Mark Germani avatar
Hi there:
I'm wondering if I need to rethink my galaxy imaging techniques. Briefly, here's my setup:
- WO Zenithstar 61 apo
- Skyguider Pro star-tracker, unguided
- Canon T3i/600D unmodified
I'm imaging in my backyard, aiming away from street-lamps (yuck) under Bortle 8 skies. I *own* a Svbony CLS filter, but I do not use it for galaxies, as my reading seems to indicate that they block a lot light from broadband targets and the Svbony is pretty harsh. My exposure times are 3-4 x longer with the filter in to get the same exposure. My exposure times are usually between 45-60 seconds.
I know there are better CLS filters out there (Optolong L-Pro) but I can't upgrade right now ($$$) but I'm wondering if I should really be doing all these short exposures without a filter, or if I'm doing myself a disservice by not using what I've got. I kind of like the short exposures as I have a hard time going much past 90 seconds unguided - I end up throwing out a lot of frames. But if it's what I need to do, then so be it.
For reference, here are a few samples of galaxies without the CLS that I've imaged over the past few months:
https://www.astrobin.com/qvflmz/
https://www.astrobin.com/8myxjs/
I'm using drizzle to gain a bit of resolution as they're a bit small for my FOV.
Any and all input is appreciated!
Mark
Björn Arnold avatar
Hi Mark,
I think you can safely use the CLS filter. As you said, Galaxies are broad band emitters and hence produce signal also in the transmissive part of the filter spectrum. With the CLS you should be able to counter the Bortle 8 sky pretty well and produce more contrast for the galaxies. So you definitely should give it a try.
Regarding exposure time, I don't know if you take a more quantitative or qualitative approach. In my very beginnings, I followed the rule that the histogram "mountain" should be located about 25 to 30% away from the left (black) side of the histogram (which I call the qualitative approach nowadays). However, that's way too much of exposure time. I'm taking the quantitative approach (at least that's what I call it):
I determined the signal statistics of the dark frames. Then I do the exposures on the target, I'm checking that the histogram peak starts about 4 to 5 standard deviations above the noise means. You'd be surprised how quickly this happens. I would assume you even wouldn't have to increase exposure by a factor of 2 to achieve that.
Personally, I don't see a reason for drizzle. You've got a 18MP APS-C chip. With the given optics, you get about 1,4"/pixel, which is close to ideal.
CS!
Björn
Mark Germani avatar
Thanks @Björn Arnold!
Ok, so maybe I should give the CLS filter a shot. I did notice that when imaging Pleides, an hour without the filter produced a MUCH better image than an hour with the filter, so I'm a bit hesitant here. Does that make sense?
I'm intrigued by your exposure time approach, but a little confused. Are you measuring the standard deviation of dark frames or bias frames? I was only able to find one reference to exposure settings as a multiple of the standard deviation of bias frames. My bias frames have a standard deviation of 0.45 (RBG) and my 45 second exposures without the CLS are 4.95, which suggests that I should be exposing at closer to 20-25 seconds without the CLS. Does this make sense?
Interestingly enough, that article said that for OSC cameras, you need to measure each colour, in which case I'm actually correctly exposed at 45 seconds, except for red which is underexposed. So I'm even more confused!
Lastly, using this calculator - https://astronomy.tools/calculators/ccd_suitability - my setup is actually 2.46"/pixel, which is just on the margin of being undersampled. Would you still not recommend drizzling? It seems to improve the detail on objects that are very narrow in my FOV. Or did I calculate it wrong?
Sorry for the questions and confusion, but I'm really curious now. Thanks again!
Mark
Respectful
Björn Arnold avatar
Hi Mark,
Can you explain what you mean by better regarding your Pleiades?
Assuming that all the settings were the same, the camera will collect more light without the filter. The Plejades are a star cluster with a reflection nebula and hence emit in a broad spectrum, contrary to nebulae consisting of ionized hydrogen. It also depends on where the objects was located during the time of shooting. If it's rather high up in the sky, the effect of light pollution is lower and you might even be able to shoot without the filter. Therefore, it can indeed be that without the filter, the picture might be better.
