The working length of William Optics FLT 132 ??
4 replies112 views
Roger Renberg avatar
Hello,
I am wondering of anyone could tell me the length of a WO FLT 132 with OTA filter wheel and camera and in focus for DSO´s ?
I have a small observatory that measures 1500mm x1500mm with a Skywatcher EQ8 R-Pro mount.
I need to know if this will work or if my telescope will be too large for this observatory before I press the purchase button.
Thank you
Uwe Deutermann avatar
I went out in the yard and measured it 😊, 1.2 meters or 4 ft.
Setup is this: https://www.astrobin.com/8du4tq/B/?nc=user
Hope that helps!
Hello,
That helps a ton man smile Thank you so much!
Kind regards
Roger
Alex avatar
I've been eyeing that scope, too.  Don't take the last one!  Kidding.  Best of luck and clear skies if you get it!
Was it the one at Agena Astro?  I saw they had one in stock for a couple weeks that disappeared yesterday afternoon.  If it had stuck around another couple weeks I probably would have caved in and ordered it.
Well written Respectful Engaging Supportive
Hei Alex,
Yes it looks like an amazing scope, but now I need to take some measurements to make sure it can actually fit and move freely in my observatory.
I have ordered it directly from WO and there is about 8 weeks wait on this. But ion it dont fit I will have to cancel the order smile
So im not the culprit of the missing scope at Agena Astro smile
Backfocus Solution for Celestron 9.25 SCT (Non Edge Version)
Hello, I am new to astrophotography and have come across a problem that has taken me weeks to find a solution to. I have a Celestron 9.25 SCT and have begun taking images. I have found a backfocus solution that works for me, but it requires using the...
Backfocus issues relevant to WO FLT 132 with filter wheel and camera setup.
Mar 7, 2023
Is Anyone Using the WO Flat 61 R
Tried to use my new Flat 61 R last night and couldn’t get to focus. I’m very familiar with the WO adjustable flatterers but just couldn’t get to focus. Im using a ZWO ASI 2600 with filter wheel and OAG and have the adjustable flattened set to 1 mm as...
WO equipment focusing problems similar to author's potential setup concerns.
Nov 24, 2022
