Markus avatar
Dear friends
It sometimes happens to me that I can't finish the last step of the alignment process of my CGX, the mount alignment with the knobs, because the four ovali holes for the azimuthal movement are at their limit stop. And this although I have made a precise alignment to the North of my tripod with the help of a compass. I then have to move the whole equipment and start the complete alignment process again.
Is there a trick to avoid this? Could it be a solution to first do a quick alignment (as the software proposes this possibility for observation), align the mount with the knobs and ev. correct the position of the tripod and then start the definite and complete alignement process?
Thanks for your help!
Kind regards
Markus
Helpful Respectful
Björn Arnold avatar
Hi Markus,
Given your description, I assume you are talking about polar alignment?
There is no way around that when you set up your mount, you have to place the tripod such that it is already oriented towards north within a few degrees. Also make sure it's leveled (when it's nicely leveled, the Alt adjustment will be minimal from setup to setup). Hence, bring a compass with a bubble level included.
The next step depends a bit on your mount. When I'm placing my mount on the tripod, I'm setting the Azimuth knobs such that I am centered with the tripod direction. Now, it depends on the way your mount does polar alignment. Some have a polar scope or polar alignment camera. Follow that according procedure but if you had the tripod set up in the way I described above, you'll only have to make a little Az adjustment (certainly within the limit range of the "knobs" ) and most of the times I have to do only very little Alt adjustment.
CS!
Björn
Markus avatar
Hi Björn!
Many thanks for your answer! It seems that I have to be even more careful with the orientation of the tripod with the compass. Obviously, it's difficult to do so within two or three degrees. My knobs are well centered. Maybe I must buy another compass, mine is made for "Orientierungslauf" (whatever this is in English…smile.
Kind regards
Markus
Respectful
Björn Arnold avatar
Hi Markus,
My best compass is the one that came with my Meade LX85 mount and OTA. In the beginning it looked cheap to me (don’t be distracted what vendors want for it) but now, after I have tried a more dedicated compass, I value my „Meade“ compass. The needle is more than 10 degrees wide but it’s accurate and I am always within the limits of my mount‘s Az adjustment range (I think it’s +/-6 deg).
I also tried to see how the smartphone competes but sometimes North is here then there. Long story short: before you buy a new compass test the current one.
Clear skies,
Björn
Helpful Respectful Concise
John Pungello avatar
Hey Markus. Do you have a finder scope or something similar to do your star alignments on your scope?  If so you can make sure your bolts are centered in the oval slots and physically move the tripod until Polaris is close to center in your finder. Then do your polar alignment. You should have plenty of play in either direction.
If you don't have a finder get as far as you can in the alignment process. When you run out of room in the slots give the front leg of your tripod a little nudge in the direction you need to go, maybe 2-3 MM. Then restart the alignment procedure. That should do it.
i've had a CGX mount for a few years and usually have no issue with PA.
Hope this helps
Markus avatar
Hi John!
Many thanks for your answer! It's a good idea to move the tripod close to Polaris while looking through the finder, but…  I believe I haven't understood every thing about the alignment: can I aim Polaris through the finder without having made an alignment first? With your idea, what would the sequence be, or at which stage should I aim Polaris?
1) installing the mount, levelling and orienting it to N
2) installing the equatorial head
3) installing the telescope with the finder (and Laser pointer)
4) And what's next? Quick align and then looking for Polaris? Or just moving to the home position and then aiming Polaris?
Kind regards
Markus
Björn Arnold avatar
Hi Markus,
I just read your initial post again and I was wondering what might have gone wrong with your polar alignment. I‘m inclined to think that the issue is your compass. Make sure that when you place your compass near the mount that it doesn’t deviate as it seems (from pictures) that some components of the mount/tripod might be magnetic (e.g., the screws where the legs are attached to the mount saddle).
Same issue on my tripod. Most parts are aluminum or stainless steel but especially screws tend to be magnetic.
From what you have written, I assume you’re from the German speaking region. In case you‘re from Germany, you could align the front tripod leg even directly to magnetic north and if you place your mount centered, Polaris should be already in your finder scope, given the altitude ist set correctly and the mount is in its polar home position.
Once you have a good polar alignment, double check against your compass. The deviation should be around 2 to 4 degree.
Björn
Hello Markus
Markus:
Hi John!
Many thanks for your answer! It's a good idea to move the tripod close to Polaris while looking through the finder, but...  I believe I haven't understood every thing about the alignment: can I aim Polaris through the finder without having made an alignment first? With your idea, what would the sequence be, or at which stage should I aim Polaris?