Also, I personally tend to question the future effectiveness of the light pollution filters as more and more sources are LED lights that don't emit lines like the classical sodium-vapor street lights. And these LEDs are insanely brighter than the classical lights - don't ask me why we need to brighten up the night further.
You need to use the darks as a basis for the histogram. Although in many cases, the bias gives most of the noise signal, the long term exposure and hence the temperature add some noise. I've analyzed my EOS250D and most came from the bias but the exposure time cannot be neglected.
You need to consider the color channels separately as the sensor is less sensitive in red and blue compared to green. Also standard deviation isn't sufficient, you need to know the mean of the dark signal as well.
I am nowadays shooting mostly mono but this can be easily transferred to color. I'm just making up some numbers as I don't have the values for my DSLR at hand: assume the mean of the darks is 0.8 (on a scale of 0 to 255) and the standard deviation 0.4, my lower signal limit would be 0.8+3*0.4=2.0. Hence, for my lights all signal should be above 2.0. To make your life easier with the colors, compute the limit based on the "worst" color channel in the darks and set this as a limit for the "worst" color channel of the light, which is likely to be the red as it has least sensitivity. That would be my approach.
I hope my explanation isn't too confusing. Otherwise, let me know.
If you should reduce the exposure time to 25 instead of 45 isn't necessarily true. It depends: it you increase exposure time, you'll catch fainter detail. On the other hand you are more likely to saturate the stars and they will more easily blow up in post processing. Therefore, I am checking two things: First, are the stars saturating? If not, I usually increase exposure time until they are at the edge of saturating. In parallel, I keep an eye on  the histogram spike. If that's well above the noise (see above), I rather prefer shorter exposure times and make more subs as this also increases dynamic range and you can afford trashing subs in case of whatever (satellite, guiding error etc.).
For fainter DSOs you'll likely saturate stars before your histogram spike is above noise level. But that's how it is.
Regarding your resolution: you're right, your 2.46"/pixel is at the limit but you need to judge on the final image quality. Drizzle is done after the capturing, so you won't loose anything if you try both approaches and compare which you like better. Also, I don't see if you are guiding or not. If you're not guiding, the error will likely be larger than the 2.46".
I've taken a look at your gallery. They're nice images.
If I may recommend: you should take a look at your flattener. The stars in the images are a bit egg shaped at the edges. Either the flattener doesn't fit the optics or the working distance isn't set correctly.
CS!
Björn
Mark Germani avatar
Thanks again, @Björn Arnold!
- Re: M45, better in the sense that I collected a LOT more light, contrast notwithstanding (I processed both nights with black normalized and compared). I don't have LED streetlamps in my backyard yet, so the Svbony CLS does work reasonably well on them but the Svbony CLS is super high-contrast and blocks so much light that I only tend to use it on emission nubulae.
- Using the Std. Dev. of the darks to determine exposure time seems a bit chicken-and-egg to me - how will I know how long to expose the darks if I'm using them to determine exposure time for the lights? Also, I have no way of knowing my Std Dev in the field, unless that information is available somewhere in my camera. I shoot unguided without a laptop.
Those are good points about overexposing the stars. I think my takeaway from your comments is that I might lean closer to 1/4 from the bottom of the histogram instead of 1/3, like I have been of late. I can always check the standard deviation later while processing, as a matter of interest.
Thanks for your kind comment on my gallery! Yeah, I'm waiting on the proper flattener for my OTA - it's back-ordered at every store in Canada right now. I've been using a flattener that came with my scope which is out-of-spec. I have been avoiding larger targets for the time being so that I can crop the most offensive stars out!
Thanks again!
