Bortle 7 Hyperstar Broadband
7 replies462 views
Arpad R avatar
I finally have a full clear night coming up and I would like to image some broadband targets. I am currently thinking of doing the Dark Shark Nebula. What are other targets I should consider?
I have read that it is not beneficial to take exposures above 30 seconds while imaging broadband at F/2 but I'm not clear on the reasons.
Is this a myth, what else should I be looking out for in a bortle 7 area?
I will have 12 hours of clear skies so the number of exposures will be a consideration.
The camera I will be using is an Altair 26C, are there any settings that would optimise the session?
Dustin Gazz avatar
I take 300sec exposures at f2 with an Edge8 and Hyperstar without issues on dimmer objects, like the Shark. I also take 50-60 60sec exposures and use those for the stars in the final image. You don't have to, but you end up with slightly sharper stars if you want to take those extra steps.
estabrook avatar
I would image M78 and Barnard's loop in Orion, which has both broadband and narrowband elements.
I have imaged this pair with a Hyperstar rig from a Bortle 8-9 zone last year: https://www.astrobin.com/k95l7a/C/
I was pleased with the result, but I think it could be done (and indeed has been done) much better.
Also, I think you can extend your exposures to about 60 seconds.  More than that and you will risk blowing out your stars at f/2.
Finally, I would also suggest IC 447, Dreyer's nebula, in Monoceres. I'm working on this now with a slower setup and I'm craving f/2!
Hope this helps and clear skies!
Matt
Helpful Concise Supportive
shenmesaodongxia avatar
You should use some light pollution  filter.
Arpad R avatar
Thanks for the tips, I have also thought about doing M81 and M82 to try and get some IFN but my field of view may be too large to capture the galaxies in detail.
Konstantin Firsov avatar
Arpad R:
Even if you are not worried about the complicated gradients, there is another fundamental issue you will be facing at Bortle7. It is background sky noise. Once you have totally gathered, say, X e- of the sky, you get SQRT(X) of noise added to your data. There is no way to fix this but driving somewhere under the darker skies or using narrowband filters.
DARRELL DUBOSE avatar
You mention above that you were not clear on the reasons for selecting a certain exposure time. There is this excellent talk of Dr. Robin Glover about sub-exposure time, depending on your sky brightness and the read noise of your CMOS camera (link below). It is worth viewing the entire video and will help separate some of the myth from theory. I've used his approach for calculating sub-exposure time and the results can be surprisingly short sub-exposure times for my Hyperstar rig and ASI2600MC-Pro. I take the results as minimums and add time for light pollution or narrowband filters.
Good luck!
Darrell
https://www.youtube.com/watch?v=3RH93UvP358&t
fielderda avatar
Similar to Darrell, I use up to 300sec for NB (Bortle 8) and up to 30 seconds for broadband for my stars. For galaxies, I never go over 60 secs as stars get blown-out.  For dark zones, the sky's the limits!
Galaxies with 585MC Pro
Hi everyone, I’m at the point of maximum confusion. My new ASI585MC Pro is a great piece of technology. But when it comes to the right settings, I’m getting lost. Clear skies are rare at the moment, so I’m doing a lot of theory. I use the camera on m...
Broadband imaging camera settings and optimization for astrophotography targets.
Jun 5, 2025
Efficient way to collect more data with Infrequent clear/short night ??
Hello, I am thinking about using below strategy to maximize/collect more data based on my imaging style and constraints. I live under bortle 4.5 ~ 5.5 skies and what I have found from the last 2 years of imaging is that I collect approx 4hr of data i...
Maximizing data collection during limited clear night opportunities available.
Jul 2, 2025
