So–I came across this formula for determining the needed filter diameter. Does it look right to those who know?
FD = ((Distance from filter to sensor/F-ratio) + (Sensor diagonal/2)) x 2
As focal ratio goes down–the filter size needed goes up. The problem I am having is I do not know how far inside the filter wheel the filter sits. So with a camera that has 17.5 mm backfocus (ASI 2600), using the ZWO 7 position 36 mm filter wheel–how far from the sensor is the filter. It will be 17.5 plus some number. The total thickness of the filter wheel is 20 mm–but the filter is close to the camera side of the device. I am thinking 5 mm….but I do not know and I need an exact number as it will be very close at F3 and F5 for 36 mm filters