Mark
Helpful Respectful Supportive
Björn Arnold avatar
Hi @Mark Germani ,- Re: M45. As you said, you're collecting much more light. So, for the explanation, I think my previous post should explain it. I agree with the emission nebulae.- Re: Darks. It's not chicken-and-egg. One thing I am doing, and maybe some people would strongly object, is that I use a bias and darks database. I'm not capturing darks and bias each session. I captured one set of bias frames and different sets of darks for some typical exposure times (60, 120, 180 seconds). The darks were captured at 20 degree Centigrade temperature. Usually lights are captured at lower temperatures so with my „hot“ darks, I am subtracting too much. However, the strongest effect is exposure time and not temperature and if I place my signal level above the noise level of the „hot“ darks, I’ll be safe.Now, I’ve now put some realistic numbers for the darks together: my 60s@ISO800@20degC give a mean intensity of 2.29 (always on a scale 0 to 255). with std. dev. 3.52, hence my lower signal limit would be 12.86. That’s about a 20th of the histogram! So, you could even go below the 1/4. However, don't start to make exposures of 26 seconds because the best fit of the histogram. Round a bit up to common exposures (like 30 or 60 seconds).
There's one thing to be careful about: sometimes, the horizontal axis of the histogram is log scaled. As far as I know, Canon shows a linear intensity scale on the cameras. Something one has to keep in mind!
Also the numbers above are for my EOS250D. Your 600D might have different values (but I'd expect not completely off).
By the way: the bias frames have mean 2.18 and std. dev. 3.05. You can see how little the time and hence temperature make!! Most of the nose is simply the read out noise of the amplifier.
I agree with you in the point that without the laptop you cannot make this assessment. Also, I made my analysis in the very beginning, after capturing the darks and work with rule of thumbs. However, it should give you a feeling that the cameras don't have so much noise as one would think and that this broadly repeated 1/3 or 1/4 rule is IMHO way too conservative nowadays. If you go from 1/3 to 1/6 you're still way above the noise but you double the number of lights and also can achieve a higher dynamic range and your less likely to saturate anything etc. etc. (I'm attaching two images to illustrate)
Long story short: No need to make a science out of it but the rules of thumb can be more aggressive than they're right now. Experiment a bit and find a suitable setting. I'm certain that after a while, you'll find that you'll place your histogram below 1/4.
- Re flattener: When I received my refractor, I hadn't ordered the flattener (you can see this at my M31 https://astrob.in/3t38ig/0/) and I also cropped the worst parts away.
CS!
Björn
Here's a sub of my Plejades (https://astrob.in/pre6bm/0/) and the histogram. The peaks are a bit below 1/16th and I would say I am slightly underexposed with that. What you can also see in the sub is that the brightest stars are only slightly saturated (red pixels). Certainly, there are images showing much more detail of the nebula area. To enhance this part, I personally will try to capture more subs as this will increase dynamic range even further.
Bildschirmfoto 2021-03-13 um 08.03.13.png Bildschirmfoto 2021-03-13 um 08.02.59.png
Mark Germani avatar
Thanks again @Björn Arnold - Just getting back to this thread. It was very useful to see that sub and the histogram.
I did, actually, get out last night and did some imaging with the CLS filter. I usually shoot ISO1600 with the filter in to keep the exposure lengths down, but with your advice in mind I went back to ISO800 which, for my 600D, is the optimal ISO. My histogram was peaking around 1/5 at 90 seconds, but I decided to leave it there and not try and increase the exposure. I imaged the Rosette nebula and the Leo Triplet. I'll be stacking them later this week, so it will be interesting to see the result.
In the meantime, I had a thought - what about shooting a series of exposures without the CLS, and then another series with, and using the CLS-filtered stacked image as a luminance layer? I'd still get the broadband colour from the images taken without the filter, but the contrast from the filter. Just a thought. I heard from another astrophotographer here that he relies almost entirely on Photometric Colour Calibration to add natural colour to his galaxy images.
As always in this hobby, so many variables & approaches!
CS!
Mark
Björn Arnold avatar
Hi @Mark Germani ,
It absolutely is, but I can assure you, as I've worked in academia and I'm working now in industry: there's even more variables and approaches and there's no right and wrong like black and white either . But as a hobby, we should be relaxed about it and enjoy the process of following these approaches and the learnings we make. I also had and still have nights, where I was a little disappointed about the outcome but when you do a retrospective, there'll be things you've learned.
