Filter Assistance
William Optics CAT Series 6 replies87 views
Joey Troy avatar
So I bought the ASI533 with the RedCat (still in transit). Can I get away with a 1.25 filter on the camera, or do I use the 2inch filter on the RedCat? If you have pictures that would be slick.
Tom avatar
It goes by the sensor size on the camera, not the scope. I use 1.25” with my Spacecat, but I use a 183mc pro which has a smaller sensor, so smaller filters will work. Not sure about ur camera
Tom avatar
I found other people on cloudy nights forums who said 1.25” will work with ur camera
Joey Troy avatar
@jjjakus17 I see you can install a 2.0 filter on the Red Cat in the back
http://www.youtube.com/watch?v=PhO7_q7mUME&t=0m46s
Just wasn't sure if I could sneak away with 1.25 on the camera.
Tom avatar
I use an efw but yes u can get away with 1.25
Lee avatar
When using the ASI533, I use 2" filters (UVIR cut or L-eNhance for example).  With the built in 2" filter thread on the back of the RedCat it's an easy way to do it… although expensive comparing to the 1.25".
With the 1.25" it's just a case of ensuring you have a thread to get it in front of the camera.  Won't be any problem from a sensor size anyway as the diagonal is only approx 16mm.  Perhaps a 1.25" filter drawer for easy swapping - close to the sensor.
Topographic avatar
The 533 comes with the 1.25" T2 adapter, gets the filter in nice and close. Shouldn't be a problem.
Help with new EAA/Astrophotography cameras setup
I've done mostly observation work in the past using Dobsonians. A couple of months ago I bought a whole new setup to do EAA and Astrophotography. I'm pretty sure I bought decent equipment, considering my budgetary limits, so my questions have...
New camera setup advice relevant to ASI533 and filter configuration questions.
Aug 10, 2022
Filter comparison for fast filters, Antlia ALP-THS vs. Baader Highspeed 3.5/4nm filters
As I had quite good results with the normal Antlia ALP-T Dualband Filter I also bought the High Speed Version of that filter as soon as I realized it exists. So now I have a set of Baader High Speed Filters and the Antlia, so why not try to compare t...
Filter selection guidance applicable to camera and telescope filter compatibility.
Jul 4, 2022
