Having gained some experience with OSC imaging, I tried my first narrowband image last night.
NGC3579 (Statue of Liberty) was my target. I took 25 x 300sec frames in each of Ha, SII and OIII.
I must say that I am pretty disappointed with the result. And I am not sure whether it was the conditions (4-5arcsec seeing, thin cloud throughout0, my observations (should I have taken more SII, or longer exposures?) or my processing skills.
The images were processed in PI using the Weighted Batch Preprocessing script (which has worked really well for me on OSC images),
SHO-AIP to merge the resultant masters (equal weight to each master) using the standard Hubble palette, followed by the using post-processing workflow (at least for me) of Background Correction, MLT noise reduction/histogram Transformation/TGVDenoise/LocalHIstrogramEqualisation/StarReduction/Curves Transformation on the "luminance" part - not on the saturation (it was garish enough already) and a hint of Unsharpmask at the end.
The result is uninspiring. What an I doing wrong? Or it is just the data. Perhaps I should have chosen something with a little more SII.
With thanks in advance for the advice.