And most importantly, IMHO, it's not about chasing likes on AstroBin but about following a hobby and share some ideas with like-minded people and find satisfaction that the image that you hold in your hand was made by you through your work.
- Re "the actual topic": I'm also only shooting at ISO800 with my DSLR.  About your idea to use the CLS as a luminance layer: try it!
However, I wouldn't expect a very different outcome. What will happen? Assume you image without filter. And also assume you shoot without any light pollution. You'd get a "perfect" RGB image. So it contains all info. When you shoot the CLS image, you remove certain colors, like the yellow and orange tones. If you put this as a luminance overlay, you'll remove these colors from the image by setting their luminance to 0. It'll increase contrast. I'd say you wouldn't gain a lot. It's essentially the very same thing the CLS does when it's in the camera. That's my theory but why not try it. As I said: it's a hobby and if you don't break anything why not following ideas.
It'd be different if you wouldn't shoot with a color DSLR but a monochrome camera. There, you would capture lower quality RGB channels, as it's "only" about catching the tone. For the luminance, one would use highest resolution and since it's mono all pixels are sensitive and detail will be improved. But one shouldn't underestimate the fact that with a mono you have to shoot the channels in sequence. Hence, mono cameras don't invalidate DSLRs in any form, IMHO.
I'm curious what results you will get!
CS!
Björn
Mark Germani avatar
Just returning to this topic briefly, I did a small experiment last week and shot an hour of the Leo Triplet with my CLS filter (90s at ISO800), and an hour without (45s ISO800). Keeping in mind @Björn Arnold's advice regarding exposure time, I settled for a histogram which peaked at 1/5 for the CLS filter, as opposed to 2/5 without.
Comparing the resulting images, the SNR of the stacked image without the CLS was significantly higher than with the filter. More than twice as high. Comparing the individual subs, the calibrated SNR for each light frame was nearly identical with or without the filter, so it seems that there was no advantage for me to shoot with the filter. I may have been able to produce a similar SNR, but it would have required me to take as many 90s exposures as 45s exposures, doubling the time required. Perhaps if I had increased the exposure time so that the histogram peaked at 2/5 I would have noticed an improvement, but I've had ended up with fewer subs in the given hour, or I would have had to increase the ISO to 1600. Either way it would have still produced a lower SNR, I would imagine.
This is all using information from Astro Pixel Processor, and I may be reading the numbers incorrectly, but from a purely visual standpoint I achieved much better detail and lower noise during the session without the filter.
I will likely try this all again when I eventually buy a better CLS filter, but for now I'll ditch it for galaxies. Thanks for weighing in, @Björn Arnold!
Mark
PS: I have stacked the two additional nights with an earlier session, and posted the result: https://www.astrobin.com/8myxjs/B/
Björn Arnold avatar
Hi Mark,
Thank you for letting us know your results. I'm happy to hear that you are satisfied with them.
Unfortunately, I didn't have any chance to capture anything in the recent weeks, except a quick trial of my new mechanical star tracker. smile
CS!
Björn
How Best to improve?
Hi there everyone! I have been shooting the night sky for just under a year now and i have recently got auto guiding set up. I was wondering how i can improve my images and what I can do better? Preferably without having to spend thousands of pounds ...
Techniques for improving deep-sky galaxy imaging quality.
Mar 13, 2019
Best gain offset for using 12 nm. Narrowband filters
Hi everyone, I use optolong 12 nm. Narrowband filters for my qhy163m, I was wondering should I use a lower gain and offset for these filters due to their, wider bandpass as supposed to say 5 or 6 nm. Filters ,also what is a good recommend gain and of...
Discusses filter selection and imaging techniques for specific equipment setup.
Nov 2, 2019
DSLR Exposure Time - Sudden Change?
Hi folks: I'm struggling with a strange issue that has just cropped up after a few years of astrophotography with the same DSLR. I've been using 360s (6-minute) exposures with my Canon 600D and the L-eXtreme filter @ ISO800. When I load the R...
DSLR exposure time issues may relate to author's 3-4 second exposure setup.
Aug 3, 2022
