Asi air power adaptor
2 replies169 views
Menelaos avatar
Hello and good afternoon.
I have a question about powering the asi air plus. It says in the manual that it requires a minimum of 12V power supply but it doesn’t state the maximum it can handle. I have a a power cable that provides 15V. Would that be a lot and burn the circuits or is that ok? How do you guys power your asi air?
Elmiko avatar
As long as the power supply is between 12-13  volts you will be fine.  The power cable is rated for 15 volts.
Well Written Concise
John Stephens avatar
Per the ZWO website the ASIAIR Plus is rated for 9-15vdc, so I would be careful with an adaptor that provides exactly the max power rating I would double check it's output with a volt meter to ensure it isn't providing over 15v.
FAQ #5
https://astronomy-imaging-camera.com/product/asiair-plus/
ASAIR Plus - Mini PC
GDay all. I was pulled into astro when watching youtube three years ago. The ASIAIR Plus made it pretty simple for this non guru and besides I had no laptop. I run an ethernet cable to the Air an monitor via IP address on my desktop PC. I have no dra...
ASIAIR Plus device discussion relevant to power supply questions.
Dec 8, 2025
ASIAIR Mini Amp Problem
Hello, I'm having trouble with my ASIAIR Mini concerning power supply, especially Amps. Recently it's behaving very strange, and the internal measurements show 12V, but only 0.1A. After seeing that, I tried multiple PSUs (2 official ZWO 12V5A...
ASIAIR Mini power supply and amperage troubleshooting directly applicable.
Aug 20, 2025
