Kyle Cerniglia avatar
I can't for the life of me figure out how to do this. I'm using siril and gimp for processing.
I captured data with an OSC with a dual narrowband filter (First time). Using siril, I processed and extracted the Ha and Oiii layers, giving me my two grayscale images, one for each spectrum.
Now, I'm trying to figure out how I convert the Ha layer to be red, and the Oiii layer to be that typical teal color, where I would then merge them with transparency, much like how stars are added back in to normal images.
My end goal would be something like this: https://www.astrobin.com/full/tybmrb/0/?q=dual%20narrowband
where the blue layer is very distinct to the red layer.
I found some tutorials about how to use siril's pixel math tool to create a blended color scheme to mimic the hubble pallete by defining RED as Ha, GREEN as 0.6*Ha+0.4*Oiii, and BLUE as Oiii. But for this shot I'm capturing, the look isn't quite what I'm going for: https://www.astrobin.com/full/8akb5n/0/?q=veil%20nebula
Any help would be appreciated!
If you want to create a near true-color image you don't have to do anything, just balance the colors to obtain the usual rendering for a Ha-OIII emission nebula. If you want to create a true Hubble palette image you are out of luck as you haven't got a third independent color channel.
Well Written Concise
Interesting, I reprocessed my image how I would normally handle a sing OSC image, and it does look similar, I guess that will work for now.
Oscar H. avatar
Kyle Cerniglia:
So if you successfully got the 2 grayscale images then assign H to red, O to green and blue, and that's it.
Directions:
SIRIL - IMAGE PROCESSING -  RGB COMPOSITING
Or you can just keep the channels unseparated from the beginning and process the original OSC image.
New script for Osc dual band images
Hi all, I just published a new script (for Pixinsight) to convert Osc dual band images in RGB format to a HaOO image. I used the script to process this image https://www.astrobin.com/4zy08q/. If you would like to download it, then you can find it her...
Dual narrowband OSC processing similar to author's script application.
May 29, 2022
Astro pixel Processor - How to combine a OSC broadband image and Extracted Ha and OIII from a dualband filter?
Hello All, I have a 2600MC-pro and have been using APP for a couple of years. I normally am only using 1 filter so no issues stacking. APP has been great. Now I would now like to take broadband subs and add the Extracted Ha and OIII from my antlia AL...
Directly addresses combining extracted Ha and OIII layers from dual narrowband filters.
Sep 5, 2025
