luher avatar
[pre]Dear Skywatcher CQ350 Pro users
Can anyone tell me if the Skywatcher CQ350 Pro Mount is compatible with Zwo Asiair Plus? I can't find any clear information about this. So this mount is stored in the Zwo Asiair Plus software.
Can anyone tell me about the accuracy of the guiding of this mount?
Are there any points that can cause problems when combining this mount and the Zwo Asiair Plus?
Does the polar alignment routine (without viewing Polaris) work reliably and accurately?
I would like to thank everyone who took the trouble to answer me.
Best regards
luher[/pre]
Deepan Vishal avatar
Hi Luher,
I can confirm that ASIAir works well with CQ350. I am one of the early adopters of this mount.
I am not technically sound and haven’t invested much time using Phd2 to do an end to end analysis on the mount performance.
All I can say with my experience is, I am happy with its performance. With good balancing I get results from 0.3” to 08” depending upon the seeing conditions.
I have some sample images in my astrobin page. I’ll be happy to share guidelogs if you’d like to see.
Thanks,
Deepan
luher avatar
Dear Deepan
thanks alot for your answer. I‘d like to see your guidelogs and will check your photos. [pre]I would like to change the mount in the long term and see this product as a very good solution. thank you very much!
best regards
luher
[/pre]
MaksPower avatar
Hi Luther,
Yes the ASIAir and CQ350 work together - I have this combination.
Polar alignment works for me in the southern hemisphere (no Polaris) - but it does require a view of the sky around the pole, as it requires the scope to be aimed at declination 90 degrees.
I have also tried the new “all sky” polar alignment but it failed to work for me.
Well Written Helpful Insightful Respectful
David Cruz avatar
Hi, can anyone tell me how to connect the asiair to the mount? Is it with a EQ-mod cable or it can be a direct connection to the usb port?
Marc-Antonio Fischer avatar
CQ350 reliability
I am just about to exchange my second CQ350 mount in one year, with acknowledged issues. Both my CQ350s have shown large RA errors, caused by the mount sticking at a specific HA. I suspect this is due to non-circularity of the main RA gear and/or bin...
CQ350 reliability — discusses mount accuracy and RA errors relevant to your concerns.
Aug 2, 2025
iOptron Skyhunter and ASIAir support
I've an iOptron Skyhunter with iPolar, I am planning to get ZWO ASIAir Mini computer to control my set up but unable to get any resource saying if it is compatible with the mount or not. I've checked ZWO support website and this mount is not ...
iOptron Skyhunter and ASIAir support — addresses ASIAir compatibility with different mounts.
Jun 11, 2025
Polar alignment produces absurd correction angles
Hi, I am using an ASIAir Mini with a Skywatcher EQ AL55i mount connected via the serial cable (could not get any other connection to work properly). I can control the mount from the ASIAir app and I got my camera and focus set up. Plate solving works...
Polar alignment produces absurd correction angles — discusses ASIAir polar alignment issues directly.
Aug 18, 2025
ASIAIR Mini and ASI2600MC exposure failures despite troubleshooting attempts
Hello, I have been using the ASIAIR Mini coupled with the ASI2600MC camera. My current set-up has been working flawlessly for a long while. Last night I had a little initial trouble with the start-up, the camera advised an exposure failure while I wa...
ASIAIR Mini and ASI2600MC exposure failures — troubleshoots ASIAir equipment integration problems.
Oct 11, 2025
