Peyton Lorimor avatar
I’m working on a multi night project targeting the Heart Nebula at the moment, and I’m curious as to what method(s) I can use to combine these sessions into the best final product. I currently stack using DSS, but I have heard PixInsight may be more effective?
I have some data from a bortle 4 site, and some from bortle 7. Assuming the bortle 4 data is better, will stacking it alongside the bortle 7 benefit  it, or just drag it down?
Well written Engaging
dkamen avatar
They will have significantly different background levels so averaging them will tend to produce a washed out result.
They need to be normalized (brought to roughly the same brightness and background level as the reference sub by adding or multiplying with a correction factor) before stacking. DSS cannot do that. Siril, APP, PixInsight, they all can.
Well written Helpful Concise
Nick Grundy avatar
I would suggest stacking them as different sessions in AstroPixelProcessor(APP). Although I've been tempted recently to shift to Pixinsight pre-processing, APP has always been good to me. If you go with APP, I would recommend experimenting with the data inclusion. I spent several hours this evening testing different combos in a stack. (more data from multiple scope vs higher qaulity data, etc). So far all I can tell is that I don't trust the scoring mechanisms in APP. I recommend analyzing your subs ahead of time and stacking 100% of what you end up loading into APP.
If anyone out there has a more complete understanding of multi-band-blending in APP, I'd love to hear their descriptions on pros/cons of including different FOV datasets
Question about Wanderer ETA and multi-night registration
Hi everyone, I don’t have the WandererAstro ETA (Electronic Tilt Adjuster) yet, but I’m seriously considering it and I’ve been thinking about a possible side effect. As far as I understand, the ETA adjusts each corner of the sensor independently. Thi...
Multi-night registration relevant to combining Heart Nebula imaging sessions.
Aug 31, 2025
A dual band filter for Luminance in LRGB images (monochrome camera)
I live and image in a Bortle 7 area. I found that my UV/IR cut clear L filter resulted in unusable Luminance data. Other members of my astronomy society tend to use narrowband images because of similar issues. As a last resort I decided to replace my...
Bortle 7 imaging challenges directly applicable to author's light pollution concern.
May 2, 2025
