Recommend a monochrome Planetary Camera,Please!
4 replies95 views
StarCraft avatar
Which do you think is the best monochrome planetary camera? Why?
Wouter D'hoye avatar
i think the imx290 base camera’s are currently the best if you insist on going mono. If color camera is ok you can co for the imx462 based camera’s, which act monochrome with an IR-pass filter.
reason:
low noise
high sensitivity
high frame rate
small pixels (hig resolution without barlow)
Kind regards,
Wouter
Concise
StarCraft avatar
Wouter D'hoye:
reason:
low noise
high sensitivity
high frame rate
Kind regards,
Wouter
Thank you very much Wouter,I want to try something different.
David Goldstein avatar
StarCraft avatar
David Goldstein:
What Niall uses...
https://www.astrobin.com/fvjcg6/?nc=user
Oh,wonderful! That's a good choice
Solar Imaging "Path Forward" Advice Needed....
I have been into wildlife photography for about 8 years and just got into astrophotography a few months ago. I have been lurking around here recently and just joined yesterday. I have enjoyed viewing everyone's images and seeing the equipment use...
Oct 29, 2023
Both posts discuss equipment choices and recommendations for specific types of astronomical imaging.
