New Gear Photography recommendation
4 replies132 views
Yogs avatar
Hi Everyone,
I am new to Astrophotography. I love the photos and decided to join the hobby.
I have a full frame Nikon D750 camera, and I have ordered Explore Scientific 102mm triplet.
Few questions to get me started please:
1. Do I need to use extension tube to connect my camera to help focus (I have t-ring and T2 focal adapter to connect to telescope)?
2. For close-up moon photography, do I need to connect my camera to eyepiece via diagonal?
thanks in advance.
Yogs
Pablo Petit avatar
Hello Yogs, and welcome to this amazing hobby !
To answer your two questions :
1/ In order to have round star all over the field with a refractor, you will need the apropriate field flattener, that sometimes also doubles as a reducer. Once you have that, you will have to have a certain distance between the end of the reducer and your sensor (which is almost always 55mm and is called backfocus). It is usually simple to acheive the 55mm with a DLSR, most parts are made to give that amount of backfocus.
2/ In don't see a case where a diagonal would help you as it just adds an unecessary mirror in your light train that will only disturb your images. You might need a barlow to get more focal lenght for the moon thought.
Hope this helps
Helpful Concise Supportive
Yogs avatar
Pablo Petit:
Hope this helps
Thanks Pablo! This is helpful.
In regard to flattener/reducer, won't that degrade the quality as my camera is full frame and crop sensor?
thanks,
Yogs
Pablo Petit avatar
No actually it will be the opposite, without a flattener your stars will become elongated the farther they are from the center, and look like this :
And because a full frame is a big sensor you will notice it even more. Now, it might be possible to have some vignetting because of the flattener on a full frame, but overall, a flattener will be a good investement.
Also, if i'm right the flattener you will have to buy for your ES 102mm is this one :
https://www.bresser.de/fr/Astronomie/Accessoires/Correcteurs-Reducteurs/EXPLORE-SCIENTIFIC-3-0-7x-Reducteur-Correcteur.html
Which is also a 0.7 reducer that will bring your focal ratio from 7 to 4.9 and will reduce your exposure time by 2, which is a lot, so its a big advantage.
Yogs avatar
Pablo Petit:
Thank you again Pablo! Good to understand the stuff. I will get a reduce/flattener to start getting good pictures.
Scope to camera adapter for Epsilon 160ED
I have never imaged with a Newt. So I ordered the E-160ED and I will be waiting for it for, probably, many weeks yet. Or months I don't know what connects to what on it, admittedly. I am trying to get parts and accessories I will need ahead of ti...
Discusses scope to camera adapters relevant to telescope imaging setup.
Nov 27, 2022
CC6 + adapters
Hi, Does anyone in here have a CC6 and could tell me how you solved the adapter/extension part to achieve back focus? My current setup is by using all three (3) M90 extension tubes that came along with the telescope, which gives me merely 100 mm of o...
Addresses adapter and extension tube solutions for achieving proper back focus.
Sep 10, 2022
