Question re my next upgrade - Scope or Camera?
7 replies276 views
Which should I do based on these facts?
Single choice poll 15 votes
20% (3 votes)
33% (5 votes)
47% (7 votes)
Interstellar Medium Rare avatar
Y'all,
I have about $2500 to spend on my next upgrade (lucky me!).  I sold a bunch of music gear I wasn't using.  Goal is to either (1) upgrade my camera or (2) purchase a larger scope.  Here's the scoop.
-Current Camera:  533 MC Pro
-Current Scope:  Askar 400 FRA quint
I want to capture more detail, and I would like to go up in FL/Aperture.  I most want to capture a lot more of the finer detail of my targets, and a close secondary goal is to be able to capture more detail in medium-size galaxies (smaller targets than, say, Triangulum).
Considering:
-Replace my 533MC Pro with a 2600 MC Duo
OR
-Purchasing an Askar 107 PHQ or Askar 140 APO Triplet (w/flattener) to have in addition to my Askar 400 FRA.
I'm really torn, but maybe there is an easy way to decide that I'm missing.  Any input would be *very* appreciated.
-IMR
Brian Puhl avatar
Option 4:   Switch to mono :-).   533 or 571 are both similar sensors, just one has more pixels.    If budget is an issue, a 533 mono with filters should be well inside that.
Nothing beats aperture, except the seeing…
Menelaos avatar
I would go for the bigger scope! 533 has a smaller sensor than 2600 so targets appear closer I guess. Galaxy season is around the corner!
Adel Kildeev avatar
I would also opt for a new Mono camera and nice NB filters ( cost a fortune now).
LookSpaceThings avatar
I would also consider the Askar 130PHQ, you won't need a flattener for this scope.
Bastiaan Feenstra avatar
100% go for a scope. The camera is expensive and will only give you a wider fov at the same pixel size. So if the goal is finer and more detail, aperture is the way.
Quinn Groessl avatar
Scope for sure. 533 is an extremely capable camera. Except for the FOV and the benefit of having a guide camera built in, I don't think you'd be as happy as a larger scope.
Scope for ZWO 533MC PRO
Hi All, I am after some help. I am looking to change my current Skywatcher Quattro 8 inch for an APO refractor with will be used with a ZWO 533MC PRO. I have find a few options and would like some help, my goal is to have one scope only which is prim...
Discusses scope versus camera upgrade decision with budget considerations.
Jan 25, 2022
New Telescope of Focuser?
UPDATE: I do have the EAF on this set up to let those know. I forgot to list that. I was more worried about the tube angle since it was sagging in the scope. I also have since posting this in the forum have purchased a new telescope: Askar 65PHQ I wi...
Discusses telescope upgrades and equipment modifications relevant to author's scope decision.
May 15, 2025
Mono camera advice: 2600mm vs 6200mm for bortle 8+ astrophotography
I currently have a 2600mc that Ive been using for a little over 3 years and need some camera advice for a possible mono setup. I live in bortle 8+ and only get to dark sky once a month or so. I’m more into clusters and galaxies than nebula, but I end...
Camera upgrade advice directly applicable to author's $2500 camera upgrade consideration.
Dec 7, 2025
New Telescope and Accessories
Hello, I'm currently in the process of purchasing a Celestron Nexstar Evolution 8 and I have several questions. 1. Does it require maintenance? If so, what tools would best be used? I've seen laser collimators and collimation knobs. Will I need these...
New telescope and accessories discussion relevant to author's scope upgrade option.
Oct 30, 2025
Building My First Galaxy-Hunting Rig – Need Advice!
Dear Astro Experts, I'm new to astrophotography and could use some guidance. A fellow member recommended that I post my questions here. I'm considering purchasing the Askar 120APO telescope paired with the ZWO AM5 mount. My goal is to build a...
First astrophotography rig building advice applicable to author's equipment upgrade planning.
Jul 21, 2025
