Help with remote setup for the first time
1 reply89 views
IzaakC avatar
Hello,
I have just begun setting up remote control for the setup for the first time but are having problems with the software.
Setup Details:
  • SkyWatcher AZ/EQ 6 Pro in EQ mode, with SkyWatcher Wifi dongle
  • Indigo server v 2.0-144 / IndigoSky on Raspberry Pi 4 (1 GB) / SynScan Mount driver installed and connected
  • Windoze 10 machine / Chrome browser v89.0.4389.114
  • SynScan App Ver Pro 1.19.0 / Motor Board 3.6.22
Basic issue we are struggling with is: the mount position as reported in SynScan-App is correct (it is pointing at that star - Achernar in this case, but that is irrelevant to the issue), but the apparent coordinates that appear in the IndigoServer are offset by some value.  The attached screen shot illustrates the point:
  • RA/Dec: 1:38:30 / -57:07:44 for Mount SynScan-App
  • RA/Dec: 1:54:42 / -57:01:04 for Indigo (and APT that gets data from Indigo shows the same values)
Same problems are evident in Alt/Az
So the values are close .. but never the same .. always offset by some amount, as per above.  For any session the offset is (I think) consistent (have not tested enough yet to know).
My hunch (at the moment) is that there is some zero error at start up - Indigo is assuming the start is at some actually exactly zero position, which it never is, and the error is being "retained" somehow. But why doesn't the Indigo Server just read from the mount the actual coordinates?  I don't know .. tearing my hair out.  Please help.
Thank you very much for assistance,
Izaak
urban.astronomer avatar
Hi Izaak,
You could try two things:
1. Make sure all software are using the same standard for Ra/Dec, that is: J2000 or JNOW. Differences here can lead to a small discrepancy in accuracy between software pacjkages used.
2. More likely, you are struggling with the same issue as I had with the SkyWatcher AZ/EQ 6 Pro mount. It has two sets of encoders which are not always in sync.  You should try to turn off encoders in EQMOD, as you do not need the mount's "freedom find" feature in a remote observatorium.  I have previously described this procedure in detail in the last post of this thread:
https://www.astrobin.com/forum/c/astrophotography/equipment/skywatcher-az-eq6-mount-encoders-and-eqmod-in-conflict/
Since then, the mount works like a dream.
Good luck!
-Martin
Helpful Insightful Respectful Supportive
Strange mount behaviour while guiding
Hi out there, I need some suggestions or possible solutions for a strange problem I had during the last weeks. I while ago, I bought a Skywatcher EQ5 Pro mount for a second setup beside my EQ6-R and for about 6 months everything seems to work fine. I...
Strange mount behaviour while guiding — Author has SkyWatcher EQ mount; topic discusses similar mount issues.
Aug 10, 2022
Tuning the EQ6-R (bearing replacement) – Experience Report
Hi everybody! If you have ever thought of tuning your EQ6-R – or any other similar Sky-Watcher mount – this might be interesting for you. Last weekend I did a bearing replacement on my EQ6-R, according to the excellent Youtube video by “Astrobloke” G...
Tuning the EQ6-R (bearing replacement) – Experience Report — Author uses EQ6 Pro mount; topic covers EQ6-R maintenance and tuning.
Mar 20, 2023