Kind regards
Markus
Hello Markus
First you need to make sure you have your scope and finder scope aligned properly. Sometimes this is easier during the day with an eyepiece. Find a far away object and align both scopes on it. At night find a bright star or planet and fine tune the alignment. Once both scopes are aligned don't touch it any more. leave it on your scope.
Make sure you mount is in the center of the slots. I do not tighten these down all the way. I just leave them snug.
Now assemble the mount and place the scope on it. Once the mount and scope are fully assembled move it so the front leg is facing North. Any compass will do, it does not need to be perfect at this point. Most compasses indicate magnetic north and true north is slightly off of that. Soon enough you will be able to find Polaris easily and you wont need a compass.
Turn your mount on and make sure it is in the switch position. CGX asks you if you want to got to switch on start up so just do it when the hand controller wants. The English version says Switch Position it may be different in translation. I also have a Home position but that is adjustable and not necessarily at 0* in both axis's, though it usually is set that way at the factory.
Here is where you maneuver the mount into position. Do not use any adjustment knobs or buttons, you can even turn the mount off for this. Take the mount by the legs and gently move it around until Polaris is near the middle of your finder scope. Now you should be close enough that your polar alignment will work. If you still run out of room in the slots while you are polar aligning then give the mount a little nudge in the direction it needs to go. You may need to use the altitude knob for also.
Use your cameras live view to polar align. You should polar align before you do the star alignment. I would recommend using Sharpcap if your camera works with it. The polar alignment tool in Sharpcap is quick, easy and worth the nominal fee for that feature alone.
If you are using Celestrons all star polar alignment routine in the hand controller you have to Star align first (do the simplest alignment possible for the first step), Then polar align, Then do a full 3 star alignment with all the calibration stars. Some people say you should actually do a second polar align but I never had the patience for that. Celestrons software works OK, but no where near as good as some of the other camera based solutions available.
Hope this helps and if you need any advice on the CGX feel free to reach out to me. It took me some time to get used to my CGX and it needed some adjustments but I am very happy with it now.
Cheers
Markus avatar
Hi Björn
Hi John
I'm Swiss and I live in Tentlingen near Freiburg. Your explanations are very helpful. For me they mean that next time I'm setting my mount, I will slew the scope to the home position and then stand at a respectable distance behind it before I use the compass. Then I will place Polaris in the finderscope by moving the tripod. Then only I will start the alignment process.
Thanks a lot!
Markus
Rod Kennedy avatar
Hi Markus
Extending John's comments: "Magnetic declination" is the term for the difference between true North and magnetic North. It's about 3 degrees for Zürich.  Left or right?  Doesn't matter I wouldn't use a compass :-)
As in a previous response, you should man handle the whole mount and move the whole tripod and head initially.  I use the drift method to adjust the mount; have tracking on and look at a star near the meridian and with declination less than 30 degrees and use a high power eyepiece and see how it drifts up or down over a few minutes, and this tells you if you're left or right of North.  This azimuth adjustment works even if the polar axis elevation is not accurate.
I have the same mount and I leave it outside (covered) to avoid the agony of PA.
Cheers Rod
Markus avatar
Hi Rod!
Many thanks for your valuable answer! I will try your method and especially try to convince my wife to be allowed to leave the mount outside!
Kind regards
Markus
Scott Badger avatar
Regarding Celestron's All-Star alignment and doing star alignments after, note that the manual says to undo the synch first. My newbie understanding is that the mount records the off-set between where you align the mount on a star and where that star should be if the mount were polar alinged. Then once you re-align the mount alt/az, the software uses that off-set against the 'map' it created from the pre-PA star alignments to accurately slew.
I also use the Precise GoTo function which seems to work well.
Scott
Scott Badger avatar
A follow on question to the sequence of star alignment and polar alignment, why not do the alt/az mount alignment to line up the first alignment star (instead of using the hand controller to adjust ra/dec)? I assume the initial slew is as if the mount was polar aligned to start, right? But when I tried this a couple nights ago it didn’t seem to put me any closer to polar alignment at the start of the All Star process than before….
Scott
Tim Hutchison avatar
Your issues seems to be that you aren't properly accounting for magnetic declination. That is the difference between magnetic north and true north. There are lots of ways to determine the magnetic declination in your location. Here is one:
https://www.ngdc.noaa.gov/geomag/calculators/mobileDeclination.shtml#WMM
​​​​​​A compass that shows degrees in the sight glass makes this easy. I use this one:
https://www.amazon.com/Sportneer-Military-Lensatic-Waterproof-Shakeproof/dp/B01MY6VVWU/ref=mp_s_a_1_3?dchild=1&keywords=compass+hiking&qid=1617798053&sprefix=compass&sr=8-3
The hard part is that you cannot be close to the mount because the motors will distort where the compass is pointing. Get yourself a straight dowel rod that is around 3 or 4 feet long. Before you set down the tripod line up the dowel rod using the compass. But not to magnetic north, to the angle of your magnetic declination. Ex: my mag. dec. is -9.7°. Open the compass completely flat. Looking through the sight glass in the bottom of the compass I rotate to 9-10deg then look down through the target area of the compass and use the cross hairs to align the dowel perfectly. Now set the front leg on the tip of the rod and align the center post to be right over the top of the rod. Now set your mount on the tripod and move the az bolts to the center of the slots. You will be very close and well within the range of the adjustment bolts.
