ZWO Filter Wheel not holding center Position during Imaging
9 replies541 views
Rick Fair avatar
=MsoNormal Slipping during imaging session.  This issue is that the filter has started to slip when imaging.  The filter is not lined up with the camera sensor and shows a line in image. When I manually rotate filter it centers back up and image is ok, but after about 5 300 sec images it starts to slip and filter moves and there’s a dark edge of on image showing the side of filter wheel filter frame. Any ides on how to fix tks
Bruce Donzanti avatar
You can recalibrate it and see if that fixes the problem.   If it is new, just return it and get a new one and not aggravate yourself over it.
Rick Fair avatar
I did recalibrated it several times, also I got it from ZWO Directly. Ive created a support ticket. I thought if anyone else had one with these issues there my be a simple fix…
Andrew Barton avatar
I have had similar issues in the past. There is a setting in the driver or your acquisition software that will tell the filter wheel to move in only one direction. I find this setting makes the filter wheel perfectly consistent. I have had this problem with filter wheels from other manufacturers as well.
CS, Andy
Brian Puhl avatar
Does it have 7 filters in the wheel?  You could be unbalanced if there isn't a full filter set in there.
Bill Gwynne avatar
Rick, the only time I've ever had mine not work correctly is when a filter was screwed in too far and it was scraping on the other side. I've never had it move out of position once it was set but would be curious to know what the fix is when you get it.
Bill
Eyecon avatar
Brian Puhl:
@Rick Fair I have the same EFW with screw in 2” filters and I’ve only seen this kind of behaviour only when the wheel is unbalanced just as Brian suggested. Did you try redistributing the filters more evenly around the wheel?
Concise
Arny avatar
Rick Fair:
I had the same problem and reason in my case was, that I had 2 empty slots in the 7x2" and did not use them opposite of each other - so a disbalance in the filter wheel pulled the wheel down leading to the same effect.
Adel Kildeev avatar
I had a similar issue with EFW-5, but the problem was in the non-standard filter (too thick), after the filter’ s replacement works fine.
Mickaelle (kaelig) avatar
If you add a thick ring, you could change the mechanic position of the wheel or rotate your optic train in the eyepiece holder. It could help to change the move of your filter wheel. It is just an idea.
flats overcorrecting in siril?
=MsoNormal I shoot with a Canon DSLR/Tamron zoom, and collect lights, darks, flats, and flat darks each session. I shoot from a somewhat light-polluted suburban location (Bortle 7?). Here is an example sub of CrB using the Histogram autostretch view ...
Filter alignment issues affect flat calibration frames and image quality.
Jun 26, 2025
extreme offset vignetting in flats and lights
This issue has persisted for a while now through at least 3 set ups and I honestly cannot for the life of me figure out what is causing this. Here is an image of one of my flats which displays the extreme offset in vignetting in my imaging train whic...
Dark vignetting edges in images caused by optical misalignment similar to filter slipping.
Nov 9, 2025
Dark bands at top and bottom of Minicam8M
EDIT: QHY support responded with the following statement: “We can basically confirm that this phenomenon stems from the light-gathering limitations of the Minicam8M sensor structure at extremely fast focal ratios (F4), rather than from mechanical obs...
Dark bands in images from optical component misalignment or obstruction.
Nov 8, 2025
