MM Pro: impossible to get good flats?
Hello everybody! I'm creating this topic here as the thread on Cloudy Nights is not getting much attetion. I'm sure some of the more experienced astrophotographers might know the fix to this issue, but until now, no one could find something s...
Same camera model; troubleshooting calibration frame issues likely relevant.
Sep 16, 2022
Bias frame gradient
I have a new ASI294MM Pro (monochrome). I took 100 bias frames at gain 120, offset 20, -10C, and 1x1 binning. The statistics are consistent across the raw frames I examined. However, I extracted the gradient across several of the unstacked frames usi...
Bias frame stability issues similar to your dark frame ADU drift.
Mar 25, 2023
Question about over-correction with flats
Hi, I use an ASI 1600 MM cool Pro CMOS camera. On a 16-bit scale (65550 total adu output) I try to keep my Flat adu to about 1/3 of total, or about 20,00 - 24,000 adu. I understand that this will keep the flats in the linear range of the camera's...
Discusses ASI 1600mm PRO camera issues; may reveal related calibration problems.
Mar 24, 2020
ZWO 183 MC Pro question
Hello I`ve recently acquired a ZWO 183 MC Pro. I image under Bortle 6 skies, not great but certainly useable. I`m also using the Skytech L Pro filter. I`ve yet to use it but i`m wondering if anyone else is using the same camera? I have a Samyang 135 ...
Different ZWO camera model; gain/offset settings may not directly transfer.
Oct 9, 2019