Personally I found the celestron alignment just ok. I used a polemaster to get close and then drift align to really refine the PA, but just a polemaster may be good enough depending on your focal length and exposure time.
Hope that is helpful.
Tim
Scott Badger avatar
Like others have mentioned, I just center the mount on the tripod and move the tripod to center Polaris in the finder scope to get started, but another good use for your straight dowel, Tim, is to get a star into the finder FOV. Maybe because I'm inexperienced, but sometimes the star I plainly see by naked eye can be inexplicably elusive when trying to locate it with the finder if it's not there already when the mount slews. Based on forum suggestions, I went on a very frustrating search for a green laser that actually worked, and in the meantime discovered that laying a straight dowel along the side of the scope and sighting down it works great. You just need to be sure it's parallel with the scope – I use the dovetail plate to line it up against.
Scott
Forget all compasses, digital or otherwise. Use the Sun, a straight rod, a weight and a string. And your place's time equation so you know when the Sun is exactly at noon thus crossing the meridian. Stick the rod into the ground at an angle. Tie the string to one end and the weight to another. The string will cast a shadow crossing both your swivel point (normally a peg or a screw) and the peg were you azimuth knobs will push against when stationing the mount. Adjust the mount so that the shadow crosses in the middle of these two points. You are all set for a proper pole alignment and not to fear hitting the buffers when adjusting the azimuth knobs.
Totally agree.  This is what I did when setting up my pier in my observatory.  It is a great method, if you are around at solar noon...
Markus avatar
Hi friends!
Wow, so many thanks for these answers! I didn't think at the difference between the magnetic and the true North, and this certainly is the reason for my troubles. Why does a manual not mention this… I have downloaded ab app on my phone and saved the NOAA Foield Calculator as a bookmark on my computer.
I'm looking forward to setting up my mount soon!
Kind regards
markus
Respectful Supportive
SicIturAdAstra avatar
Hi Markus,
I can't really add more than what as been (greatly) said, but just a tip. If you're imaging everytime from the same place, like your backyard for example, once the polar alignement done mark where the tripod legs are. Next time you will be able to place it roughly aligned, and it will need just minor adjustement.
Best regards
Rich Sky avatar
Hi Markus,
I don't know if this was covered in all the post, I have not read them. I use 3 long 1 foot nail in the ground to position my scope.
Then, I am almost at polaris, and my setup requires one slight bolt turn in dec and az.
Clear skies!
Richard
Markus avatar
Hi Richard
Many thanks for your answer! I just came in a minute ago and I was in my garden to mark the position of my mount on the ground. Yesterday, the alignment went without any problems. I corrected the alignemt of the tripod by the 2.6° of declination for my place and after having slewed the scope to the initial position I centered Polaris in the finder. The rest was easy!
Kind regards
Markus
Glad you got it sorted out!
Markus avatar
Hi all!
I just want to thank you all for your valuable and so much appreciated help. Yesterday evening, I managed the alignment of my mount in a very short time, without one single problem. The result was a perfectly centered NGC 2403 at the first attempt, and this with the C9.25 without reducer. I corrected the orientation of the tripod by the 2.6° of declination for my place and after having slewed the scope to the initial position I centered Polaris in the finder, without using the knobs, only by moving the tripod. Then I started the alignment. Today, I have marked the position of the tripod on the ground.
Kind regards
Markus
Helpful Respectful
How do you polar align your AM5 mount?
Because of the really bad weather here in Switzerland it has been a little while since I last used my AM5. Tonight is the first (and last) night with clear skies so I installed the AM5 and my 1000mm Newtonian on my balcony. Then the troubles started,...
Discusses polar alignment techniques for equatorial mounts similar to author's issue.
Mar 20, 2023
Polar Alignment with Star Adventurer 2 w/o Polaris in sight for DSO Imaging
Hi All, Hope you all are doing well. I am planning on testing my equipment at home from where the view to Polaris is blocked. The equipment I have is: Sony A7III ZWO Guide Scope and Camera Star Adventurer 2 Stellarmate OS on RPi4 w/ EKOS/KStars and P...
Addresses polar alignment challenges and workarounds without ideal conditions.
Jul 21, 2022
